Question about HP iPAQ hx2410 Pocket PC
HX2410 won't start , have to reset every morning
I have had this unit 2 days and every morning or after leaving for a few hours it will not start, push buttons tap screen but have to reset to start, first time every had to be reloaded, next all was still there. HELP
    Master:
  • 450 Answers
To my experience, tehre's some evidence this occurs when th device is sort of locked up for too many alarms/notifications being prompted while the device is shut off. This may cause a shortage of memory, for which soft resetting is the only way out. Anyway, as long as you don't drain your battery out, it should NOT cause a hard reset (which would imply losing data and third-party software). Bye
Posted on Sep 08, 2005
Why is ice maker loud when filling tray and water flow slows down?
perhaps you need to leave it turned on all the time . thry were not made to be run as a part time unit .
Apr 04, 2016 | Refrigerators
Bosch Dishwasher drain mechanism starts itself a few hours after a completed cycle and won't stop. I reset the dishwasher, but it remains unusable for a few days. If I turn on the dishwasher, th
this could mean there is water leak and it collects at the base of the dishwasher leading to moisture detection circuit tripping. when you leave it for a few days the water dries up and trip is removed. check door seals for leak most likely at the base of the door. turn power off when working on dishwasher.
Jul 18, 2012 | Bosch Dishwashers
I have a Volvo s60 52 2.4 diesel won't start when
hard starting in cold weather for a diesel is a sign of problem injectors or battery not full charged
take it to a specialist diesel shop for a diagnosis of the problem
Feb 10, 2018 | 2002 Volvo S60
Unit stoped working and found filter was full of dust and fins on cooler was also dust cloged.I cleaned both and still won't start up
hi.
if the cooling fins blocked, it is quite possible that the unit has overheated and tripped the thermal fuse in the motor.
thermal fuse are built in to the motor to prevent overheating. some thermal fuses blow and the entire motor needs to be replaced, while others will reset themselves when the motor cools down.
as the fuse is in the centre of the motor they cannot be replaced and can take quite a few hours to cool down and reset themselves.
the only thing you can do is to leave the vacuum overnight and try it the following day to see if the thermal fuse has reset itself.
if the unit still does not work then you may have to get the motor replaced.
hope this helps
Jul 13, 2011 | Vacuums
My 305 unit will not turn on. It has been sitting on the charger for 3 days..Is there a reset option? It is only 2 months old, but is a refurbished unit. It was working fine the last time it was used.
try pressing the mode and power buttons together although you may lose your data, if this does not work leave it off the charger for a few hours and then try to start it,, this happened to my olde 305 and after leaving it overnight it started again....they are sometimes tricky
Sep 12, 2009 | Garmin Edge 305 HRM kit
When i reinstall the Bios on my Ipaq Hx2410 is fail.
I think you've know already (as an experienced technician) that opening h/w case won't solve anything..
The normal BIOS write is about 20 min (or more), longer than that it could be a problem with ActiveSync or your PC connections.
I'm afraid the ROM chip cannot re-restore because flashing basically format and write your BiosRom chip. Just pray that doing "hard reset" will turn your 'tiny' IpaQ to come alive.
Mar 30, 2009 | HP iPAQ hx2410 Pocket PC
Start up problems
I had the same problem few years ago with my 3950
I kept it on the charger and it just kept doing that, and finaly died totaly.
I send it to repairs and found out it was a motherboard / chipset problem and the motherboard would need to be replaced.
Mar 01, 2008 | HP iPAQ hx2410 Pocket PC
Bluetooth after ROM-Udate
I had contact to helpdesk: I made again an hard-reset, and now i can use the Bluetoth again with no problem. Now i have only one Icon for bluetooth and wireless on the desktop. Bevor i had also two Icons. The helpdesk said, that at running the Rom-Update you have to shot down firewall and virus-software on your maschine. Then make a hard-reset and run the rom-update again.
Sep 11, 2005 | HP iPAQ hx2410 Pocket PC
HP iPAQ hx2410 Pocket PC Logo
90 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
