Question about Sewing Machines
My singer athena 2000 won't pull the bottom thread up to form a stitch. I know this is an OLD machine and I couldn't find the right selection from the list My Singer Athena 2000 sewing machine was working fine until today. Everything is working fine except it will not pick up the bobbin thread or wind a bobbin. I dusted the bobbin case, changed needles, bobbins and thread several times but to no avail. Please help!
  • pinkle Aug 29, 2008
    As I stated, everything is working fine except it will not pick up the thread. The hook moves, the needle moves, no buzzing, etc. I am leaning toward the timing being off. If I turn the hand wheel manually, I can see that the needle seems to move out of the way just a tab bit too early. Any advice? Thank You
Yes, the hook timing is off. You need to either take it to a service repair center, or do the timing yourself. If you're mechanically inclined, go to youtube and look for a video by Nilsandkatrina about how to repair your sewing machine. He gives a very good example.
Posted on Nov 29, 2011
  • 323 Answers
I think if you watch the hook as you turn the wheel you will see that it is not moving.If it's not moving it can't pick up the thread or sew or wind the bobbin. If you really like this machine you can take it to a technician who is going to tell you you have a broken gear.Always have them replaced in pairs. On this machine there are 2 gears( 1 Pair) on the left and 2 gears( 1 Pair) on the right. If the machine is making buzzing noises, replace the machine instead of the gears. Singer makes a nice machine which sells for around $300 which will do more than the one you have and it is easier to use. Look at Model 7467. I sell quite a few of these and they don't give me or my customers problems.
sewman7
Posted on Aug 29, 2008
  • John Free Aug 29, 2008
    If everything is moving and the needle is moving a little early then the timing is off. It's time to consult a technician.You can try lowering the needle 1/16 inch or so to see if it will work temporarily
    ( to complete a job ) but it will still need to be adjusted.
    sewman7
Singer ahtena 2000 won!t run motor want to start ao trys what is the problem?
Posted on Jul 14, 2010
2 Suggested Answers
  • 10865 Answers
SOURCE: How do I fill a bobbin on a Singer 2000 Athena
http://www.singerco.com/accessories/manuals.html
go to this site to obtain the manual.
please mark this answer as a fixya!
Posted on Feb 27, 2009
My singer (1962 Model) does not make a stitch just not sewing.
When this machines don't stitch right is usually the sequence of the thread, are you expert? Are you certain that the thread is ran through the steps correctly? Also the bottom coil has to be inserted right.
Feb 12, 2017 | Singer Sewing Machines
How do i thread the bobbin on a singer athena 1200 sewing machine
The Athena 1200 and 2000 are "Touch and Sew" slant needle machines. Singer has not made them for many years, but I always loved them, because the bobbin is wound in place--you don't take it out! You can still get a full assortment of presser feet for them; just make sure they're for slant needle machines.
You would be wise to visit the Singer Sewing Machine site and download your user's manual--it's free, and it will show you how to wind the bobbin. There are a series of pictures there as well. There are several steps you need to take, such as raising the presser foot, selecting the blind hem stitch, etc. Sounds complicated, but I owned an Athena 1200, and I can tell you that after the first or second try, you'll find it quite easy.
Incidentally, did you know that it's one of those rare machines that will do a TRUE 1/2" basting stitch! I kept it for years, just for that ability!
Feb 20, 2015 | Singer Sewing Machines
How do I thread a Singer Athena 2000?
The user's manual for the Singer Athena 2000 is a free download from the Singer Sewing Machine site. It will show you how to thread your machine properly. A heads-up, though--the presser foot MUST be UP when you thread ANY machine from ANY manufacturer, going back at least a century!
Jun 21, 2014 | Singer Sewing Machines
Singer 756u stitches not catching
So this is a serger? Might have been nice to know that. Make sure you have threaded your serger in the correct order. upper looper, lower looper, needles from right to left.
Make sure you do this with the presser foot lever in the UP position. Make sure all the threads are pulled fully into any tension guides.
Sep 01, 2012 | Singer Sewing Machines
My top stich is tight,but bottom is loose of my singer sewing machine.
Think in opposites... the top stitch is formed by the bottom thread tension and the bottom of the stitch by the top. So either the bobbin thread is too tight or the top thread is too loose. Check the bobbin thread first as that is the one most overlook. It should come out of the bobbin without having to yank it hard but it should have a little resistance.
Mar 22, 2011 | SINGER 7470 Sewing Machine
Singer Athena 2000 won't zig zag
Did you switch the metal plate to one of the ones that won't allow left/right movement by any chance?
If the wrong plate it in -The machine somehow figures out that the plate won't allow the needle to move in the left/right directions and only does a straight stitch or funky other stitches.
Jun 08, 2009 | Singer Sewing Machines
CONSEW 206RB5 TOP THREAD NOT FORMING STITCHES AND BREAKING
you have your thread tension too tight that's why it is pulling the bottom stitch all the way through it looks good from the bottom but not good on top. Its pulled the stitch all the way through the material.
I had my own upholstery shop 18 yrs and tension gets you every time.Just loosen the top tension.
Jan 18, 2009 | Euro-Pro 8260 Mechanical Sewing Machine
I have a Singer Featherweight 221-1 that won't form a stitch
The needle goes in with the flat side on the left and you thread it from right to left ,hope this helps
Jan 10, 2009 | Singer Featherweight II 117
Singer 3116
Rewatch your dvd that came with your machine. If, you do not have that, read the manual. Sometimes you have the thread feeding the wrong way, make sure that it unwinds toward you. Also, check your needle, change if necessary. Make sure the flat side faces the rear of the machine and is inserted all the way up.
Sep 05, 2008 | Singer 3116 Simple
Im pretty sure i have my singer 5525 threaded right but i think the bobbin is wrong but when i try to sew the top looks fine but the bottom is a thread mess an the thread keeps breaking
angle the bottom might be a mess but it is the top thread that
you see balled up .Pull the top thread and make sure there is tension on it ,if not check the thread is between the discs and there is nothing else between them .if this is ok there is something stopping the top thread from being pulled back up
through the needle plate to form a good stitch,if you can turn by hand and watch where it is catching you might be able to solve it.
Aug 17, 2008 | Singer 7462 Mechanical Sewing Machine
Sewing Machines Logo
1,540 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
