Question about Toshiba e740 Pocket PC
E740 won't turn on
Until two days ago my e740 was working near perfectly, only the usual minor problems that occur with any electronic device. however, on wednesday morning I tried to turn the unit on and it did not respond. I tried resetting it first soft then hard and then eventually it turned on only to freeze. when I pressed the power botton it did a reset once again. I mananaged to install my backup with no problems but throughout the day it kept on freezing. I have continued to have these problems today. The only way i have been able to make it that the problem does not continue is to make sure my ppc stays on, which is obviously a power drain when a plug isn't available. I think it is a battery problem.
    Master:
  • 903 Answers
Is there a freezing problem if the PDA is on cradle? I am not sure but it can be battery problem. I don’t know how old is your PDA but you should contact service partner and let them check the unit.
Posted on Sep 08, 2005
SOURCE:
I recently replaced my Intermatic EJ500 with a new unit, I noticed it works perfectly fine for one day then the batteries that control the timer drain completely the following day, what could it be?
Line voltage usually controls the timer functions when properly wired until a power outage occurs; then battery power takes over until utility power is restored. Should utility power be off for an extended period of time, eventually the battery will drain completely
Double check to make sure you wired your wall switch timer properly.
Make sure there are no loose wiring connections.
Even though you purchased a new replacement timer wall switch, it could be a manufacturer's defect.
Has your home electrical system experienced any signal spikes? Electronic components are very sensitive to impulse spikes/surges and can be damaged very easily.
If you are experiencing surges or spikes, perhaps investing in a whole house surge protection system (Intermatic IG series) would be the way to go as well. It'll protect all your electronic devices and appliances through-out the house.
Feb 12, 2017 | Intermatic Hardware & Accessories
Not powering on
Will it start if attached to a charging cradle directly?
May 21, 2008 | Toshiba e740 Pocket PC
We have a Samsung SMH1816S Microwave and about a month ago we had a scheduled power outage. Right after we noticed that every time we open the microwave door, the fan runs. It doesn't sound quite right,...
Likely an electronic component has failed. It sounds strange, but this sometimes occurs to electronic devices that had been previously working just fine -until it is removed from power. When power is restored, the device fails. This type of behaviour is normally associated with power surges, but it can simply happen to electronic devices that have been in service for a while. Have you ever noticed an incandescent light bulb "blow" when you switch the light on? Unfortunately, the controller circuit board will require replacement, which may not be economical.
Nov 12, 2014 | Samsung 1.8 Cu. Ft. Over-the-Range...
Novi doorbell intercom system won't work. Got it about 8 years ago, worked OK except for minor problems until recently. Now it malfunctions constantly. We finally had to disconnect the wiring o
If you are looking for new intercom system then I would suggest you to buy it from http://www.hulksecurity.com/ .Hulk Security System not only provides intercom systems but they also offer variety of access control system, CCTV and alarm systems. Well, I hope this would help you and have sorted the concern for intercom system.
Oct 24, 2012 | Novi Wireless Doorbell Intercom Security...
OK, ya'll, a problem I have not seen mentioned. About I year ago I replaced the usual suspect capacitors in my E85H power supply. Presto! All was well. One day last week the power went off. The unit was...
Circuitries exspand an contract all the times.Parts flickers in voltages,current in or sitting there for long time or just apply to it.Or cold solders,bad concuctive paths joints.Hundred of answers,cause to a device to malfuctions.
Aug 11, 2010 | Panasonic DMR-E85H DVD Recorder
Hi. i lost my sound on hp dv 8113 cl few days ago
  • Hi, the best thing to do at this point is perform a "System Restore." Try to remember the exact "Date before the problem occur, or once you start the System Restore, ("pick a date going back more than 5 days"), check the dates and see if any of the dates seem familar. Pick the closest date prior to the "Sound going out!" Type in the "Search Window" from the start menu: system restore; scroll to find, and open. Follow all the instructions carefully for the process to be successful. "Hope it works out for you; if so rating the help will let me know, thanks."
