My Thermostat is flashing "L6"
I have a Bryant furnace/air conditioning unit. The thermostat started flashing "L6" today. What does this mean? Should I turn the Air Conditioning off?
  • compag4 Nov 29, 2008
    Thermostst blinking l6
  • mdewolfe72 Jan 26, 2009
    Can I reset this code that is flashing L6?
The battery needs replacing.
Posted on Oct 18, 2008
  • achiropracto Oct 18, 2008
    Hi.
    Sorry, discovered the the L6 problem is a Lb problem Low battery
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Look on one of the inside panel for the code diagram! Thank -you-very-much!
Posted on Aug 28, 2008
Air conditioning condensor will not run from thermostat have to go outside remve covers and jump thermostat connection . Then runs fine and cycles problem is intermitant
If it was me I would make sure the weed wacker hadnt attacked those wires as they leave the area leaving the house making their way to your condensing unit. Next, follow those wires back to your furnace control terminal area. Blower vibration can cause those little wires to break over time. Take care not to cause a break. Next, pull the thermostat off its base wall mount and jumper the red and the yellow wire, sometimes there is a blue color wire instead of yellow. If the unit outside comes on after this trick, make sure rc and rh are jumpered together on the thermostat terminal base and if they are then its your thermostat. One last thing, if someone has changed that thermostat since last cooling season, the thermostat wiring should be red to r terminal, white to w, green to g, blue or yellow to y terminal. Again rc and rh are usually jumpered. There are exceptions and at the very least see that the red wire is under the rc terminal.
Jun 03, 2012 | Bryant Heating & Cooling
What are twinned units?
Twin units can be two airconditioner condensers and/or two furnaces. Most manufacturers make a twinning kit that will wire two units together to operate simultaneously by one thermostat. At times, one may operate as a first stage of heating (cooling) and then the other unit can operate as second stage. Twinning unit are beneficial in commercial buildings where the load conditions vary constantly. For instance, if you twin two 4 ton units together. On a nice cool day, you may only need 4 tons of air conditioning. So, the thermostat will only turn on one unit. On a hotter day, you may need 8 tons of air, so the thermostat will turn on both units. In case you are thinking about doing this, the biggest mistake in twinning units together is using a common return air for the furnaces. Make sure you separate the return air cavities and ductwork for both of your furnaces If you don't have separate returns, you have the possibility of one of the blowers starting backwards. (talking form experience LOL)
Aug 13, 2011 | Heating & Cooling
My totaline thermostat is blinking ''L6'' Furnace is operating ok, filter is clean. I can't figure out how to reset it and don't have a manuel.
Well..I just recently noticed this problem on mine and cant seem to find anyone to help me other than to call for furnace service..but the more i look into this ..the more i wonder if the code is L6 or Lb for low battery.
Jan 27, 2010 | Heating & Cooling
Bryant programmable thermostat will switch on furnace
Turn the power off to the Air handler unit.
Remove the thermostat from the wall, (Just the face part).
Look on the back side of the thermostat and verify that the jumpers are set to electric and not gas, otherwise the fan will not run during heat mode, they come from the factory usually set for gas.
If this is a electric heater this will solve your problem, If it is gas then it will be more detailed. Once you put it back on keep in mind that most thermostats have a 3-5 minute delay so just give it a little time and the fan should then work once you have the jumpers in the correct position.
FlaTech
Thank you for using FixYa!
Nov 17, 2009 | Bryant Heating & Cooling
Day / Night HVAC is running cool air BUT the furnace is running 2
Strange. Does the thermostat control both the air conditioning units and the furnace. If not make sure the furnace thermostat is turned down to below 65 degrees.
Jun 29, 2009 | Honeywell Programmable Thermostat Heater
Bryant Legacy Line air conditioning not blowing cool air..
Your outdoor condenser is in heat mode. Check the wires on the thermostat. Sounds like a small wiring problem and nothing else. Good luck. Please keep me posted as to you progress.
Apr 27, 2009 | Bryant 462AJC021BA Air Conditioner
Furnace is not working, digital thermostat does not register
sounds as if your low voltage transformer might have bit the bullet will need replacing all of the devices you mention are powered by this one low voltage t-stat
Dec 09, 2008 | Bryant 462AJC021BA Air Conditioner
Honeywell thermostat
If you have a forced air furnace with an air conditioner attached make sure you have a jumper wire between Rh and Rc. If the Bryant thermostat had a wire hooked up to C you do not want to hook this up to Rc. Just cap it off and put it back in the wall or disconnect that wire down in the furnace.
Aug 10, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
3,120 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
