Question about Proview PA-32JK1A 32 in. LCD Television
Proview 3200 RX-326 LCD TV loses BLUE
TV (usually) powers up fine but then loses all BLUEness and associated colors leaving only shades of red and green. (Thermal problem?) Anyone know where to get schematics or repair service or an idea on how to deal with this? I'm pretty sure cable box source of RGB signals is OK -- at one point I could tilt and shake the TV and see the blue come back if only temporarily.
Feeling blue in Arizona.
  • 51 Answers
Digital brd has a heat related problem..If you did not get a extended warranty then it could be cheaper to just replace the TV...
Posted on Sep 09, 2008
How to fix a proview 3200 HD TV with no sound?
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Aug 10, 2014 | Proview Televison & Video
My Proview RX-326 lcd tv Has sound & picture but Picture mix colers brite
There is some incompatibility issue. Did you check the format is set correctly for PAL/SECAM etc.?
Jul 28, 2012 | Proview PA-32JK1A 32 in. LCD Television
Is there a wall mount kit I can purchase for my Proview 3200 326
There are pretty much wall mounts for every flat screen tv out there. Target sells them. You just purchase by using the size of your tv and there should be brackets that match the screw slots on the back of your tv.
Nov 28, 2010 | Proview PA-32JK1A 32 in. LCD Television
Does the proview rx-326 have the digital box
Yes,it have a Digital Tuner inside.It can get free air signal tv.No,need for a converter box like a Analog CRT tvs.
Apr 07, 2010 | Proview PA-32JK1A 32 in. LCD Television
Digital programming
The RX-326 does not have a digital tuner, only an analog.
Aug 17, 2009 | Televison & Video
Turns off and on
If it happens at a certain time every day, make sure you do not have the sleep and wake timers on.
Mar 08, 2009 | Proview PA-32JK1A 32 in. LCD Television
No picture but there is sound
This may be the problem click on your remote source button and see what is checked on the blue sceen that pops up...it may be on the wrong setting... I hope this helps, Ken, Attica, NY
Nov 24, 2008 | Proview PA-32JK1A 32 in. LCD Television
Proview rx 326 model 3200 tv sound but no picture
I just fixed my proview 3200 that doesn't have picture but with sound.
First, thanks for the tips I got from this forum. I checked the 24v from the power supply board and that's perfectly working fine. I then check the fuses in the Inverter board. There are 4 white fuses (2amp I guess, i cant remember) and 1 black fuse (1amp/76v just behind the wire connector going to the power supply board). The black fuse is the one that blown out on my tv. This fuse supplies power to the LM358A IC. I know its not right but I just solder a thin piece of wire to short circuit this fuse. I'm lazy to drive to RadioShack to find this fuse. :)
....and that worked beautifully. Check the picture attached for what I did.
May 27, 2008 | Proview PA-32JK1A 32 in. LCD Television
Proview 3200 HD TV
as you are using the ch3 , have you previously scanned and locked in all the channels for cable,
Apr 25, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
Proview PA-32JK1A 32 in. LCD Television Logo
399 people viewed this question
Top Proview Televison & Video Experts
Tony
joncin91
Level 1 Expert
Are you a Proview Televison and Video Expert? Answer questions, earn points and help others
