Question about Toshiba e740 Pocket PC
Memory loss/reset
I have a reconditioned Toshiba e740 (Windows 2002). It worked great for a while, but recently it keeps going back to factory settings. At first it just seemed happen whenever I took it out of the cradle, but now it happens all the time and I cannot even get the backup reloaded before it will reset itself and I will have to go through the whole setup process again (although I have not tried leaving it in the cradle and resetting it there recently). Can anyone suggest what the problem is and how I can fix it?
If prior posters are correct that it is the internal battery (not the easily replacable, removable one, but the one which is supposed to save your data long enough to swap "external" batteries), and that the internal battery _is_ the ML 1220, it should be an cheap fix. That sounds like a logical cause and which is a problem I've had on other electronics and repaired quite easily that way, including CMOS batteries on a number of desktop PCs and some smaller cheaper gadgets. In any case, assuming the internal battery dying is the problem and that the ML 1220 is the replacement part, then it is available at PcHub.com, impactcomputers.com and other suppliers. They show varying prices and makers, but include details on voltage, resistance, and other specifications. They also show them as being in stock. My understanding is that with batteries as long as the amperage, voltage, resistance, and such are the same, they are generally interchangable. I could be mistaken, and if so, I hope someone will correct me. I hesitated to be overly confident, since I just did a quick google search and turned up those results.
http://www.google.com/search?q=ML1220&rls=com.microsoft:en-us:IE-SearchBox&ie=UTF-8&oe=UTF-8&sourceid=ie7&rlz=1I7HPID
Posted on Apr 03, 2009
    Master:
  • 903 Answers
Have a suspicion that this whole issue revolves around the fact that the E740 uses a ML1220 coin-type lithium manganese dioxide rechargeable battery which is a 3V battery using specially treated manganese dioxide for the positive material, a lithium-aluminum compound for the negative material, and a specially formulated organic electrolyte. This is found under the left lower cover set on it's edge and like a home PC is I believe the CMOS battery which is rated at 1,000 cycles of discharging to 10% of nominal capacity (Depth of discharge = 10%). The total discharge capacity is quite high at 100 times nominal capacity. Supplies a nominal capacity of about 95% even when stored at 20 deg. C for roughly five years according to accelerated test conducted by Maxell). And since organic electrolyte is used, the battery has superior leakage resistance (shipped fully charged). I have the same issue with my unit and decided to open it up and find out about this battery. I am almost certain that this battery is no longer holding a charge and therefore always crashing an resetting. I have had the same experience with my old Handspring unit as well as an old PC. I would appreciate hearing from Toshiba or anyone else where one can acquire a replacement ML1220 as it is only supplied to manufacturers and not consumers.
Posted on Sep 08, 2005
  • oldfergie Feb 13, 2011
    I was just wondering if you found out anything about the internal batery? I hadn't used my pocket Pc for a couple years because I was having a lot of trouble syncing it to the new computer I had purchased and was experiencing the reset and power loss problems. I found the necessary drivers and updates but was never able to get it to work. I just recently found it in a box after we had moved and was actually able to sync it to the computer, however, within a day it was starting to reset on me and now as soon as I turn it on it shuts off again. Anyways I was sure if you had found out anything. Thank you
    Master:
  • 903 Answers
I am not sure about that but if there is no power supplies the data will be lose. Try to contact service partner and I am sure that they can give you more precise information about this issue.
    Master:
  • 903 Answers
As far as I know this can happen if the PDA lose the power supply
Have toshiba pda/e740, have no drivers for pc
Try going to the website of your Operating System (ie, Windows, Mac, ect). I've only used Windows , butsee if you can download the Activesync software that you need there. The e740 was only available with Windows Pocket PC 2002, and will appearantly not sync to Vista PCs, however.
I will try to check back in a day or two, so let me know if this is of any help to you.
Apr 01, 2009 | Toshiba e740 Pocket PC
Toshiba E740 Power Problem
Hi, I noticed that the firmware that you have is not the latest, the last provided was 1.0623.049 which was released a few years ago. I would install this, in addition to the other patches from the Toshiba web site. Hopefully this will overwrite any software quirks for you. regards, Keith
Nov 24, 2006 | Toshiba e740 Pocket PC
Reset my Pocket PC
A Reset of your Pocket PC is equivalent to "Restart" of a desktop computer. Carry out the Reset only in such unusual cases as when a button or tapping the screen does not respond. When your Pocket PC is reset, no data will be deleted. All stored information like Addresses, Contacts, Tasks or Programs are still stored in the Pocket PC memory. To Reset the Pocket PC, the power must be on. Then press the Reset switch with the stylus, then release. Your Pocket PC should function properly thereafter. If the functions cannot be restored, even after the reset button is pressed, Initialise your Pocket PC (refer to the FAQ article: How can I initialise my Pocket PC (Factory Reset). If you have further questions, please refer to the Instruction Manual page 12-4 (172 of 182).
