Question about Pentax *ist D Digital Camera
Exposure problem
I just made some more test shots with the *istD. I shot some outside, some inside with built in flash and some with the external flash mounted on the camera. I also reset the camera to its' default settings. Guess I better shoot some more with external flash with cord hooked up and see what happens. The exposures were all right on target. Now, I wonder if the problem could be with the external flash cord I am using. Hmmmmm. Do you think this would cause an underexposure problem?
    Master:
  • 542 Answers
From my tests on my *istD, I concluded that the meter is correct but that the ISO sensitivity is overestimated by 0.5. Of course: --this is not necessarily the case with all *istD: many underexpose like mine, some others are correct, some others are worse and need repair --there are always situations which lure any meter, and in which you have to use your own brain, with the help of the histogram (after one test shot). My camera seems to love the low end of the histogram. This is not a problem if the histogram is not clearly cut at the left end: it must show a oblic line at this point, not a vertical. The oblic line is the large majority of cases. However, my practice is now to apply a +0.5 exposure compensation with an eye on the possible burned highlights. For comparison, I had no underexposure problems with my Olympus C2000Z and E10, and my Canon G3. The minoltas A1 and A2 of friends were about 0.5 overexposing. I have no experience of other reflexes.
Posted on Sep 08, 2005
    Master:
  • 542 Answers
I've found that the *istD underexposes ( as it should metering 18% grey ) light subjects, or with light backgrounds. A white wall using TTL ( AF500ftz ) behind any subject it always turns grey! You need to manually adjust 1 stop over. With dark subjects, overexposing with out blowing out much. If your used to the metering from a PS digi cam the *istD takes a bit of getting used to.
Can the camera sp-800UZ take rapid shots pics with flash going off every pic taken
In short, no. As with all flashes, the capacitor takes a while to recharge (via power from the low voltage battery which is amplified to many thousands of volts in the capacitor) between each shot. How long exactly depends upon how far it's discharged each time, so for close-up objects which fill the frame and need little flash, the discharge will be relatively low and you may get a few shots off in a row, and for distant objects using a more powerful flash discharge it may totally discharge with each shot.
The bigger and more powerful the flash unit, the better it will perform in that respect which is why professional external flashguns are big, bulky and cost hundreds or even thousands of dollars. A built-in flash such as on your camera is a compromise solution and is not intended for heavy use. More advanced cameras may have their own built in pop up flashes to take close up snapshots, but for anything else have connectors to enable the use of more powerful external units.
Mar 04, 2011 | Olympus SP800UZ Digital Camera
Pictures are over exposed when outside
You may have the settings wrong. Check in the MENU to see if you have it set to "inside" pics rather than outside.
Also the ISO has a lot to do with the exposure. If the iso is set too low outside sunlight pics will be white or overexposed. Try setting ISO on wheel for various options select program mode button and MENU select ISO 120 or 250. These are are pretty general settings. the flash will only engage inside or outside if the light is low ( like evening) I suspect your ISO setting is at a setting that is incompatible with bright sunlight
t
Also select White Balance and move it to DAYLIGHT
take a few shots inside and out to see if there is an improvement.
Please rate my help++++Thanks for using FIXYA
May 29, 2010 | Samsung Digimax L60 Digital Camera
Pentax istd built in flash goes off when taking picture but picture is underexposed but if I use a different flash in manual mode the camera works ok
What distance are the subjects when using the built-in flash?
The built-in flash is optimized for use between 0.7m (2.3ft) and 4m (13ft).
You could also try adjusting the ISO setting (higher ISO requires less light) or adjusting the EV value to a positive number to increase the exposure.
May 14, 2010 | Pentax *ist DL Digital Camera
We have a C-725 Olympus. Flash shots inside are
Lower the "exposure compensation". Lower the ISO.
Nov 11, 2009 | Olympus Camedia C-725 Digital Camera
Built-in flash not flashing as expected
I'm not sure if the problem is the flash or settings on your EOS, from what your saying.
Lets try to change the settings first.
Try to change the settings of your camera, look in your manual. What your looking for is ISO, this is the exposure. By taking practice shots and changing ISO you will find a setting that will match your preference.
Also, it seems like your flash is faulty. Contact Canon to fix it for you.
If you have the money, try to fix your flash. Otherwise set your ISO to auto or change it every time you take a picture outside or inside.
Sep 13, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Manual light & exposure settings
if you are using flash lights on the art work, please follow the following steps
  1. turn off your flash in cam since it bypasses the external flash and makes the picture look different.
  2. turn your light settings to either automatic or "flash light or arc light".but do not set them to incandescent light!!!
  3. turn your macro to on status if you are going to take a close up shots, but please note that close up shots work great in natural sunlight than at flash lights...
Sep 13, 2009 | Fuji FinePix S2000hd Digital Camera
Flash Problem
First step would be trying to reset all defaults, which I'd imagine is in the setup menu. Make sure you are also not in a mode which turns off the flash. For the 990 at least these are: The built-in flash will automatically be set to ?Off? when: ? you use autofocus with a setting of ?Infinity? ? you choose a multi-shot setting of Continuous, Multi-shot 16, VGA Sequence, or Ultra HS (an external flash can still be used with these settings) ? you choose a multi-shot setting of Movie ? you use best-shot selection (BSS) ? you use lens converter (LENS) settings ? the AE Lock option in the EXPOSURE OPTIONS sub-menu is on make sure your batteries are fresh and fully charged. if nothing works, consult a professional on repair, use an external flash, or use it just when the sun is out... Good luck!
Sep 19, 2005 | Nikon Coolpix 2000 Digital Camera
Problem with taking pictures in the shadows
In very simple terms you simply didn't have enough aperture and sensor sensitivity to get the same exposure in the camera as you got with your eyes. The blurring was caused by camera movement while the shutter was open, hand held anything over about 1/15th of a second will be unusable at your shortest focal length. Night photos are hard as they require maximum aperture to let in enough light, and maximum aperture means minimum depth of field so if you are close to the subject it is hard to get all of it in focus. You can increase the ISO setting, but that introduces noise into the shot. As you noticed using flash completely destroys the interesting lighting you were trying to capture. With a proper external flash you would have got a shot as though it were daytime, with a small inbuilt flash you just forced the camera to take a short exposure with a small aperture without adding enough flash light to get the exposure, hence the black picture. As it was a static subject you could have tried a long exposure with the camera on a trpod, possibly using the self timer to start the shot so that you did not touch the camera at all. Another area to take care with is colour/white balance. Your eyes are very good at adjusting for any colour cast or hue in the illumination. You will notice that a sheet of white paper looks white to you inside under normal lights, or inside under flourescent lighting, or outside in daylight . You will find that your camera has to be preset for the colour/temperature of the illumination, to get this right you need to know the spec of the flood lights (halogen, tungsten etc) as it is unlikely the automatic white balance will get this right, being less sophisticated than the human eye/brain combination . You can of course adjust the white balance in who editing software. I hope this helps....
Sep 08, 2005 | Pentax Optio 330GS Digital Camera
Flash pictures too blue - optio 750z - help?
Try playing with the exposure compensation lever. Turn it down a few notches when you use flash. I do that all the time to prevent over exposure Or you can set the flash compensation in the setup.
Aug 30, 2005 | Pentax Optio 750Z Digital Camera
Pentax *ist D Digital Camera Logo
91 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
