Question about Frigidaire ATF6000ES Front Load Washer
Frifidaire front load shuts off before spin
My frigidaire front load machine works perfectly until it reaches the 9 minute left mark when it should begin its final spin. Instead, it simply shuts off. This happens irreguardless of the cycle that it was set on--'normal', 'spin and drain', 'rinse and drain' etc. Any ideas?
  • angela Aug 14, 2012
    Did you find out what the solution was. I'm having the exact same problem.
  • 639 Answers
Dear Friend
ngfam1 here for you!
I am happy to be of assistance!
Since your machine does not work perfectly, My professional opinion is that only factory service will remedy this malfunction!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. Please give me a good rating here in fixya.com before you sign out!
Posted on Aug 28, 2008
Frigidaire Affinity ATF7000E Front Load Washer won't stop spinning with 1 minute on timer- it continues until I hit cancel. I don't like to babysit a machine but have to make sure it doesn
If the unit is washing properly, as far as you can tell, but it won't stop spinning, then I would have a professional look at the control panel and timer to be diagnosed because there seems to be in miscommunication.
Sep 14, 2012 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire gallery front load won't spin
Does the washer spin after the wash cycle? It sounds like the door switch. This is a common problem with frigidaires. 90% of the time a door switch fixes it.
Jul 01, 2009 | Frigidaire Washing Machines
Front load washer isn't spinning out
The first thing to check is if the door is locking. Put the unit into spin turn unit on let it go for about a minute then shut it off, try to open the door right after you shut it off if the door opens you need a door switch if not chances are you need a motor control board. Before replacing the board call for service they are expensive if it is a guess. good luck
Dec 26, 2008 | Frigidaire GLTF1670A Front Load Washer
14 cycle front load washer fridgidaire
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 door lock error
check wires connections to the door lock..
replace door lock..
hope it helps
Aug 08, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire LTF2940ES Hums
sounds like something is stuck in drain pump
washer will not go into high spin untill water is pumped out
Jul 20, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
69 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
