HI I just talked to you about Phillips projection
I took off front panel there is no controls up there, F.Y.I. had to unscrew front panel from inside TV. There is two sets of knobs on back with blue,green and red one saye focus and the other says screen.The one that says screen seems to make brighter and the other one focus the crosshair would move down and up but not left or right. There is a knob right on the base of projectors that looks like you would use wrench or socket to adjust something. Thanks Adam
  • 1 more comment
  • ar2004 Aug 28, 2008
    Thanks for your help looks like it's over my head there is three boards in my set and lots of wires too much for a rookie. Is 300-400 reasonable to fix this at my home?
    2004
    Ok thanks for all your help
    Genius:
  • 2,920 Answers
You may have a buily in board which means youll have to replace it,,,its in the back of the tv almost in the middle and should say convergence on it the board runs about 80.00
Posted on Aug 28, 2008
  • 1 more comment
  • Ronnie Houston Aug 28, 2008
    what year is it?
    yes it wouold definately be worth the cost to repair it its barely 4 years old i would say yes fix it
    you are more than welcome feel free to contact me any time you need help ron
HI I HAVE A DRYER MODEL DLG5988WM I WOULD TO KNOW HOW TO REMOVE THE FRONT PANEL
Step 1, remove dryer top: remove three phillips head screws from the back edge of dryers top.
stand in front of dryer and push back sharply about 2 inches on the dryer's top using the palms of your hands. Lift top up and off.
Step 2, remove control panel: remove phillips screws from back side of control panel corners and release clips along top edge of control panel, allowing panel to be taken off and set on top of dryer.
Step 3, remove front panel: Open door, remove phillips screws located at 4 and 8 O'clock positions at door opening. remove phillips head screws along fron panel's top edge. tilt panel forward and unplug light, door switch, and moisture sensor (at bottom of panel) and then set panel aside and out of your way.
Feb 03, 2011 | LG WD-3243RHD Front Load Washer / Dryer
Can't get the end caps on the console removed
Behind each end cap (back of washer) you will find a screw hidden beneath a plastic tab. Place a Phillips head screwdriver against the tab and onto the screw. Unscrew it and then pull the control panel forward toward the front of the washer. Lift the head by the end caps and rotate it upward. It will stay attached to the back panel and expose all the parts inside the control area.
Oct 05, 2009 | Whirlpool LSR6232J Top Load Washer
How do I remove the timer to replace it? Roper RAS7133RQ4 washer has timer that quit working.
Unplug the cord of the washer.
On each end of the control panel there is a plastic end cap. If you look at the back edge of the each end cap...you will see a Phillips head screw. Unscrew the screw in the rear of each end cap. Stand at front of machine and grasp both end caps. Pull the whole control panel forward about 3/4" and it will lift. Lift and swivel the control panel up. The very top stays attached and the underside will now be exposed for access to the timer.
The link below will cover aspects of your desired task beginning on page 19. Page 20 talks about timer removal.
Service Manual
Reverse the process to reinstall the control panel. Good Luck.
Sep 21, 2009 | Whirlpool Washing Machines
Amana front load washer door locked with door open
To get the front off. (All screws look to be #2 Phillips Screws)
1. You have to unscrew (2) phillips screws from the back that holds the top on.
2. Slide the top off. (slide towards the back)
3. Then where the control panel is there is about 4-6 screws holding that plastic piece on, take those out this will allow you to pull the control panel up and out of the way.
4. At this point you can unscrew the 4-6 screws in the door area that holds the front of the washer on, once you unscrew those screws there is a tab that you have to lift the front over to pull the front off. This will allow you access to the locking mechanism.
5. There are only 2 screws holding te locking mechanism on.
Feb 25, 2009 | Amana Washing Machines
Orange light on the front of the TV
Replaced bulb for zenith e44w46 lcd but the orange light is still on how can I reset the bulb timer on my own without throwing down another 85.00 for a repair guy to reset my T.V.
Jan 26, 2009 | Zenith E44W46LCD 44" Rear Projection...
Power cord broken inside s251i miele How do i open the s251i ????
HOW TO OPEN MIELE 251 VACCUUM: 1-Unplug from wall and disconnect power cord 2-Remove black switch panel at back of top panel: A-Use Phillips screwdriver, remove two silver screws visible between back of hinged top door and front of black switch panel
B-Push back of the panel down while pushing it forward (towards front of machine). There are two plastic notches and clips which are tightly fit together that you need to separate.
Once it releases, push it a bit more towards the front of the machine and lift off panel. It has wires connecting it to the main body so it will not remove completely.
C-Be careful not to lose the springs that simply sit inside of two plastic channels, one under each of the two switches. These are required for your witches to operate properly.
3-Locate screw at bottom of deep rectangular hole now revealed (under former location of black switch panels). Unscrew using Phillips screwdriver. 4-Open hinged top panel. Locate two silver screws, one on each side of main housing. Unscrew using Phillips screwdriver. 5-This will let you lift off the whole top assembly, door and main housing, revealing the plastic chassis and the motor unit within.
You now have access to the motor, wiring connector harnesses, circuit board and the cord reel.
Dec 07, 2008 | Miele S251i Plus Bagged Canister Vacuum
Sony Rear projection TV problem
hi, i had the same problem today. i took a risk and opened the front bottom panel(regular star faced screws located at the side) where the speakers and buttons are located. then i unscrewed the panel located right below it. i then unplugged the wires that were connected to the bulbs(sorry i dont know the technical term for it but there should to be blue,red,and green bulbs). when i reconnected i turned it on it was fine. its been about six hours now and it's working perfect. hope this helps.
Oct 20, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
How to get access to door interlock mechanism?
WHAT YOU HAVE TODO TO GET THE FRONT OFF IS TAKE OUT THE SOAP DRAWER COMPLETELY THERE IS FOUR PHILLIPS SCEWS TAKE THEM ALL OUT THAN TAKE THE TWO KNOBS OFF THAN LIFT UP THE PANEL SLOWLY WATCH THE WIRES THAN UNSCREW THE THREE SCREWS ACCROSS THE TOP OF THE FRONT PANEL AND THE THREE ALONG THE BOTTOM YOU SHOULD NOT HAVE TO TAKE OFF THE RUBBER TO GAIN TO THE DOOR SWITCH
Apr 20, 2008 | Hotpoint Aquarius WD63 Front Load...
Front Panel
unscrew the screws around back, but hold front will start falling when screws are out
Jan 14, 2008 | RCA D52W19 52" Rear Projection Television
Will not power on. Please Help!!
Error code 12 means normal operation. On these models we have found that a switch is sticking on the control panel not allowing the set to turn on. Disconnect the control panel. You will be able to use the remote on it. To find the plugs for the control panel: Remove the speaker grill and front panel, then follow the wire to the connection. Remember to unplug the set before putting your hands inside of it. Tell me how it went. Lead Tech
Dec 14, 2006 | Mitsubishi WS-55511 55" Rear Projection...
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
