Question about Akai LCT3201AD 32 in. LCD Television
AKAI WONT POWER ON!
I have the Akai ltc32z4adp tv/dvd combo. The tv turned off by itself. The red led is on (steady... no flashing) but my tv will not power on. Not from the remote or the side panel. I press the power button and the led stays a steady red. PLEASE HELP!!!
  • debrussick Sep 07, 2008
    I have the same problem. The TV won't turn on. LED light remains red.
  • 2,326 Answers
The power supply on your LCD failed and will need to be replace or repair.
Let me know if you need further assistance.
Posted on Aug 28, 2008
Akai tv/dvd combo LCT3201ad 32" auto-shutoff or turns off after 3-5 seconds after being turned on.
Change input device to some other like a DVD player and see.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, call in a qualified service technician.
Aug 05, 2012 | Akai LCT3201AD 32 in. LCD Television
TV doesn't turn on - red lindicator light is just flashing
check and replace your horizontal output transistor as well as the regulator..
May 17, 2010 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Television will not turn on with remote or from the tv itself. The red light is on, so it is getting power and we have tried other plugs, so outlet is not the problem. Akai 32" LCD TV/DVD Player Combo...
there are capacitors on the power supply that will be vented or the top bulged out
those will need to be repalced to correct the problem
1000mfd 16volt caps
Oct 24, 2009 | Akai LCT3201TD 32 in. LCD Television
I have 32" akai that won't turn on - it is plugged in
I had the same problem witht he same tv that was given to me! I just took off the cover to the DVD player and unpluged all the connectors to it and then the TV worked. Now you will not be able to use the DVD player but you can hook one up externally
Oct 23, 2009 | Akai LCT3201TD 32 in. LCD Television
Red power indicator light is blinking
The flashing light indicates a short circuit inside the power supply circuitry. This type of repair is not a DIY without a multimeter, desoldering iron and hand soldering skills. I repair these power supplies, if you need further info write to jah2mil@hotmail.com
May 26, 2009 | Akai LCT2701TD Television
Akai tv
The power supply most likely failed on your LCD.
How old is your LCD?
Jul 26, 2008 | Akai LCT3201TD 32 in. LCD Television
Tv\DVD Wont turn on
Quizas el sistema de la vcr este fuera de tiempo,por causa de la banda del motor de carga el aparato tiene que ser abierto para ser reparado llevalo a un taller.
Mar 28, 2008 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Turn off /turn on
I have an 32 inch Akai TV/DVD Combo; the TV turns off by itself about every 20-30 min, and when I put in DVD to play, the TV cuts off.
Jan 30, 2008 | Akai LCT3215/26 32 in. LCD Television
Akai Plasma TV's screen suddenly went blank -model PDP4294
Same thing for me. TV just turned off one day and won't come back on. LED flashes red. Someone said it's because a cooling fan went out. If I can't find someone to fix it I'll take it apart and tinker myself. 32" with dvd built in was barely over a year old.
Nov 04, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai 20 in combo
These sets have very few parts available today and are considered throwaways. It will cost you more to repair I'm afraid then it would for a new set.
Oct 15, 2007 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Akai LCT3201AD 32 in. LCD Television Logo
303 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
