Question about Kenmore 15864/15862 Top Load Washer
Kenmore washing machine 90 series
Water will not drian after washing cycle has completed
I took off the piece of rubber ring on the cover door. Now it's working
Posted on Sep 14, 2008
  • 3 Answers
Before you buy a pump, try the solution listed that says take off the rubber ring on the probe on the door. This lets it go in further. I actually ended up also putting a 1/4 inch extension on the probe so that it can activate the limit switch. With the unit stopped when it hits the drain cycle point, open the door and try pushing in the switch with a pencil. It should start up if the problem is a short probe.
Posted on May 11, 2009
Slow water drip on inside of washer
Posted on Sep 21, 2008
    Novelist:
    Champion:
  • 261 Answers
If not use pump 3363394 and tilt the machine back to expose the pump. Two clips hold the pump as well two hoses and clamps. From here it pulls off the motor and the new pump is installed. Please note position of clamps and clips to ensure a good repair, observe then repair. PS A&E is a Sears company geared for third party warrantees which makes them useful!
Posted on Sep 07, 2008
  • 639 Answers
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Sounds like a bad pump!
For this problem you will need to use factory service!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
Water wont stop draining when in wash cycle
In the front load washer is use the drain pump to drian out the water. so the water out tube (pipe) was hang up hihtger them to washer tube. your machines problem I thinh it is the drain out tube (pipe) was fall down lower them the washer tube.please correct it.
Jul 11, 2011 | Washing Machines
Washing machine won't drain completely or finish the rinse cycle
Hi the pump drian unit needs to be replaced, this solve your problem..
Jun 06, 2011 | Fisher and Paykel GWL11 Top Load Washer
Too much water after was is finished
your drain pump is probably clogged or the main drian hose is kinked
Jan 12, 2010 | Kenmore 44072 Front Load Washer
Dish washer fills and then drians without washing
If you're sure it is heating the water, then it sounds like the wash motor/pump has failed. If you've worked on washing machines and/or dish washers before, this is potentialy a DIY job - the Haynes Dishwasher manual is very good, and parts can be found on the internet.
The reason for cheking it is actually heating the water is that the symptoms sound very similar to those of a failed heater = fill, pause, empty, stop usually accompanied wth an error code. Error code will be presented by a number of flashes of a lamp, or a number on a display panle depending whch machine you've got.
Sep 12, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Wont go into spin cycle
will the drum go round when on a wash. and is it drianing water out if the drum goes round its not your brushes. if it not emptying water you pump as gone and will not spin if there is water in the drum
Jun 28, 2009 | Kenmore Washing Machines
Water not completely drianed after running, is this normal?
Hello. There should be no water left in the bottom at the end of the wash cycle. There are a few possible causes, the most common one being debris in the small pump that pumps the water out of the machine and into your sink drain, or debris in the hose vrom the dish washer to the sink, or a blockage where the dishwasher empties into your food disposal [if you have one installed].
May 31, 2009 | Kenmore 15762 Dishwasher
Washing machine clothes dry
Is the belt broke? Have you checked during the wash cycle if it is agitating.
Mar 28, 2009 | Washing Machines
LG WM1832CW water leaking
your valve is not closing or your cycle isn't reading correctly. there should have been a diagnostic read process that should have came with the machine. if not you may have to end up buying a new drian assembly
Jan 15, 2009 | LG WM-1832C Front Load Washer
Kenmore 15864/15862 Top Load Washer Logo
395 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
