Question about Pioneer DEH-1100 CD Player
Pioneer deh 1100 problem
Ok my cd player and radio work just fine. i can set the presets and everything and they will work, but if i turn the key off for longer than about 3 seconds it wipes all my presets and forgets where i was at on my cd. how do i go about fixing this?
    Sergeant:
  • 241 Answers
Your fuse that is in the car is most likely th problem.Your radio is fine. Replace the fuse check the owners manual to locate the memort for the radio
Posted on Aug 28, 2008
Setting radio stations, Pioneer DEH-P2000
you can seek to a station you like and then choose a preset button 1-6 . press the chosen preset button for a few seconds until the display blinks. the station should then be locked into that preset.
Jan 04, 2011 | Pioneer DEH-P2000 CD Player
I have the Pioneer DEH-P5100UB. How do i stop the display from changing colors from blue to black?
I have the same radio, it doesn't have preset buttons...to get it off u turn the key to on/acc and turn the radio off. then press the "band/esc" button.
Nov 11, 2009 | Pioneer DEH-P5100UB Car CD/ MP3 Player
Preset memory not working on pioneer DEH 1700 radio
You must connect the constant hot wire (or there is a fuse blown somewhere).... it should either be orange or yellow at the rear of the pioneer radio ... it should be connected to a wire that recieves power even when the key is off ... that wire will depend on the car itself ... if you used a connector to plug into the factory wires (a good idea) that connecter should have a yellow wire that would supply a constant "hot" for your pioneer, if it doesn't there should be a fuse blown in the car fuse box.
Apr 06, 2009 | Pioneer DEH-1700 CD Player
My preset radio cant hold long ...
This is normally a problem that happens when the yellow wire on the harness is connected to the wrong voltage source. The yellow wire must be connected to a source that is always supplying 12 volts even with the car turned off. That is the way they keep all memory after the radio has been turned off and the car turned off. Check that the yellow wire has the voltage it needs when the car is off, if it does have that voltage, I can help you further, but this is the most common reason for your problem.
Jan 23, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Pioneer DEH-2100, no power after alternator change.
Take the unit out of the dash. In the back of the unit, disconnect/remove the wiring connector. Underneath a little "flap" on the bottom of this connector there is a small red 10V fuse. That fuse had blown, and when I replaced it the CD?radio worked just fine.
Dec 13, 2008 | Pioneer DEH-2100 CD Player
Setting radio station to a channel on a Pioneer DEH-525R cd player
Scroll to the station then press and hold the preset button you want it to goto.
May 23, 2008 | Pioneer DEH-P2000 CD Player
Setting radio stations on pioneer DEH-525R CD player
Scroll to the station then press and hold the preset button.
Pioneer DEH 435 CD player
Same as all Pioneers. With the car on or in ACC position press and hold SOURCE until the radio turns off. Press and hold FUNC to enter the menu. Use the four arrow keys to navigate and make changes.
Nov 30, 2007 | Pioneer DEH-27MP CD Receiver w/ MP3/WMA...
I cannot get AM to come through my radio
THERES NOT ALOT OF AM RADIO ANYMORE MOSTLY TALK RADIO BUT MAYBE THAT'S WHAT YOU WANT
Oct 05, 2007 | Pioneer DEH-1100 CD Player
Pioneer DEH-1100 CD Player Logo
118 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
