Little cold air blowing out of vents. Pipes outside house not frozen over. There is water in the drain pan in the garage, and a small drip. Is this a serious problem, or fixable?
  • 1,543 Answers
Change your filter. Use a cheap filter when running AC so you will get enough air flow over the cooling coils. Old filters or the Filtrete / allergen type filters will not allow enough air flow, and will cause the coils to freeze over. Shutting the unit off for awhile will be necessary to thaw the coils also.
Posted on Aug 28, 2008
  • 639 Answers
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
You need service to make a proper diagnoses.
It can be many things!
For this problem you will need to use factory service!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Why water under crisper ..Frigidaire top freezer
You have a frozen or stopped up condensation drain line. Disassemble freezer to access evap coil and defrost ice in drip pan and drain line. You probably should replace the thermostat(cold control) if it hadn't been set to the coldest setting or if the fridge hadn't been opened for a long period of time prior to this problem. If the drip pan and drain aren't frozen then blow out the drain line with hi pressure air
Jul 23, 2015 | Refrigerators
Ac unit isn't blowing
It sounds like your freezing up at the coil, which in turn, blocks airflow across coil and only a small amount of air comes out of the vents. This also explains the cold air coming from fan on the outside unit, since the system cannot absorb the heat from the inside of the house through the coil. Your air outside is usually blowing out warm to hot air because thats the heat it rejects out of your system. I would turn the thermostat to "OFF" and turn just the fan setting to "ON" instead of Auto, this thaws the system out faster. Give it time to fully thaw, make sure filters are clean, and check airflow. If airflow is back to normal, your problem is more than likely the charge of refrigerant. If you have to call a technician out, make sure the unit is not frozen at all before they get there, they would not be able to do anything with the system froze. Hope this helps and good luck!
Jun 18, 2012 | Heating & Cooling
Every summer for the past two years I have the same problem. The condensation is so much that is not draining outside, but falling into the drip pan inside the house. I se moisture on the outside unit, but...
What we use is compressed air, either nitrogen and fittings or we use a small CO2 gun that you can pick up at local supply houses and some home improvement stores. You may have to cut into the condensate drain at the coil to blow through. It should be 3/4 in. PVC, and hopefully not copper since that would have to be soldered back. Some systems have a blow out somewhere on the drain line which helps. The only other problem would be the drain pan under the coil is also clogged, then you would have to open the coil case and try to unclog it from inside. Any kind of compressed air with some kind of fitting that seals the line when you blow through will work great. Hope this helps and good luck!
Jul 02, 2011 | Goodman CKL42AR42 Air Conditioner
Water leaking out of hose on a fujitysu split system ast24rga
Normally, an Air Conditioner removes water from the air and that water condenses on the coils of the inside section that does the cooling. The water condenses on the cooling coils just like moisture condenses on the outside of a glass of ice water.
This excess water drains out of the cooling section through a "drip tube" and is supposed to drain outside of the house, or a drainage system. Your "drip tube" has either not been installed (if it is a brand new installation), has separated and water is now dripping into the house instead of outside of it. Or it is clogged. This happens when algae builds up inside the "drip pan". If that is the case, you can purchase "algaecide" tablets which kill the algae that is clogging the drip pan and preventing water from draining out through the drip tube. These tablets can be found in many hardware stores, refrigeration supply companies, or even Walmart. You can put a tablet inside the pan. (You will have to remove the cover of the unit). You can often use a little bit of Bleach and that will act as an algaecide. Hope this helps,
Best, Mark
Dec 26, 2010 | Fujitsu Heating & Cooling
We live in an apartment complex and have a Trane Air Conditioner, each unit has its own central air. I believe the one in our unit has clogged drain pipes, when we first moved in we didnt change the air...
Hello You have to cut the pipe and blow out each end,You can use a 1"rubber hose from an auto parts store & 2 hose clamps, If you can't find the end.This will allow access in the future to clean out the pipes.It will slip over 3/4" PVC pipe.They sell a PVC pipe cutter but a hacksaw blade works well.Get ready for all the water in the pan once you cut!
Sep 14, 2010 | Heating & Cooling
Mr. Slim is dripping from movable doors.
Try to get at the drain hose from outside. It sounds gross but try to blow some air int the drain hose. Do not blow to hard but hard enough to tell if the hose is clogged or not. If the hose is not plugged hou may have to tear into the unit a bit. The drain hose is either on the left or right hand side of the unit. You should be able to take out the filters in the unit to see down in the drain pan. It is under the coil and you should be able to see water in it. It may be better to have a technician come over and tear into the unit to get the drain pan out and cleaned. Sometimes if water gets trapped in the drain pan it will slime up and cause it not to drain properly. They do sell a tablet that you can use in the drain pan to treat the water to keep it from sliming up and getting moldy. We sell the bottle of 100 tablets for around 25 dollars. Your local HVAC Wholesaler or contractor should have these on hand. Let me know how it goes.
Jun 06, 2010 | Mitsubishi MS-A12WA Air Conditioner
Water droping
Your drain pan is not draining. Use a wet vac to **** the drain line from the outside. This will pull out the blockage and you're back in business. Do not blow compressed air into the drain. This pushes the blockage back up into the drain pan.
Oct 02, 2009 | Friedrich M18YE Air Conditioner
I have central a/c. The drains in the air vent in my house instead of outside. How do I find the drain pan?
If your air handler is up in the atic - you will fins the drain pan up there under the air handler and you will need to clean out the water drains that are probably clogged..
Also find the drain exit pipe out side and duct tape a shop vac to it and suk out the dirt and debris..
Once a year - bleach water should be put into the drain pipes to avoid clogging..
I hope this helps !
Aug 19, 2009 | Heating & Cooling
Amana AP095R Portable Air Conditioner is dripping water constantly. It didn't use to do this. What's wrong here?
all air conditioners condense water .. the water is normally drained to the outside thru a hole near the outside bottom of the unit .. the unit has to be mounted so that it doesnt tilt inward .. the drain hole has to be cleaned once in a while ... if its clogged or if the unit is tilted inward then the water will drain inside the house .. less likely but possible is a cracked or damaged drip pan inside the unit ... thats a shallow pan under the condenser (cold) coil that captures the water and directs it toward the outside drain .. so check the tilt and clean the drain
Aug 17, 2009 | Heating & Cooling
Water dripping into refrigerator from cooling area
Your defrost drain in the freezer is frozen closed.
Turn the fridge off.
Remove the rear freezer panel.
Remove the visible ice.
Use a hair dryer to thaw the drain hole in the back of the freezer in the center of the drain trough.
Mar 12, 2009 | Refrigerators
Heating & Cooling Logo
78 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
