Question about Toshiba e740 Pocket PC
USB 1.0/1.1/2.0 support with USB cradle
How can I make e740 to install my USB 2.0 ThumbDrive or in this case the name is PenDrive?
    Master:
  • 903 Answers
I get a popup stating Unidentified USB Device and asks for name of the device.
Posted on Sep 08, 2005
SOURCE:
Video facebook
1) If you got the video from email, then it hv to be downloaded into your computer (c: drive) first. Once done, login into your FB acoount and upload it into FB.
2) IF it from pendrive/thumbdrive/external drive, then just connect it with your computer. Then you login into FB and upload it from pendrive/thumbdrive/external drive.
Aug 22, 2014 | Computers & Internet
Hello all, Hope everyone is fine. I have a kingston 4 GB pendrive. My system got shutdown while my pendrive is connect to it. Now this pendrive is not detecting on any systems. Can any one help me how to...
your pendrive might have been burned due to a surge.. I have experienced this but the problem was the USB drive itself, the technician who assembled the desktop interchanged the USB connections making it very destructive to plug in any USB device.
Kingston usually has warranty. Have it replaced on the nearest service center or at the very least have it repaired. I wouldnt recommend you opening it unless you wanted to see the real cause. If it smells burnt then chances are your data is lost or the thumbdrive wouldnt work.
If it can no longer be detected in any system and your warranty is out and if you're desperate to have it fixed, you can bring it to any cellular repair shop, have them open it and check for burns.. Hope they have a means of retrieving it.
Hope this provides any help,
levibit
Dec 14, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have 8gb kingston pendrive..and i set my pendrive drive name to 'myname'.i already used my pendrive 7.4gb.and got a lots important files..when i plug in the pendrive,it will automatic install driver...
yes your pendrive is attactked by a severe virus.......you need format it you can do only one thing click on format option or restart the pc then press f8 thenan stat windows setup when you reach the formatting option then only format that pendrive.............
Nov 27, 2010 | Computers & Internet
Hi, myself chetna i am having compaq laptop,and the problem is this: whenever i connect my pendrive, my system get hung-up, it stops working, then i abruptly turn off it, and then again start it, somebody...
HP Pavilion dv6000z Notebook
well what can that be , many things
pendrive (a usb port memory stick, and not real DRIVE?)
test it on other pc yet. why not? its failing test it.
many USB mem stick fail due to corrupted files on it.
(removing it incorrectly cause that)
what OS? , you posted with NO OS Stated, at all. XP?
all ports fail on this Laptop?
do other USB sticks fail....>? or USB keyboards, or mice?
the HP OS restore features started about year 2006
called the F11 recovery mode. (that?)
you said.
"but window formatting does not make it work,"
what does that mean, by what means? who done?
using what media or F11 magic key.?
I say the PC is XP? and we all know XP has Horrible
USB support, and NOW worse MS shut down XP servers
for the USB devices, (and more) so will hang when
doing PnP "plug and Pray" driver from there.
XP is DEAD, you do know that right? XP and VISTA are
now DEAD.
recap:
1: the Stick fails on all USB ports.
2: the stick fails in othe PCs
3: running XP and expecting things to work. HAHAHAHAAHAHAAHAHAH (the endless dream?)
my XP works on one PC, but I had to make sure I had all drivers perfect , from each chip maker,
MS and HP dont have them so takes hard work
4: is the Device manager in control panel clear of al errors"
this PC is 10 years old
HP retired it, official
XP is retired at HP and MS.
that PC came new with F11 magic recover key.
the HP manual (covers XP and VISTA )
is still there, will be deleted soon... hint hint..
http://h10032.www1.hp.com/ctg/Manual/c01035677.pdf
here is DM running and me clicking power tabs
on usb hubs
Sep 13, 2017 | HP Pavilion dv6000z Notebook
Booting with usb thumbdrive
it's very easy. all you need to do is insert the pendrive and then restart your computer. then follow the instructions...
Aug 01, 2009 | Computers & Internet
Pen drive not been detected by laptop.
try connecting it to a diff. usb port.
most likely problemis that the drife may have malfunctioned.
Mar 15, 2009 | Kingston 4GB Secure Digital High Capacity...
Pendrive write protection removing
Hey, the transcend pen drives usually have a small switch on the side of it, ie to turn the write protect on and off, usually a small lock symbol on it, the problem with unreadable files names etc, could be a corrupt partition, i would suggest formatting the drive as long as you aint got any important information on it,
All the best
John
Jul 27, 2008 | Computers & Internet
How i can make xp proff service pack 2 bootable pendrive, cd,sdcard
helo frind
1. Windows Xp installation disk
2. Access to PC with working CD Cd-ROM DVD drive.
3. This file solution.rar
This guide is for people with basic knowledge of PC hardware and system software
Let's start.
