Question about Toshiba e750 Pocket PC
NAVMAN GPS Card problems
I have an e750 and am trying to use a NAVMAN 1400 Compact Flash Type1 GPS Reciever. It says on the box that it has been tested on this pda so it should work. I have installed all software as required but when I insert the GPS module the e750 complains about an unrecognised card and asks me to assign a driver! Any ideas??
    Master:
  • 903 Answers
I had a similar problem earlier in the year with the Navman 1400 CF card and my Toshiba E740. Whilst I could get the PPC to recognise the CF card, I could not get any GPS signals recognised by either the Navma s/ware or GPS Utility. I even sent the whole setup to Navman UK - Horley for them to check out. They updated the BIOS and claimed it was working, but when it returned - no go! Numerous phone conversations and simultaneous tests showed that it was not working! Navman tried to persuade me to upgrade to their Bluetooth GPS for an extra few hundred quid ! No way, eventually I got my money back. It would seem that GPS CF cards do not work with Toshiba PPCs unless they have an external aerial connected to the CF card - it appears that interefence from the PPC processor swamps the satellite signals. I have tried to get info from Toshiba on this but no joy. I eventually bought a different GPS CF card which also has an external aerial and it works perfectly well with the external aerial attached, but no signals are received whern the aerial is disconnected.
Posted on Sep 08, 2005
    Master:
  • 903 Answers
It is not easy to say what the problem can be. In my opinion you should contact the producer of this GPS receiver and ask them what the problem is. If this has been tested the producer must be able to help the users.
Update navman gps
go online they usually have instructions for updating.
Jul 31, 2014 | Navman S50 3D Portable GPS Automobile...
How to update navman maps flash card
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 19, 2014 | Navman AA005364-5E2 Model iCN 320 Mobile...
Navman S50 3D will not load just shows computor to navman image
I have been having the same issue and was wondering how you got on ? sue_stoke@yahoo.co.uk
Jul 16, 2014 | Navman S50 3D Portable GPS Automobile...
Does anyone Know a golf gps that works on Navman pin 570
Navman is not a USA product and it is not compatible with many apps. Getting Local Maps are not easy either.
Mar 25, 2014 | Navman GPS
How to update my navman F10
It helps to know your progress through this update. Inform me. And vote for me.
http://www.gps-data-team.com/pda-gps-navigation/topic/2839.html
Here's what you need.
Sep 17, 2012 | Navman F10 Portable GPS Automobile...
Application error.
This is not an uncommon error and is mostly referred back to Nab=vman for repair
Other than sending it to Navman you can...Open up the unit (this voids any and all warranties you may still have and if you go with this option forget about contacting Navman). F20's internal flash is just a hidden micro SD card. If you don't have it already, you'll need to get a cheap micro SD card adapter -- with it you will be able to read the card with any card reader. You could then scan card for errors and look for log files that could provide more information on what went wrong with your unit.
Please rate my help++++Thans for using FIXYA
Nov 26, 2009 | Navman F20 GPS Receiver
Navman icn510 gps reciever problem
How long are you waiting and are you moving while it is trying to acquire signal? These receivers are using older circuitry that may take up to 20 minutes to first acquire a signal from a cold start. If you are moving it may take longer!!! The good news is that after you have initially acquired a location, if you turn the unit off it will only take a minute or so to reacquire after it has "warmed" up.
Oct 22, 2007 | Navman ICN510 GPS Receiver
SD GPS
I have read some Information about Toshiba PDAs. There is a technique called SD™ IO card. In the technical specifications I found this Info: 1 x SD™ card slot (supports SD™ memory card, SD™ IO card, MultiMedia card) So when SD™ IO card is the same as Bsquare SDIO Now! tecnique...
Sep 08, 2005 | Toshiba e750 Pocket PC
Sdio GPS
as far as I know the e750 supports the SD-Card I/O standard. You can check your system seettings, go to START - SETTINGS - SYSTEM - SYSTEM INFORMATION - DRIVERS There should be seen the SD/MMC Host driver, the SD/MMC Memory Driver and CF Card driver. Also if the gps card needs a driver, it should be installed also! Perhaps a system reset helps you in the end!
Maximum memory?
How much I know there are no limits. I have information that with 1GB Card there are no problems. It can be that if you use Card with high memory capacity PDA can read data somewhat more slowly.
Toshiba e750 Pocket PC Logo
112 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
