Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
Panasonic PT-47WX42F Do you have the location of the IC7001 part on the circuit board? My HDTV projection TV has distorted color just like you've mentioned in the past. I'd like to see if I can repalce the aprt myself. I know the problem but I was quoted over $600 to repair the TV. Any ideas? mytankos@hotmail.com
  • Panasonic Master
  • 8,617 Answers
You can get the two convergence ICs STK392-110 at the following link with free instructions with pictures so you can repair it yourself for around 50
heres the link.
http://servicemanuals.vstore.ca/
Posted on Sep 05, 2008
PT-53wx42f won't come back on. Red light blinks several times, checked cords, all are ok. Is there a reset button to press?
Please replace 2 chips in tv, these are marked (location number) as IC7001 and IC7002 on circuit board and number written on both big black chips is same that is STK392-110
Click PartStore.com to buy 2 chips and get it replaced in tv to solve the issue.
Thanks.
Jul 30, 2011 | Panasonic PT-47WX53 47" Rear Projection...
Television has double images like 3D, and bottom half of screen has a concaved image.
Please replace convergence ICs in tv, there are two big black ICs that has number STK392-110 mounted with big aluminum heat sink, replacement these ICs will solve your tv problem. Also check big resistor nearby these convergence ICs and replace if found burn mark or color faded.
On circuit board, IC location number is IC7001 and IC7002
Let me know if you have additional question.
Thanks.
Dec 25, 2010 | Panasonic PT-47WX49 47" Rear Projection...
RED ARCH ON LEFT BOTTOM CORNER
This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Jul 16, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic T.V. model number PT-47WX42F no picture or sound
R800 open on power board next to the relay.the resistor value is1.5 ohms 10 watt resistor.
Jul 15, 2009 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic PT-47WX42F outer most screen cracked
Look for a used Panasonic PT-47WX42F One in Local ads, Or place a wanted ad for your model. ~ Or if you want A new one, Get ahold of a TV Shop And OR Panasonic and be ready to spend lots of $$$$ ~ And yes there easy to replace!, Make sure you have a large clean area to work in, And a helper. Becarful and replace them back in as they came out! ( Top Bottom) they should be marked with a small tag or mark.... Geo*
Jul 06, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-52DL10 DLP TV
Color wheel bearing can make the noise you describe, and that will also cause color distortions.
Feb 15, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Panasonic 47wx42f projection
Joe,
It sounds like your may need to replaced your convergence ic's loc# ic7001 and ic7002 stk392-110. That should take care of your alignment problem.
Dec 03, 2007 | Panasonic PT-53WX42 53" Rear Projection...
One color distorted and not converged
Not an expensive repair, relitively speaking. Both convergence amps need to be replaced, Ic7001 and Ic7002 ( Panasonic p/n# C5aa00000203) are both Stk392-110 Sanyo built Ic's and cost about 25-30 dollars plus labor to install and a slight convergence set-up...
Bill
Nov 04, 2006 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
75 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
