Question about Sanyo HT32744 32" TV
Sanyo 32 The TV is 3 years old, the picture started to go in and out, and over time is now out more than in. The sound is good and the picture is good when it decides to be available. Can someone assist me in what the trouble might be? Tom
  • propst56 Oct 16, 2008
    ok , solder where? Is this something that my husband can do? What is a cold solder? What do I need to do? Thanks
    Champion:
  • 252 Answers
Resolder your tv maybe it has a cold solder
Posted on Oct 16, 2008
    Problem Solver:
  • 11 Answers
I too had the same problem where my HT30744 TV would lose its color or picture. My mom's HT32744 would have the same problem too. They both are refurbished models bought at Value City Dept store. If I gave the cabinet a good hit it would mostly fix the color, but it could also make the picture go fuzzy too, a clear sign of just a loose connection somewhere.
So after my wife telling me she was sick of this almost 2 year problem and she was going to buy a new TV on the weekend, I figured I had nothing to lose. So I took the rear cabinet off, unseated the card mounted on the picture tube, applied a little dielectric grease on the connector on the card and reseated the card, removed, re-greased and reattached the card. I have had no problem with either my or mom's which I did the same to since! This is an easy fix that anyone can do. The hardest part is moving the TV and reassembling the rear cabinet. Do not pull the cabinet back out more than you have to, to ease the reassembly of it.
Posted on Mar 05, 2010
TV has audio but no video. Replaced LED driver but didn't fix it. What else could it be?
TV fuses go out like mines and can hear the cable but see no picture..
Apr 03, 2016 | Sanyo 32" LED HDTV DP32242
My Sanyo Flat Screen TV is dead. No Picture and No Sound. Model No. CE32LD08N-B
Year of model. it may be time to replace this if you have some age. Sanyo those are very good units but they are replaceable.
Nov 23, 2014 | Sanyo Televison & Video
No sound on t.v. but popping and crackling from speaker
Sanyo sets have a horrible track record, if the set is still under warranty return it. The problem could be in either the power supply or main board. It will have to be diagnosed properly to be sure.
Oct 22, 2012 | Sanyo DP32746 32 in. LCD Television
Sanyo TV LCD 32 inch about 3 years old. No
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
Jun 04, 2010 | Sanyo DP32746 32 in. LCD Television
No picture, no sound.
contact sanyo, sounds like your display panel has gone bad
Sep 08, 2009 | Sanyo DS31590 31" TV
Sanyo tv wont stay on
The problem of your TV is the power switch, and best solution for this is replacement with a good one.
Warning: The next procedure must be done by an expert to avoid risk.
1.Open the the back cover of the TV and detached the board.
2.Try to see any broken solder or cut PCB lay-out on the board.
3.Get a continuity check to the switch.If the switch is defective replace it with a good one.
Jul 13, 2009 | Sanyo HT32744 32" TV
25 inch sanyo tv
If the horizontal lines going through the picture are fine white lines, then I would suspect the picture tube as having a heater to cathode short or some other problem. Since some sets have had a 3 year warranty on the picture tube, you may be lucky unless the labor to replace the tube is more than the set is worth. Sanyo is usually not a good name in consumer electronics anymore, so if you're looking for a replacement I would look elsewhere.
Mar 31, 2008 | JVC AV-32F704 32" TV
No picture
Sounds like one of the CCFL's is failing.. (Backlight bulbs).. Some use multiples and others have singular.
Feb 29, 2008 | Sanyo DP32746 32 in. LCD Television
Sanyo DS31520- high pitched whine, picture is fine
sounds like bad solder connections on ground of the inputs radioshack has a cheep solred gun and solder make sure set is unpluged
Dec 03, 2006 | Sanyo DS31520 31" TV
Sanyo HT32744 32" TV Logo
215 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
