Question about HP iPAQ hw6500 Pocket PC
Keylock How can I keylock for iPAQ hw6500? I hit the display all the time and it dials numbers... What am I doing wrong?
    Master:
  • 450 Answers
Hi, The Hw6500 dont have any keylock/display lock. thats why we released it with the hard plastic cover over the display, so you can have it against your ear without pressing the display all the time.
Posted on Sep 08, 2005
I have a Fisher Paykel 605 double DD. I have an F2 error message. There was a frozen rotor, likely from disuse over the winter. I replaced the rotor and it still stops and shows the F2 display. There
Not sure if you have fixed the F2 problem yet. The rotor cavity may look clean but sometimes there is a piece of bone or seed stuck inside the channel connecting rotor cavity with pump sump. Take the rotor out and the drain filter out. Take a rigid thin wire and run it inside the channel connecting the two.
Also get some white vinegar and with a tooth brush rub it inside the rotor cavity to ensure all dirt is removed. The rotor speed sensing is done by the hall sensor sitting underneath the cavity. It is not visible from top. The sensor could be reading incorrectly. IF still no luck then Run in diagnostic mode - (but make sure you do not try any other function than what is mentioned here otherwise you could damage dishwasher).
DishDrawer Diagnostics can
only be entered in Power Off mode, ie. When there is no display on the LCD or the
badge LED's are off. Diagnostics is entered by holding the
Keylock and Start/Pause buttons simultaneously for 5
seconds. Ensure that
Keylock is pushed first.
All LED's and LCD segments (except keylock) are illuminated. Press Power button and display shows HO in red background. Press Start/ Pause. You are now in hardware diagnostic mode. Open drawer so that you can see inside. Press Start/ Pause a few times until FU shows on display. At this point press Keylock and water should flow in. Press Keylock to turn inlet valve off after water is collected under the wash arm (don't cover wash arm). Press Start/ Pause again and P1 will display. Press Keylock to turn rotor motor on and water will swish around. Press Keylock to turn motor off within a few seconds otherwise flooding could occur. Next press Start/ Pause once so P2 displays. Press Keylock to run rotor again but this time it will pump out. Let it run until the water is pumped out. Press Keylock to stop pump. This should test the rotor in both forward and reverse direction.
PRESS POWER BUTTON ANYTIME TO EXIT DIAGNOSTIC
If the hardware test worked ok then turn mains power to dishwasher off and on and start normal wash cycle. If there is still an F2 problem then hall sensor is faulty and needs replacement. Not easy to do and best left to technicians. By the way each dishdrawer has separate controller - so one drawer could be working fine and the other not.
May 10, 2014 | Fisher and Paykel Dishwashers
I have a Palm Z222. I cannot deactivate the keylock, which makes it impossible for me to use the Palm. Regards, Renate
spacer.gif spacer.gif How to preserve battery charge by preventing your Palm handheld from accidentally turning on via keylock Your Palm handheld is equipped with the Keylock Activation feature to prevent the device from accidentally being turned on (while in your pocket for example) and thereby preserving the battery charge. To access the Keylock Activation settings, follow these steps:
  1. Turn on your Palm handheld
  2. Tap on the Preferences icon
  3. Tap on Keylock located in the General section
  4. Tap on either Automatic or Manual to activate the Keylock functions
Sep 01, 2008 | Computers & Internet
My Uniden walkie talkie keeps saying L very time I push a button
You've set the keylock feature on your walkie talkie. From the Uniden manual...
KEYLOCK
ON/OFF Press and hold the call/lock key until the "L" appears. After 1 second, the LCD will return to the channel display. To exit Keylock on mode, press and hold call/lock again. Note: While in keylock on mode, it will still receive transmissions.
Feb 10, 2014 | Uniden GMR-1035-2 2-Way Radio
Uniden walkie talkie says L every time I push a button
KEYLOCK
Feb 10, 2014 | Uniden Radio Communications
How can I test the lid actuator motors
you can go into diagnostic mode by pressing keylock and start buttons together for 3-5 secs in power off mode. Keep pressing start button a few times once all lights light up and you see LS on display. Press keylock to turn on and off the actuator motors.
Dec 18, 2010 | Fisher and Paykel 24 in. DS-603 Built-in...
My 99 Alero doesnt want to start it wont let me turn the key past the off position i have to jiggle the key to get it to sometimes start i also have to spray WD40 into the key hole and it works fine for...
THE KEYLOCK CYLINDER FAULTY NEED REPLACING.IT WILL GET TO A POINT WHERE KEY WONT TURN IGNITION SWITCH. TRY ANOTHER KEY IF KEYLOCK STILL NOT TURNING. MORE LIKELY KEYLOCK CYLINDER NEED REPLACING.
Dec 17, 2010 | 1999 Oldsmobile Alero
Leaking water from bottom draw
To put machine into test mode: Press and hold keylock, then press and hold start button. Hold both in until machine beeps (if you have display, it will show all symbols). Press power button- display should now show HO. Press start button until LD shows in display- this tests lid motors. Activate lid motors by pressing keylock button- if you open drawer about 3 inches, you should see lid come down. Pressing keylock again will raise lid. Raise and lower lid several times by pressing keylock button to ensure lid is working properly- if not, lid motors need replacing. Good luck!!
Mar 18, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
When i start my 300pl desk top system. when i
Hello my friend.That error message has nothing to do with the actual keyboard.The POST/BIOS is reading a single port bit in the system boards keyboard controller and detecting this bit as being shorted to ground. On some systems there is a keylock on the front of the case that allows you to "lock" the keyboard for security reasons. It is this lock that is being detected. On a system without a keylock, this error can be caused by one of the front panel wires being placed on the wrong pin on the system board. Or by something shorting out the keylock pin on the system board, or a hardware failure in the keyboard controller, or using the wrong version of BIOS.So make sure if your computer has a lock key/button or something on the case that locks the keyboard.Also you can load default bios settings by hitting Del while you boot if you have change anything in the bios.
Feb 08, 2010 | IBM 300PL (PC 300 PL 733) PC Desktop
Palm Tungsten E2 is password protected (keylock activated), but I cannot enter password with stylus. Asterisks, wrong numbers, or periods appear instead of the correct code.
Palm has a button that will give you a graphical keyboard. Usually in the lower right of either the display, or the pen area.
Aug 01, 2008 | RIM BlackBerry Pearl 8100
How do you turn off keylock
Power off your display monitor then hold down the down arrow key on the monitor at the same time you power on the monitor. This should unlock the monitor keylock alshsh@epix.net
Mar 20, 2007 | Kogi L7CH Monitor
HP iPAQ hw6500 Pocket PC Logo
97 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
