Question about Frigidaire ATF6000ES Front Load Washer
I have EE70
When the machine starts the rinse cycle it will stop and say Er70 what does that mean??? Thanks
  • 639 Answers
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
This means only service at your location will be able to diagnose the situation when there is an error it can be many things.But its an electronic problem!
For this problem you will need to use factory service!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
I
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
Washer fills on wash won't fill on rinse. Does on old washer and new washer. Checked and plumber said not the plumbing. Help PLEASE
It seems that you are out of cycle; meaning you are washing on rinse phase and the you are not getting water on rinse because you are at the end of the cycle. Try this; set the washer to the end of the rinse cycle, let it spin and stop. then wait 1/2 hour then start a wash you will be at the beginning of a new wash cycle..
Nov 10, 2016 | Washing Machines
Rinsing cicle is not stoping.Mashine not responding to any baton.How to stop Rinsing cicle and go to normal mode? Thanks Radan
If its is only the rinsing cycle at start up you can go into the menu and turn the rinsing cycle off.
If its the rinsing cycle for the descale, it has to run out of water to finish. Then reprime the machine and it will start to heat again.
Oct 28, 2010 | Gaggia Titanium Espresso Machine
What does SUD mean?
SUD means a detection of suds in the machine. These machines are very sensitive to over sudsing. Try adding just plain water or bleach to break down the suds level. They say to use 1/4 of the detergent you would use in an older machine.
If you see "Sud" or "Sd" with the Rinse status light on, the washer is in the process of removing suds. Let the cycle finish
If you see "Sud" or "Sd" and the Cycle Complete light is on, the washer detected too many suds during the cycle and your load may not be fully rinsed or water may not be fully removed. You may want to select a Rinse/Spin cycle for further rinsing.
Jul 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Nec nw-891 washing machine will not complete the programmed cycle
Apparent malfunction in the timer circuits. Specific Component replacement not available.
Jun 30, 2009 | Washing Machines
Wsher stops in the rinse cycle wiht a n F4 message
f2 error means long drain or no drain
check the drain pump
replace drain pump if nessesary
Mar 17, 2009 | Kenmore Washing Machines
Asko Quattro 6661 water inlet fault
I had the same problem with my unit. The manual tells you to disconnect the water intake at the machine and clean the screen. This wasn't my problem because as you said the problem doesn't occur until the Rinse cycle which means there is water supply to start the Wash cycle.
From the back of the unit, remove the three screws and take of the lid. You'll notice that there are three separate motors do pump water inside the machine at the water intake. When standing in front of the machine, the motor on the right controls the rinse cycle. I connected an AC volt meter to that pump and started the rinse cycle. 240v showed up at the pump, but the water flow was poor. I simply squished up and down the rubber hose connecting this motor to the detergent unit and was unable to free the clog and water began to flow.
Jan 07, 2009 | Asko W6661 Front Load Washer
Rinse cycle won't stop
Start rinsing again, when the water comes out, take off the water tank and let the machine go to it stop.
/Mirran
Aug 21, 2008 | Saeco Incanto Classic Espresso Machine
Fisher and Paykal GWL 10 US - Stops before rinse
52. (00110100) Eco - Diverter Top-up Fault diverter valve made be stuck in half open position ,may be a mechanical obstuction or the wax filled solenoid that actuates it may be faulty .located under machine beside pump .
Jun 17, 2008 | Fisher and Paykel GWL11 Top Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Frigidaire ATF6000ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