Sep 08, 2005 | Toshiba e740 Pocket PC
Initialize my Pocket PC
When you initialize your Pocket PC, the factory default values are reset to the status as when you originally purchased the Pocket PC e740. NOTE: When you initialise your Pocket PC, all data stored in the memory is deleted. Your Pocket PC's initially installed programs are not deleted. Before initialization your Pocket PC, remove all storage cards. To initialize your Pocket PC, please follow the steps: Turn off the power Press the power button while pressing and holding the reset switch with the stylus. Then release the power button When a screen appears, release the reset switch When initialization is completed, the Welcome screen appears. Set up the system according to the screen as in the case of startup procedure.
Windows CE Program's
On the new Toshiba e310, e570 and e740 Pocket PCs, Microsoft's new operation system Pocket PC 2002 is installed. The question whether Windows CE programs run under Pocket PC 2002 has no definite answer. Most Windows CE Program will run under Pocket PC 2002. Pocket PC 2002 is an improved version of Windows CE, or rather, the next generation of Microsoft PDA operating systems. Some parts of the internal architecture of the operating system, like the e-Mail system, are of a complete new design and in fact, quite different. So if you run older Windows CE programs using "old and possibly, changed parts of Window CE system", it is quite possible that the Windows CE program will not run or will not operate correctly. Tip: To avoid problems or data loss, we suggest using Pocket PC 2002 programs only. Please note: Pocket PC 2002 is only available for Intel "Strong ARM" processors. This is different to Windows CE, where several CPU's types were supported. Only Windows CE Programs for Intel Strong ARM" processors may run an Pocket PC 2002.
Sep 08, 2005 | Toshiba e310 Pocket PC
Sep 07, 2005 | Toshiba e330 Pocket PC
PDA e310, e330 or e740 together with Windows NT 4.0
The Toshiba Pocket PC's e310, e330 and e740 are designed to work together with Microsoft Windows 98, Windows 98SE, Millennium, Windows 2000 and Windows XP. Microsoft Windows NT4.0 is an older operating system, which does not work together with the Toshiba Pocket PC's e310,e330 and e740. Technical background: The Toshiba Pocket PC's have a USB and a Infrared interface to communicate with a Computer. Unfortunately, Microsoft Windows NT4.0 does not support USB nor Infrared. Windows NT supports a serial connection, but the serial interface is not available for the Pocket PC's e310,e330 and e740. Note: There is the possibility to synchronize a PDA over Network or Modem but the ActiveSync Software, which is responsible for the synchronization, will need a "first sync" to establish a "partnership" with the PDA. This "first sync" can only be done via USB.
Sep 07, 2005 | Toshiba e310 Pocket PC
Sep 07, 2005 | Toshiba e740 Pocket PC
Backup and restore data
Section A - How to use a Toshiba Pocket PC e740 without loss of data: Never let the battery fully discharge. Never disconnect the battery from the e740. Regularly backup your stored data. Always connect the product to an external power source before changing the battery. Section B – How to backup your data: B1 – Using Activesync You can make a backup of the Toshiba Pocket PC e740 data to your notebook or desktop computer. If you have backed up your data to your notebook or desktop you can restore that data to your Toshiba Pocket PC e740. Periodical data backup is recommended. The following types of data can be backed up: FILE: Includes files created by Pocket Word, Pocket Excel, Notes etc. or an additionally installed program. REGISTRY: Setup information of Windows or programs. DATABASE: Database information from Pocket Outlook. When making a backup or restoring data please DO NOT remove the Pocket PC e740 from the USB cradle and DO NOT turn off the power to the device until the backup or restore is completed. Backup Instructions: Insert the Toshiba Pocket PC e740 into the USB cradle. A connection between the e740 and your notebook or desktop will be established. Please close all active applications on the e740. On your notebook or desktop start Activesync and select Tools and then Backup/Restore. Select Full Backup. Select Back Up Now to start the backup process. B2 – Using a Compact Flash (CF) or Secure Digital (SD) Memory Card: a) How to insert a Compact Flash Memory Card: Ensure the e740 is connected to the mains. Turn the e740 off. Remove the dummy card if necessary. Confirm the direction of the Compact Flash memory card by lining up the side grooves of the card and groove edge of the card slot. Insert the card smoothly and completely. b) How to insert a Secure Digital Card: Ensure the e740 is connected to the mains. Turn the e740 off. Remove the dummy card if necessary. Insert the Secure Digital card with it’s contact surface (the metal contacts) facing the back of Toshiba Pocket PC e740. Press the card down until it clicks. You can make a backup of the Toshiba Pocket PC e740 data to your Compact Flash or Secure Digital memory card. If you have backed up your data to your Compact Flash or Secure Digital memory card you can restore that data to your Toshiba Pocket PC e740. Periodical data backup is recommended. The following types of data can be backed up: FILE: Includes files created by Pocket Word, Pocket Excel, Notes etc. or an additionally installed program. REGISTRY: Setup information of Windows or programs. DATABASE: Database information from Pocket Outlook. When making a backup or restoring data using the DataBackup program please DO NOT remove the Compact Flash or Secure Digital card from the Pocket PC e740 and DO NOT turn off the power to the device until the backup or restore is completed. Backup Instr
Toshiba e740 Pocket PC Logo
231 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
