Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Have a new Craftsman 5600 Watt AC Generator - followed instructions in preparation to start according to book- only put 1/4 tank of gas to try it but does not start! Not enough gas??
Make sure it's on level ground as there is a built in switch which inhibits operation. It doesn't take much tilt to throw it off, i.e. inclined driveways etc.. Make sure ALL switches are in proper position before pulling the cord and, oh yeah...make sure there's oil in it or it won't start!
Posted on Sep 09, 2008
Did you put oil in it?
Posted on Aug 30, 2008
White smoke
You are getting oil into the cylinders. Possibly bad seals on the valves or bad rings on the pistons.
Apr 01, 2014 | Craftsman 5600 watt Generator
Generator does not start it has fuel in the tank with new battery ,check every thing is ok
how OLD is the gas? if it is older than 3 months with NO stab condishner get rid of it try new gas
Dec 12, 2013 | Dewalt Generator. 6000 Watt Portable...
Craftsman 5600 watt generator won't stay on and white smoke pours out when started.
try running it with nothing hooked up if it runs fine, then the power draw is to much for it that would cause it to hunt !!!
Jan 30, 2013 | Craftsman 5600 watt Generator
My craftsman 5700 generator has gas inthe oil...why?
your float is stuck and wont shut of the needle and seat so it floods make sure you shut fuel of when not running and check your needle and seat and see if it shuts of the fuel from the tank
Oct 29, 2012 | Craftsman 5600 watt Generator
Yamaha EF1000is inverter generator, never tused, won't start
Try searching for a fuel shutoff somewhere near the bottom fuel line exit for the fuel tank on somewhere on the fuel line.
Nov 12, 2017 | Yamaha 1,000 Watt Portable Generator...
Gen power shut down every 10 to 15 min
try and run it with the gas cap loose the vent could be plugged up if it stays running but pops the circuit breaker the your over loading the system
Sep 03, 2012 | Craftsman 5600 watt Generator
I need a gas tank for a 4000 watt Buffalo generator.
call buffalo tool parts dept.they have brand new tanks for $36.75 or if you need a petcock they cost $9.95 they also have the gas gauge for $9.60.call 1-800-568-6657
Feb 01, 2011 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
I have an ACDELCO 6500 Watt Electric Start Generator. i bought it brand new about 1 year ago and it started up with no problems. Unfortunately I did not drain the gas after using it and it sat idle with...
Fuel will go stale if left for a long time. Drain and clean fuel tank and also drop float bowl on carburettor to remove any old fuel. If there is any sediment in the float bowl a carby clean could also be necessary.
Aug 24, 2010 | BUFFALO ACDelco 6500 Watt Generator...
Makita G11oo portable generator. starts on choke. cuts off run
Just noticed your question... If you still need a little help:
1. If the gas is from last year, drain the tank and the carb bowl and replace gas with new. Visually inspect the inside of the tank ..be sure there's no sediment that needs to be cleaned out.
2. remove air cleaner and make sure it's not plugged or dirty
3. plug the spark plug and clean with spray carb cleaner.
4. At end of season, mix some gas stablizer in with the fuel to keep it from going bad while in storage.
Let me know how it goes..
k
May 21, 2009 | Makita 1,100 Watt 2.5 Hp Portable Power...
Preventive maintenance craftsman 5600 generator
there should be a little bowl on the bottom of the carb if so take the bowl off and a gas can & funnel it should drain everything out the reason for draining all the gas out is if you don't most of the time it will start coroding the parts & when you go to use it again it wont run because the float is stuck or corosion in carb hope that helps e-mail me let me know thanks wade
Sep 11, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
96 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
