Question about Dryers
Roper dryer I have a Roper dryer that is about a year and a half old. I have only actually used it for 6 months out of the year and a half. It has been in storage for almost a year. We just moved and when we hooked the dryer up it ran for only a few seconds and then cuts itself off. We checked to see if the drum was turning and it is. However, after it cuts itself off it will not let you turn it back on for about a minute or so. When you do turn it on, it does the same thing. A couple of times we just shut the door to the dryer and it came on itself. Any suggestions?
  • 706 Answers
Based on your desription... one of the thermal sensors is overheating , tripping..shutting you down until it cools down enough to reset itself... then you can run it again.. and that process repeats.. You may have a defective thermal switch... Hope that helps...
Posted on Aug 29, 2008
My roper dryer is not giving off any heat. and everything else works just fine. The dryer is only 6 years old. I also just cleaned out the lint trap straight through.
You did not say if your dryer is gas or electric. So if your dryer is electric go check out this electric no heat tip...
and if you dryer is gas check out this gas no heat tip....
heatman101
Aug 27, 2010 | Roper Dryers
My Roper dryer was making a strange rattling noise for a couple months. Then it started not drying my clothes completely. Not it just won't start at all. Its only 3 years old...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 25, 2010 | Roper Dryers
We have brought home two new roper dryers now because neither one of them heats up. we hooked up a brand new 3 prong plug to the new dryers and plugged them into the existing 220 outlet that our old dryer...
You need to double check that your wiring it up correctly at the junction block on the machine. if thats correct. Most likley is that you actually only have 110 volts going to the machine it will run fine but will not HEAT. check voltage at plug or where its wired into back of unit you should have 110 volts on two out of three with the third being ground if you dont you have a bad outlet or breaker in elec.panel
Aug 08, 2010 | Roper REX4634KQ Electric Dryer
What would the value be of my used Roper REX3514PQ0 dryer?
Usually a little less than half of original price paid as new, on working appliances, that is. I would advertise the bad one as free, with the purchase of the running one. You should do well with these on craigs list.
Jun 20, 2010 | Dryers
My Roper elictric dryer is not drying clothes
If you are experiencing longer dry times and/or poor drying efficiency, the following link can give you some tihings to check before assuming there is a malfunction with your dryer:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes. Hopefully, this may save you a service call. If you check everything and still have poor heating issues, please let me know. You may have an internal bias or hi-limit thermostat malfunctioning.
Jan 05, 2010 | Roper RES7646KQ Electric Dryer
Siemens Condensor Dryer E46-38. After a few
Mine is 4 years old and the pump went within 8 months! The dryer has had 6 new pumps in total! It was last fixed 6 months ago and now playing up again! I dont even constantly use my dryer! I am very disappointed with Siemens now, my last dryer lasted me 10 years and it was constantly on the go when my children were young! Here comes, tomorrow I have got to book another repair! No more Siemens for me.
Oct 20, 2009 | Siemens Dryers
Roper dryer will not heat.
Friend,
ngfam1 At your service!
Sometimes this can happen when the vent line is clogged.
TRY THESE MEASURES!!!!!!!!
1. If the dryer is gas and old, the pilot could be out or if it is newer it could have a defective or worn out a igniter!
2. Check if the lint filter is full and needs to be cleaned.
Try this first.
3. Then check if the outside screen covering the exhaust vent is even half blocked with lint there will be no heat! This screen is to keep small animals out!
Try checking this second and if it is clogged or the spring loaded door is stuck closed try to clean the lint out of the corners of the flap door, and or remove the screen permanently!
I DID AND NO ANIMALS LIKE TO GET BURNT,IT'S HOT IN THAT TUBE!
2 years that mine is off and it's all is fine.
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 31, 2008 | Roper REX3614KW Electric Dryer
Dryer only runs 10 seconds then cuts off
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
It sounds like one of the wheels that the drum rolls on is hanging up !!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Aug 28, 2008 | Roper REX4634KQ Electric Dryer
Dryers Logo
55 people viewed this question
Top Dryers Experts
