Question about Admiral AW22 Top Load Washer
Spin problem On all cycles, the first spin cycle works, but the last spin does not work. Any suggestions?
  • 639 Answers
Dear Friend,
ngfam1 here for you!
I am happy to be of assistance!
This problem is electronic and requires factory service.
when you buy your next appliance shop quality and not price and you will have the appliance for 15 years with out incident!
admiral is from Home Dept! Good for paint and hardware!
Appliances form an appliance store will be better!
Live and learn!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. Please give me a good rating here in fixya.com before you sign out!
Posted on Aug 28, 2008
My washer wont go into spin cycle. I hear a clicking sound coming from the timer. It still wont work. What could it be? Any more suggestions, Huseyin?
if it is not progressing to the spin cycle it could be the controller is faulty
I suggest an technician call to get the proper diagnosis for the problem
Jun 22, 2015 | Washing Machines
Doesn't dry clothes in spin cycle- spins but not enough
so it is the spin cycle that does not work that is the drum does not turn. Have you tried other levels such as delicate wash and see if spin works. LASTLY, disconnect power and reconnect.
Mar 03, 2014 | Frigidaire ATF6000ES Front Load Washer
Machine runs wash cycle but fails to drain and spin. When door unlocks I remove and replace wet washing then switch on rinse and spin cycle. This seems to work but is no long term answer.
Hi, The washer will fail to spin if there is too much water in the machine, check the filter on the machine is not clogged or blocked if it's not then the pump could be suspect, normally you can hear it running on the spin cycle. it could also be the motor brushes are worn.
if its none of the above I would suggest that it maybe the pressure switch or pressure switch tube blocked other than that the last resort is the programmer or motor control panel.
Hope this helps.
Feb 09, 2011 | Hotpoint Aquarius WD63 Front Load...
My final spin cycle is not working on any wash
TIMER!!! Last cam in your timer has a loose set screw or is broken. Don't try to fix it, it won't last. Buy a timer.
Mar 09, 2010 | Washing Machines
My perfoma washer is not working on the last Spin CYCLE
timer bad as far as balance is unit level on flat surface
Jan 18, 2010 | Washing Machines
Kenmore washing machine didn't spin @ end of cycle
If you tried a different cycle and it worked this means that the timer is probably bad on the main cycle that you use. If the machine does not spin on all cycles, then please check out the LID SWITCH.
Nov 12, 2009 | Washing Machines
Kenmore Model 110.23832100 spin cycle works intermittently
This appears the timer is at fault. But check the motor controller too.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 17, 2009 | Kenmore Washing Machines
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Have to hand start the last spin cycle
sounds like carbon brushes in the motor are not making perfect contact,take out inspect,clean or replace clean up commutator
Nov 01, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Admiral AW22 Top Load Washer Logo
121 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
