Question about GE Washing Machines
You can hear water still in the washer - not inside the tub where you put the clothes but inside the washer machine.
  • 1,543 Answers
I believe you are referring to a GE top loading washer. GE uses a liquid filled balance ring around the top of the washer to help compensate for off balance load. The sound is perfectly normal.
Posted on Aug 28, 2008
2 Suggested Answers
sdmc73
  • 121 Answers
SOURCE: neptune washer tangles all cloths
the washer has a balance ring that hold water that is ok. as of the tangleing you may have a low water fill
Posted on Nov 30, 2008
Kenmore series 80 washer do not drain enough
It's normal to hear some water in tub, it isn't normal for the rubber wheel to be hard to turn, you need to replace the pump, they are much cheaper on ebay
Sep 27, 2017 | Kenmore Washing Machines
My LG front loading washer smells like wet clothes that have been in the washer for months? Musty smell?washer overnight? Strong smell of musty old clothes
This is caused by the biomass built up inside the tub of the machine. This can also be caused by a moldy door boot. You need to scrub your door boot between the tub and the door. Water settles in the bottom of it and molds. Once you clean this, order affresh washer cleaner for your machine. This kills all the biomass built up in the tub and removes the smell. You will put all three tablets in the drum and run on the longest hottest wash available. When this is completed your machine should smell much better. To keep this from getting so bad again... Keep the washer door cracked open between cycles. This keeps the inside from smelling. Hope this helps
Apr 04, 2012 | LG WM-2277HW Front Load Washer
Model MAH5500BWW Why after I am all done with the wash and have everything unloaded can I hear water below the tub when I turn the tub manually? This is at all times.
This is not water that you hear. It is a form of liquid ballast that stabilizes the drum and counterbalances the weight of the clothes when the machine spins the clothes dry.
Aug 18, 2010 | Maytag Neptune MAH5500B Front Load Washer
Water left in tub at end of load smells bad you don"t see water but can hear at a turn of the tub by hand.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hope your filter is clean. Don’t wait for the machine to jam to look into your filter.
You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use very hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Put the Affresh pellet inside the machine, not in the soap dispenser.
You can give me a ‘very helpful’ rating for the free help, can't you. Thanks.
May 20, 2010 | Maytag Neptune MAH5500B Front Load Washer
Neptune MAH 4000AWW works good but some whater is left
Apr 11, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Why isn't the maytag neptune draining? when you spin the barrel you can hear water?
if you do not see water in the tube and the clothes have spun out enough to go into the dryer when the washer cycle finishes the washer has drained out all of the water the water you hear in the tub when the door is open and you spin the tub with your hand that liquid is in the sealed balance ring , that is a sealed channel around the front of the tub to help the machine stay balanced it does not come out
Apr 04, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have a top load GE model #WBB4500G, and our clothes comes out smelly. It is horrible. We are constantly having to rewash clothes, this is rediculous. I've heard of this problem with front loaders, but we...
You have an inner and an outer tub. The outer tub may be holding too much water. The smell may be the soured water in the outer tub. You should take the washer outside and drain it completely. Then replace the drain hose before you put it back inside. Hopefully, this will slove your problem.
Sep 04, 2009 | GE WSXH208A Front Load Washer
When i spin wash tub wigth my hand i can hear lots of water still in the machine under neath the wash basin
That is becouse most washing machines are made up of an inside drum where your clothes are washed and an outside durm that catches the water when the washer spins the water out of the washed clothes. A pump is connected to the bottom of the outside drum. If the pump fails, the water would not get pumped to the drain and would collect in the outside drum.
Aug 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
Neptune washer tangles all cloths
Nov 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
My Kenmore Elite He3 sounds like it has water in the tub after washing AND smells of MOLD?
there is always some water left inside the machine and that is probably what you are hearing are you using liquid detergent? if so this is almost certainly the cause of the smell. liquid detergent leaves a nasty slime inside thge machine and smells like drains. put on a boil wash with no clothes and revert to using powder detergent
Apr 02, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washing Machines Logo
284 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
