Question about Toshiba e740 Pocket PC
Power fault
I have been having problems starting my e740 recently. in the morning i try to turn it on but it just simply won't eventually it comes on but does not stay on, it freezes, and resets if the power botton is pressed. the only time that the unit will stay on is if it is plugged in. I am wondering if it is a power problem related to the battery not being able to keep a charge.
    Master:
  • 903 Answers
In y opinion there must be some problem with battery power supply. In my opinion you should contact service partner. I hope that your unit has still valid warranty.
Posted on Sep 08, 2005
SOURCE:
Good morning, I have the Hyundai hp4200 which will not turn on, when you switch on it clicks then 2 minutes later clicks again to onto I guess standbye. However, if you turn it on and off by the socket...
Yep, I can help but I am afraid that I won't be able to bring totally good news.
The TV is in forced standby also called "protection". Protection kicks in when an internal fault such as a short (big power draw) or a wrong voltage is detected. The click comes from a relay activated by the protection circuit to force TV to shut down.
All you can do is disconnecting the power cord, checking if there is a fuse built in the power cord, replacing fuse and connecting back after about 30 minutes (that allows power drain). If the TV does not work there are faulty internal parts that need replacement.
If now the TV does not start at all, and not even the standby light is on, then the problem is usually the PSU. The part must be tested and eventually replaced.
Here replacement parts for most flat panel TV models:ShopJimmy.
See also:
PartStore
Regards.
Ginko.
Sep 15, 2011 | Hyundai Televison & Video
My sony stays on standby some times mostly in the mornings
It's probably staying late at night and is sleepy in the morning :-)
Seriously, it is likely related to the temperature.
It is a common problem with power boards where filter capacitors start to dry out; higher temperature helps them function properly and you will find advices to try a heat blower at the back on the TV to test this theory.
Unfortunately, there are also other parts that may be causing the same effect. I say unfortunately because they are usually harder to pinpoint and resolve.
I had a TV in shop recently which was behaving exactly like that and after turning around the power board I eventually ended up replacing the main board. The problem was solved and it certainly wasn't caused by filter caps, I made very sure of that.
My advice is have a pro look at it. If I am correct the problem will expand and it will start getting delayed more and more over time, not only in the mornings.
Regards,
http://www.coppelltvrepair.com
Dec 06, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I have an 8710 workstation and it has worked fine for many months. Recently I've been having problems powering it on. I use a docking station and when I try to power it on in the morning -- the power LED...
Flashing orange light generally indicates battery low charge could be your battery at fault
the next time you try and power on and it doesnt work, take the battery out (unplug AC) and try to run just on AC power
hope helps, let me know if can help further
Nov 04, 2009 | HP Compaq 8510w Notebook
Hard starting
hi if the engine light comes on you need to get the diagnostic tester to find out what the fault code is otherwise finding the fault can be a bit hit or miss and end up costing you more money then it might have you had the engined tuned [seviced] as this is the first thing to get done its the basics then look deeper if need be yates210456
Sep 03, 2008 | 1991 Honda Civic
Toshiba E740 Power Problem
Hi, I noticed that the firmware that you have is not the latest, the last provided was 1.0623.049 which was released a few years ago. I would install this, in addition to the other patches from the Toshiba web site. Hopefully this will overwrite any software quirks for you. regards, Keith
Nov 24, 2006 | Toshiba e740 Pocket PC
BT Problem Battery/Power Problem
In my opinion it is always very risky to buy some second hand unit because you can not be sure if every hardware component works properly. The best solution for you is to contact service partner and let them check the PDA. It is also possible that power supply electronic has some malfunction
Sep 08, 2005 | Toshiba e740 Pocket PC
E740 won't turn on
Is there a freezing problem if the PDA is on cradle? I am not sure but it can be battery problem. I don’t know how old is your PDA but you should contact service partner and let them check the unit.
Backup and restore data
Section A - How to use a Toshiba Pocket PC e740 without loss of data: Never let the battery fully discharge. Never disconnect the battery from the e740. Regularly backup your stored data. Always connect the product to an external power source before changing the battery. Section B – How to backup your data: B1 – Using Activesync You can make a backup of the Toshiba Pocket PC e740 data to your notebook or desktop computer. If you have backed up your data to your notebook or desktop you can restore that data to your Toshiba Pocket PC e740. Periodical data backup is recommended. The following types of data can be backed up: FILE: Includes files created by Pocket Word, Pocket Excel, Notes etc. or an additionally installed program. REGISTRY: Setup information of Windows or programs. DATABASE: Database information from Pocket Outlook. When making a backup or restoring data please DO NOT remove the Pocket PC e740 from the USB cradle and DO NOT turn off the power to the device until the backup or restore is completed. Backup Instructions: Insert the Toshiba Pocket PC e740 into the USB cradle. A connection between the e740 and your notebook or desktop will be established. Please close all active applications on the e740. On your notebook or desktop start Activesync and select Tools and then Backup/Restore. Select Full Backup. Select Back Up Now to start the backup process. B2 – Using a Compact Flash (CF) or Secure Digital (SD) Memory Card: a) How to insert a Compact Flash Memory Card: Ensure the e740 is connected to the mains. Turn the e740 off. Remove the dummy card if necessary. Confirm the direction of the Compact Flash memory card by lining up the side grooves of the card and groove edge of the card slot. Insert the card smoothly and completely. b) How to insert a Secure Digital Card: Ensure the e740 is connected to the mains. Turn the e740 off. Remove the dummy card if necessary. Insert the Secure Digital card with it’s contact surface (the metal contacts) facing the back of Toshiba Pocket PC e740. Press the card down until it clicks. You can make a backup of the Toshiba Pocket PC e740 data to your Compact Flash or Secure Digital memory card. If you have backed up your data to your Compact Flash or Secure Digital memory card you can restore that data to your Toshiba Pocket PC e740. Periodical data backup is recommended. The following types of data can be backed up: FILE: Includes files created by Pocket Word, Pocket Excel, Notes etc. or an additionally installed program. REGISTRY: Setup information of Windows or programs. DATABASE: Database information from Pocket Outlook. When making a backup or restoring data using the DataBackup program please DO NOT remove the Compact Flash or Secure Digital card from the Pocket PC e740 and DO NOT turn off the power to the device until the backup or restore is completed. Backup Instr
Sep 07, 2005 | Toshiba e740 Pocket PC
Toshiba e740 Pocket PC Logo
63 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
