Question about Gateway Solo 1450 Notebook
Notebook not powering on
There is no response from the notebook. When I press the power on button, there is no response even with the power adaptor connected. The battery light glows but there is no other action after I press the power button. This problems sometimes automatically resolves after several months of not using the laptop! but after powering on and off after a few days the same thing happens. could you please resolve. Thanks, My laptop will not turn on. When I plug tha adapter in the battery light comes on but stays orange. I get a faint flicker from the power panel under the hard drive spot. The hard drive doesnt turn on and neither does the fan. Not a single noise or light. What is wrong. I checked the adapter and it seems fine. I do not have a cmos battery in it. Would that make a difference or is my motherboard fried? Please help! Thanks
  • thetreeguy Aug 28, 2008
    How would the memory cause the comp not to turn on at all? I have been told its the DC jack or motherboard. Could memory really be the issue? Thanks
  • 31 Answers
If its not the battery, try replacing the memory
Posted on Aug 28, 2008
What stops computer from starting up
hi
turn off the notebook. take a regualr desktop monitor VGA or LCD monitor and plug into the notebook (make sure to power up both the notebook with AC adapter and power cord for monitor). Turn both on and you should see video on the desktop monitor . if you do not see anything, i would hint at the fact that the notebook screen may be bad. Do you hear the hard disk drive spinning when you turn on the notebook ? if so, thats a good indication that the mainboard is still working and that the LCD screen on the notebook is not functioing . You will have to replace the LCD (notebook) screen
Jan 04, 2012 | Acer Aspire 5630 Notebook
Lenovo Ideapad Y510 won't turn on or off
try removing the battery and removing the adaptor press and hold down the power button for 5-10 seconds then let got this will power drain your system board noy turn the system on using the battery only without any adaptors to charge or power the system, try turning the system on if the system turnes on leave it turned on for a couple of hours then conenct your sysem adaptor monitor if the battery light and the battery indicator on the lower right of the screen in windows woll indicate that the system is chargin if it is then I believe everything should be fine the blue indicator is for your system if it is blue then your system is turned on and has power if it turned orange and blnking then the battery will be more likely be almost out of juice or may need charging.
Jun 23, 2010 | Lenovo IdeaPad Y510 Notebook
Gateway mx7118 laptop will not power on
remove the battery, unplug the power adapter. press power button for 30 sec. then connect the power adaptor. press the power button.
if this didnt work you can contact your laptop's manufaturer to run test for your pc..
you can contact this num: 866-539-3901.
Apr 01, 2010 | Gateway MX7118 Notebook
My Gateway 1450 will not power up. For the last 2 weeks that battery light has been red (battery need recharging). i had the unit turned off with no ac power to it all weekend and not it will not power up....
The motherboard battery is just a little round battery that you can buy at almost any retailer in most pcs. The model number to the battery is usually a CR 2032. This battery does not receive any power from your power supply. Have you noticed your PC loosing time over the last few months? This is usually a good indication that the motherboard battery is dying. The lights that you refer to though should only partain to the rechargable battery of the notebook. During the past two weeks while the red light was on, was the AC adaptor plugged in to the laptop and plugged into an AC source? If your AC adaptor has been plugged in and is not charging the notebook battery then there could be one or both of the following problems: your notebook battery could be bad or your AC adaptor could be bad. Something you may or may not know is that it is not good to keep the AC adaptor plugged in all the time. This causes the notebook battery not to fully discharge after being charged. Over a long period of time, the battery will not even charge anymore. My suggestion is that if you know someone with a similar AC adaptor to yours, borrow it to see if it charges your battery. If the battery doesn't charge then you know to replace. However, I am almost certain that you problem is the battery. Sometime older laptops like the one I have has a reset button on the underside. If yours has one try removing the battery and leave it out. Then plug in the power and press and hold the reset button for 10 to 20 seconds. If no reset button is on yours then do the same process with the battery removed and power adding, but hold the power button instead.
Dec 07, 2009 | Gateway Solo 1450 Notebook
Powering on the laptop
Remove the Battery from the Notebook and disconnect the AC Adaptor. Press and hold the Power button on the Notebook for 30 seconds.
Connect the AC Adaptor to the Noteobook and to a different wall outlet then press the power button to turn ON the Notebook. If not then insert the Battery pack in the Battery compartment of the computer then press the power button to turn it ON. Make sure that the Battery is fully or optimally charged.
If performing the above mentioned steps didn't power up the notebook nor the power indicator glows on the notebook then the issue is with the power circuit and service will be required.
In this case, contact any service technician to get the Notebook repaired and running.
Nov 03, 2009 | Acer Extensa EX4420-5239 Notebook
Message that battery needs replacing last week but it was still going
Remove the battery and ac adaptor. also remove any peripherals.
Make sure that ac adaptor is working ok
Then press power button and hold that for 20 seconds to statically discharge the notebook. Then plugge that into the mains (without battery) and try to turn on. IF Notebook will not boot. Call service as mainbord needs to be replaced.
May 27, 2009 | HP Pavilion dv9000z Notebook
Adaptor light on. Laptop does not start when power button pressed same problem also when try too start from battery power. Son was playing a pc game and just switched off, have waited for hour still n
try to take out both battery and power adaptor. press and hold the power button for ten secods while both are not connected. then connect the power adapter only. try to turn it on. if it still does not turn on then most likely you have a problem with the hardware. you might need to have it checked out with an outside tech already.
May 25, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
My note book will not powering up.
Try to open the battery and connect your laptop to adaptor, then try to switch it on again. If nothing improves then there could be motherboard issue
Nov 25, 2008 | Compaq NC8000 Notebook
Compaq Presario 1680 Notebook shows no power in window when plugged in.
Take the battery out disconnect the AC adaptor Press and hold the power button about 7 seconds. Put the battery in and connect to AC adaptor press and release the power button. If it caused by static-component lockup, issue will be resolved. If still there is no activity including no power light check the AC Adaptor if its working
Good Luck
Dec 30, 2007 | Computers & Internet
Help
sounds like you have an intermittent problem with your AC adaptor or dc input jack. Does the light on the AC adaptor light up when you plug it in? If it does then your dc input jack may be faulty. If the light on the ac adaptor does not light then replace the ac adaptor. Good Luck!
Sep 16, 2007 | Toshiba Satellite M30-S350 Notebook
Computers & Internet Logo
213 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
