Depending on the model, there are corner seals (kenmore are black) at the base of the door these can fail , Frigidaire, Galax, and Whirlpool/ Tappan use small plastic diverters that are semi clear.
If these are missing in the corners nearest the base of the door then this problem
will occur. Also if you are using regular dish detergent, it will oversuds. One last note,
if the dishwasher has not been used for a while due to handwashing on the disposal side
of the sink, the soap will make its way into the sump of the dishwasher and cause this
condition. Try using several pitchers of water and pumping out the water by rotating the
control knob till it pumps out to dilute the soap. Hope this helps.
Check
out these tips...they can help you figure out what is going wrong
with your refrigerator and why it is not cooling
Refrigerator
not Cooling
or Fridge not Cooling
How to Defrost Refrigerator Defrost
Timer Problem
Water
Running in refrigerator
from Freezer
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
