Question about Panasonic Audio Players & Recorders
My panasonic sa-ak58 home stereo, it turns on o.k. but after a couple of seconds i loose audio, on all speakers, but the led screen shows normal volume level, no matter if is high or low on volume.
Go on the back of the stereo take a aux cable and hook to the back and touch the end were it plugs in to the mp3 r what ever you use and if its still making the nosie your amps fried
Posted on Nov 01, 2010
How do i get my panasonic sa-ak58 to read discs? it wont read them.
I'm afraid if your Panasonic SA-AK58 is not reading disks, and you don't have the technical preparation to repair ir, it has some hardware problem and you should take it to repair.
Feb 21, 2015 | Panasonic Audio Players & Recorders
Panasonic sa-vk800 when the volume up the unit is shoot down than display f16
Check all of your speaker wire connections at both ends for looseness, strand wire fraying/breakage, correct polarity and corrosion. If all are ok, reduce your setting for the amount of bass it outputs.
Dec 15, 2014 | Panasonic Sa-ht70 Home Theater Receiver 5...
Kenwood A722L no sound and volume led blinking
This could be due to a faulty speaker relay (if your unit uses one). Normally, the unit will "wait" a couple of seconds after you turn the unit on. Then you will hear a "click" and the sound will begin coming through the speakers. If the relay is faulty, it would cause the problem you describe.
Aug 01, 2014 | Kenwood Audio Players & Recorders
I have a panasonic sa-ak58 sterio system and woud like to pug my mic into it. how do i do so
Hi
You would need to buy a small mixing desk which would plug into the AUX input at the back of your Stereo. Your microphone would plug into the Mixing desk.
Good luck. Michael
Aug 24, 2011 | Coby CM-P35 Consumer Microphone
My panasonic sa ht930 is well connected and the subwoofer is on but the stereo dont turn on
Is it refusing to turn on or incapable? Did it ever work before? If not, check your power source.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
May 17, 2011 | Panasonic sa-ht930 Home Theater Audio...
I would like to connect my computer to my panasonic sa-ht800v unit and hear the sound thru the surround sound speakers
In general, your PC's sound card (and its controlling software) will determine what it can connect to.
Even the most basic PC would have stereo analog output via the typical green 1/8" connector or a headphone jack that easily adapts to RCA pair for analog audio connection. Any Line Level input EXCEPT PHONO would accept the PC's output. The output level would be controlled by the sound card software and settings.
The SA-HT800's single LINE Input would accept the Green stereo audio or speaker output from a standard PC, once adapted. Select VCR.
Find your PC's Sound Controls and enable the applicable input. make sure the volumes of both Inputs and Outputs are turned up.
Though not applicable to theGemini, more-advanced sound cards and audio hardware would have similar adaptable 5.1 or 7.1 (paired) analog outputs and / or digital audio outputs that conform to the s/pdif or Dolby Digital standards.
Mar 26, 2011 | Panasonic sa-ht800V Home Theater Audio...
My dvd stereo system panasonic model SA DK2 , F61 error,and immediately power down, comes on when turned on and then powers back off. please help
F61 usually means the amp has detected a short.
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Check for loose speaker connections as a root cause for intermittent shutdown.
Feb 21, 2011 | Panasonic sa-ht800V Home Theater Audio...
Error f-61 on SA-AK640
F61 Power Amp IC output abnormal
Upon power on,
PCONT=HIGH,
DCDET=L after checking
LSI.
For power.
Press [STOP] on main unit for
next error.
Aug 23, 2008 | Panasonic SC-AK640 Shelf System
My receiver for the Panasonic-SA-HT800V is toast
ebay? the speakers can only be used with this model..unless you strip the speaker wire...
May 06, 2008 | Panasonic sa-ht800V Home Theater Audio...
269 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
