Question about Honeywell Heating & Cooling
We have gas under floor heating. The main thermostat controll has FEL by Honeywell on it. It is about 6 months old. We don't appear to have any manual or instructions on how to set the the thermostat to run automaticaly. Can you help with a manual or set of instructions. Regards Ron tman_nz@yahoo.co.nz
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
In OKLAHOMA, we only have a 2 wire thermostat that the heat closes the contacts,,I'm not familure with your type..
Posted on Aug 28, 2008
I have a very old Honeywell thermostat. I am not getting any heat-how do I check to see if thermostat is working.
Is your pilot lit? if not the the gas valve will not open. Call for heat, check wires at gas valve, should be around 24 VAC.
Jan 03, 2018 | Honeywell Heating & Cooling
My round Honeywell T-87 on the main floor(middle) of the house has no ON/OFF switch. It controls the temp of that level of the house and even though it is set at 60, the temp is way too high and reads 74....
What you are describing is the Heat Anticipator. It is a small resistor that helps the thermostat from overshooting the set temperature by heating up and shutting off the thermostat just before your set temperature. I don't think that is related to your over heat. 14 degrees is a lot and the Heat Anticipator will only effect it 4 or 5 degrees. I would remove the thermostat and check if there is a call for heat. If so, you have a shorted wire. If not, replace the thermostat.
Dec 30, 2009 | Honeywell Programmable Thermostat Heater
Wiring honeywell to old landis thermostat
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
Jul 08, 2009 | Honeywell Heat/Cool Thermostat
Installing CM900 Honeywell into Junior 24 Bosch Combi
What kind of boiler are using is this boiler a on the demand electric or gas? You need low voltage wires. If you get me make and model # of off boiler i can try and find wiring diagram . Tell me a little more about you heat system to. Like baseboard heat or in floor how many zones
Jan 16, 2009 | Honeywell Programmable Thermostat Heater
Wiring for a Honeywell RTH2310B
HONEYWELL WEBSITE:
Go to honeywell.com
Jan 10, 2009 | Honeywell Focus 6300B 5-2 Days...
I had an old thermostat that i had to change need wiring diagram
HONEYWELL WEBSITE:
Go to honeywell.com
Dec 20, 2008 | Honeywell Electronic Programmable...
Need to know which terminals run what
Had similar problem, continuous fan, turn off power, then won't start up. Replaced thermostat, no change. The main controller board in the furnace went bad. What was weird was that it happened in the summer, while the heat was turned off. One day I noticed that the fan was running. The thermostat was in the off position, and I had to shut off power to the furnace to make it stop. I forgot about it till heating season came along and it wouldn't start up. The preliminary blower would start, the gas would click on, it would light, then quit. After tracing and checking the various safety switches, etc. it became apparrent the main board was bad. I found one on ebay, replaced it, [a simple job, unplug, a few screws, replug] and it's been working fine..good luck, John
Nov 07, 2008 | Honeywell Focus 6300B 5-2 Days...
Installing Honeywell RTH7000 - I have too many wires!
check to see if the B terminal is on the new t-stat if connect to it , but this terminal refers to heat pumps and is normally use to energize the reversing valve on the outside unit and not used on ac units , but normally the tag O/B is the same terminal on therostats
Oct 26, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
77 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