1. Download solution.rar file
2. Unpack solution.rar file on drive C, you should have a folder named C:\Dos
3. Put your pendrive ( at least 1GB) into working PC USB port
4. Go to the folder C:\Dos and run HpUSBformat.exe file
- it should auto detect wyour pendrive disk, if not select form the list ( my pendrive is a drive G: )
- set other options like on the image below and click start.
- now you have a pendrive with bootable dos on it.
5. Copy all other files from C:/Dos to your pendrive. ( you can overwrite existing ones)
- your pendrive should look like that
6. Put your Windows Xp installation disk into Cdrom and copy all files from CD to pendrive.
good_lk
Oct 12, 2007 | Microsoft Windows XP Professional With...
"Communications Error 608"
If you put the Toshiba Pocket PC e740 in your USB Cradle you may receive a "Communication Error 608". This is not a serious error, it is just a false setting in the ActiveSync Program. Please follow these steps below to correct this problem: "Tap" on start and choose the ActiveSync program Then "tap" on "Tools" and choose "Options" in the ActiveSync Program Check under "Enable synchronization when cradled using" to see if the setting is on "USB" If it is set on "Bluetooth", please change it to "USB". Now you can close the application window Important: Please remove the Pocket PC from the cradle and then return it to the cradle. This activates the new setting Important to note: This above described issue occurs if you "tap" accidently on the Bluetooth Icon in the Program Group or activate Bluetooth of any other reason, the ActiveSync Option will be set to "Bluetooth" instead of "USB". This setting will cause the "error 608" if you put in the Pocket PC e740 in the Cradle and start to synchronize over USB.
Sep 07, 2005 | Toshiba e310 Pocket PC
Backup and restore data
Section A - How to use a Toshiba Pocket PC e740 without loss of data: Never let the battery fully discharge. Never disconnect the battery from the e740. Regularly backup your stored data. Always connect the product to an external power source before changing the battery. Section B – How to backup your data: B1 – Using Activesync You can make a backup of the Toshiba Pocket PC e740 data to your notebook or desktop computer. If you have backed up your data to your notebook or desktop you can restore that data to your Toshiba Pocket PC e740. Periodical data backup is recommended. The following types of data can be backed up: FILE: Includes files created by Pocket Word, Pocket Excel, Notes etc. or an additionally installed program. REGISTRY: Setup information of Windows or programs. DATABASE: Database information from Pocket Outlook. When making a backup or restoring data please DO NOT remove the Pocket PC e740 from the USB cradle and DO NOT turn off the power to the device until the backup or restore is completed. Backup Instructions: Insert the Toshiba Pocket PC e740 into the USB cradle. A connection between the e740 and your notebook or desktop will be established. Please close all active applications on the e740. On your notebook or desktop start Activesync and select Tools and then Backup/Restore. Select Full Backup. Select Back Up Now to start the backup process. B2 – Using a Compact Flash (CF) or Secure Digital (SD) Memory Card: a) How to insert a Compact Flash Memory Card: Ensure the e740 is connected to the mains. Turn the e740 off. Remove the dummy card if necessary. Confirm the direction of the Compact Flash memory card by lining up the side grooves of the card and groove edge of the card slot. Insert the card smoothly and completely. b) How to insert a Secure Digital Card: Ensure the e740 is connected to the mains. Turn the e740 off. Remove the dummy card if necessary. Insert the Secure Digital card with it’s contact surface (the metal contacts) facing the back of Toshiba Pocket PC e740. Press the card down until it clicks. You can make a backup of the Toshiba Pocket PC e740 data to your Compact Flash or Secure Digital memory card. If you have backed up your data to your Compact Flash or Secure Digital memory card you can restore that data to your Toshiba Pocket PC e740. Periodical data backup is recommended. The following types of data can be backed up: FILE: Includes files created by Pocket Word, Pocket Excel, Notes etc. or an additionally installed program. REGISTRY: Setup information of Windows or programs. DATABASE: Database information from Pocket Outlook. When making a backup or restoring data using the DataBackup program please DO NOT remove the Compact Flash or Secure Digital card from the Pocket PC e740 and DO NOT turn off the power to the device until the backup or restore is completed. Backup Instr
Sep 07, 2005 | Toshiba e740 Pocket PC
Toshiba e740 Pocket PC Logo
120 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
