Question about Dell A960 All-In-One InkJet Printer
Printing problem Instruction window reads black cartridge missing, but it isn't. Sometimes prints a little and then black fades almost completely.When starting printing, it shows that we have ink.
  • 73 Answers
Take out the cartridge and see if the contacts on the both the printer and the cartridge are clean. Sometimes old unused cartridges dry up. Maybe it's gunky. Go to Properties, Printing Preferences, and see if there is a tab that says Maintenance. If you are going to throw the cartridge anyway, open the label on the top and add a few drops of water. Let it sit for a while.
Posted on Aug 28, 2008
Where is the ink cartridge located in the printer
Replace print cartridges that show any of the following symptoms:
  • Print is faded, is missing, or has missing streaks.
  • Printed colors are different than expected. This usually occurs when one or more ink colors are empty.
  • Print cartridge error messages that cannot be resolved appear on the front panel display.
    Read More....Replacing the Print Cartridges and HP Printer Support
    Thanks.
Jul 15, 2014 | HP OfficeJet 6110 All-In-One InkJet...
Im trying to print a black and white document but it wont let me print because my color cartridge is missing
The Lexmark X2600 requires both cartridges to have ink in them to continue printing, even if your printing in "black and white". To print true black, you actually use some of the color ink. , Leaving the color cartridge empty or dry isn't good for the printer. It can lead to poor print quality issues.
Sep 22, 2011 | Lexmark X2600 InkJet Printer
Printer wont print black, it only prints in color, also the printing fades
printing in black
* change the properties of your printer --->> Printer icon-->>Properties-->> select color or black and white grayscale.
fading print
*clean the cartridge printhead through the computer or manually (remove cartridge and wipe with cotton cloth with water). Also, clean the scanner window (glass).
http://printerquickfix.blogspot.com/
Jul 19, 2011 | HP DeskJet 842c InkJet Printer
Black print is faded on my HP deskjet 6980 printer. Whenever I print a word document it will have sporadic fading. It will be fine in one place then all faded in another. I've cleaned the cartridges and...
Here are some steps you can check to resolve your issue.
Check if the ink cartridges are low, specially the color black since if the black is empty, you are using the colored cartridges to print black. If the cartridges are newly replaced check the cartridges by reseating it. Try to consider changing the print quality high but doing so will use more ink. If still the same try to clean your printer heads.
Here are the instruction for cleaning your printer.
Open the printer tool box. (open a word, then click on file then print, choose properties, then services)
click on clean the print cartridges, then clean. Do test printing as well to check if the color is correct. If still the same calibrate the color which can be found in the same menu.
For more information here is the link for step by step instruction with visuals.
Hope this will help you resolve the problem.
Thank you for choosing fixya
Mar 03, 2011 | HP Deskjet 6980 InkJet Photo Printer
How to check the ink level onC4480 printer
To check the ink levels from the HP Photosmart Software
1. In the HP Solution Center, click Settings, point to Print Settings, and then click Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Features tab, and then click the Printer Services button.
The Printer Toolbox appears.
2. Click the Estimated Ink Level tab.
The estimated ink levels for the print cartridges appear.
Or
Print a self-test report
1. Load A4 unused plain white paper into the input tray.
2. Press and hold the Cancel button and then press the Start Copy Color button.
The product prints a self-test report, which might indicate the source of the printing problem.
3. Make sure the test patterns show a complete grid and the thick color lines are complete.
• If more than a few lines in a pattern are broken, this might indicate a problem with the nozzles. You might need to clean the print cartridges.
• If the black line is missing, faded, streaked, or shows lines, this might indicate a problem with the black or photo print cartridge in the right slot.
• If any of the color lines are missing, faded, streaked, or show lines, this might indicate a problem with the tri-color print cartridge in the left slot.
Nov 30, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Cartridge Error 50C consult user guide. I
Error messages; Error: "Cartridge Error 50C"; Cartridge error; Black cartridge missing; Color cartridge missing Solution Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Nov 10, 2009 | Lexmark X6170 All-In-One InkJet Printer
My printer won't complete the cartridge alignment function. It only prints the first two bars and then stops. When printing the black cartridge looks faded and half printed lines across even though it is a...
My printer does the same thing. I changed the blank ink yesterday (the printer shows the black ink was low) however after trying and trying and not being able to complete the alignment I decided to change the color ink as well.
It worked. Printer works fine now. Sometimes the ink dries up and you have to change it even though you know it should last longer.
Give it a try and let me know.
laura@theprincessandthepup.com
Sep 12, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP 5610 - printing fades down the page
the printer carriage might be wearing out, it happens on the 5610's, may be time for a new printer. The fading issue sounds like a cartridge issue. Try a oem?
Nov 14, 2008 | HP Officejet 5610 All-In-One InkJet...
Continually says align print cartridges
My guess is that the color cartridge is either defective or not inserted correctly. I have a 6110 and know that inserting a print cartridge is a little tricky. If it isn't completely inserted and the top latch fastened correctly, the cartridge either won't work or produce errors.
Try reseating the color cartridge so it's inserted in exactly the same way as the black cartridge and run a print job again.
Open the following web page and go to Step three to see the instructions for cleaning the electronic contacts on the cartridge and print carriage.
Ink Cartridge Alignment Fails
Those seem the most likely causes and solutions to me. Good luck.
Oct 29, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Dell A960 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