Apr 25, 2010 | HP Pavilion dv8000z Notebook
When I turn the light off with the remote control
im realy not trying to be a smart a*s but bont you only ever use lights at night?? i know i do?
it sounds like its the programer chip within the light that giving you the problem if taking the batterys out the controler dont stop this, its down to the light,
well there is one other thing it may be,,,
a friendly gost playing tricks on you???
or it could be that its getting a surge or spike of power from some were and that tricks the controler in the light to turn itself on???
sorry about that bit of fun as first just could not resist it????
Oct 26, 2009 | Hunter Ceiling Fan Light Remote Control
Samsung e740 mobile
hi friend look problem is not with your software but it is with ur screen . pls went to any nearest dealer to solve that problem. migght be u need to replace screen or minor wiring errors can also be there.
Jun 17, 2009 | Samsung SGH-E740 Smartphone
Toshiba E740 Power Problem
Hi, I noticed that the firmware that you have is not the latest, the last provided was 1.0623.049 which was released a few years ago. I would install this, in addition to the other patches from the Toshiba web site. Hopefully this will overwrite any software quirks for you. regards, Keith
Nov 24, 2006 | Toshiba e740 Pocket PC
Backup and restore data
Section A - How to use a Toshiba Pocket PC e740 without loss of data: Never let the battery fully discharge. Never disconnect the battery from the e740. Regularly backup your stored data. Always connect the product to an external power source before changing the battery. Section B – How to backup your data: B1 – Using Activesync You can make a backup of the Toshiba Pocket PC e740 data to your notebook or desktop computer. If you have backed up your data to your notebook or desktop you can restore that data to your Toshiba Pocket PC e740. Periodical data backup is recommended. The following types of data can be backed up: FILE: Includes files created by Pocket Word, Pocket Excel, Notes etc. or an additionally installed program. REGISTRY: Setup information of Windows or programs. DATABASE: Database information from Pocket Outlook. When making a backup or restoring data please DO NOT remove the Pocket PC e740 from the USB cradle and DO NOT turn off the power to the device until the backup or restore is completed. Backup Instructions: Insert the Toshiba Pocket PC e740 into the USB cradle. A connection between the e740 and your notebook or desktop will be established. Please close all active applications on the e740. On your notebook or desktop start Activesync and select Tools and then Backup/Restore. Select Full Backup. Select Back Up Now to start the backup process. B2 – Using a Compact Flash (CF) or Secure Digital (SD) Memory Card: a) How to insert a Compact Flash Memory Card: Ensure the e740 is connected to the mains. Turn the e740 off. Remove the dummy card if necessary. Confirm the direction of the Compact Flash memory card by lining up the side grooves of the card and groove edge of the card slot. Insert the card smoothly and completely. b) How to insert a Secure Digital Card: Ensure the e740 is connected to the mains. Turn the e740 off. Remove the dummy card if necessary. Insert the Secure Digital card with it’s contact surface (the metal contacts) facing the back of Toshiba Pocket PC e740. Press the card down until it clicks. You can make a backup of the Toshiba Pocket PC e740 data to your Compact Flash or Secure Digital memory card. If you have backed up your data to your Compact Flash or Secure Digital memory card you can restore that data to your Toshiba Pocket PC e740. Periodical data backup is recommended. The following types of data can be backed up: FILE: Includes files created by Pocket Word, Pocket Excel, Notes etc. or an additionally installed program. REGISTRY: Setup information of Windows or programs. DATABASE: Database information from Pocket Outlook. When making a backup or restoring data using the DataBackup program please DO NOT remove the Compact Flash or Secure Digital card from the Pocket PC e740 and DO NOT turn off the power to the device until the backup or restore is completed. Backup Instr
Sep 07, 2005 | Toshiba e740 Pocket PC
Toshiba e740 Pocket PC Logo
83 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
