Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Oven door locked
My oven door  is locked and I can't close it, release it or use the oven. HELP!
  • 639 Answers
Dear Friend,
ngfam1 here for you!
I am happy to be of assistance!
For this matter you will need to call factory service!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. Please give me a good rating here in fixya.com before you sign out!
Posted on Aug 28, 2008
E1 F5Error on Whirlpool wall oven.
The main control and door latch are not talking to each other without testing impossible to say which one on the latch assembly there are micro switches which have contacts that are open or closed depending on latch position this tells the control the position when you power up the door locks the unlocks try a latch assembly first
Jan 13, 2015 | Whirlpool RBS245PRT 24-inch Single Wall...
The oven door is "locked" on my Kenmore slide in electric oven. There is a button on the display that says "oven lockout" that was evidently pushed, but now I can't open my oven. How do I unlock the oven...
Sorry but I don't know much about the Kenmore however, I would suggest that it has some sort of Child Proof locking mechanism to stop kids from putting their hands in a hot oven. Some ovens automatically lock once they start to heat up, some can be locked all the time. Perhaps on yours, like some other brands, 1 or more buttons need to be pressed at the same time on the control panel to release the lock? Have a look in your manual or look closely at the control panel itself, it may say press this/ hold that, whatever, to release the lock.
Feb 22, 2014 | YouTube Videos
Rc17 commercial microwave, display shows door even when door is closed.what can i do to resolve
Possible that the door lock switch is stuck and so is not releasing even after the door has opened. Look inside after disconnection of power to the microwave at the place where the door locks. Tap into the lock to release the switch . If the switch is jammed or damaged it must be taken out and replaced.
Mar 31, 2011 | Amana RC17 Microwave Oven
How do I remove the oven door
Welcome to FixYa.
Most if not all Thermador owners manuals have this outlined in them, however, here you go.
Removing the Oven Door
  • Fully open the oven door.
  • Raise the U-clip over the hook on each of the hinges to the "locked" position (see illustration below). This will prevent the hinge from snapping closed when the door is removed.
  • Grasp the door by the sides toward the back. Raise the front of the door several inches (there will be some spring resistance to overcome because of the hinge being locked). When the front of the door is high enough, you will be able to lift the hinges to clear the indents.
  • Pull the hinges out of the slots in the oven front frame.
To Replace the Oven Door
  • Grasp the sides of the door at the center and insert the ends of the hinges into the slots in the oven front frame as far as they will go (see illustration below).
  • With the door open all the way, lower the two locking clips.
  • Raise the oven door and make sure that it fits evenly with the front sides.
DOOR HINGE WARNING:
**CAUTION** With the door off, never release the levers and try to close the hinges. Without the weight of the door, the powerful springs will snap the hinges closed with great force.
Let me know how you make out or if anything is unclear. Thanks for choosing FixYa.
Good Luck,
Macmarkus :)
Sep 01, 2010 | Thermador SMW272 Electric Double Oven
The lock on self cleaning oven door will not release
Once the cleaning button on the oven is pressed it take 15 minutes for the uven door to unlock.
Jul 30, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven locked so I can't shut door/operate oven
Thanks a million, solved the problem like a charm. For those that can't find it, it is on the left side orf the OVEN, not the stove. Once you open the door, you'll find it on the frame's upper left side corner, can't miss it. Good luck
Oct 27, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Lock won't disengage
Try putting it into CLEAN MODE and wait about 3 minutes.... then cancel the clean mode. Sometimes this will release the relay if its stuck.
If that doesn't work, you have a problem with the latch relay and you need service on the unit. You can try and remove the latch assembly yourself, but it can be tricky, and you may create more problems than you fix.
Jul 19, 2008 | Ovens
Jenn air oven stuck closed after attempt to activate self-cleaning
The lock motor may have failed. Most often, bending a coat hanger into a hook and sliding from the right side as you move the door to the right,will allow you to release the lock and open the door.
Jun 09, 2008 | Jenn-Air JJW8130D Electric Single Oven
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
50 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
