Question about Dishwashers
GE GLDA690, THE CODE HI COMES ON BREIFLY AND THEN GOES OFF, JUST INSTALLED TODAY, ALL ELSE SEEMS TO BE WORKING FINE, DISCONNECTED ELECTRICAL AND RECONNECTED STILL SHOWING HI, ANY SUGGESTIONS, THANKS, AMY
  • 639 Answers
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Just installed today??? CALL SERVICE ! You have a 1 year warranty on new appliances !
For this problem you will need to use factory service!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
My new dishwasher wont completely drain?
Hi if the electrician installed your dishwasher Or (fixed it) he didn't !!, I'd ring the electrician and get him back....AND SHOULDN'T COST ANY EXTRA.......
Mar 18, 2016 | KitchenAid Dishwashers
Dishes not clean seems to have no water pressure
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Mar 12, 2011 | General Electric GLD5950N Built-in...
Hi I have a GE Dishwasher model gsd2200g -03 and I am getting C1 & C2 error codes but it seems to be working fine. I disconnected the drain hose and the water appears to be draining properly
hello there:
if you have installed a new garbage disposal make sure the knock out has been removed if removed then check the drain valve in the pump hope this helps you out sincerely D.Jones
Jun 08, 2010 | GE Profile PDW9880NSS Stainless Steel...
GE Dishwasher GLD4200L00BB not running
Did you ever get a solution to your problem. I have had the same model for 5 years and today it did exactly what you described. Please help.
Feb 14, 2010 | GE Dishwashers
My dishwasher wont start
Sounds like you need to check for power to the unit. Access is at bottom of dishwasher under panel. Next you will see the wiring coming into an enclosed electrical box. you will need to get to wires and check voltage on black hot wire to neutral with a voltage meter. If you have power but still doesn't work then at least you know the problem is with the unit and not the incoming power.
Jul 24, 2009 | Dishwashers
Maytag dependably quiet plus not starting
check connections to the door switch.
Nov 04, 2008 | Dishwashers
GE 2200 Dishwasher-no power at all, circuit breakers are fine, switch works
with your volt/ohm meter check for power going to the dishwasher. the power supply is located under the kick panel. the power wire may be shorted out due to poor installation. if you are not comfortable testing power, I would advise calling a professional. If no power is found at the power box (this has a power cord or electrical wire going to it) the problem lies within your house electric. if 120 volts is present, check for power @ the door switch. aftrer that you just need to follow the power wire and see where it stops
If this is a newly built house and new to you the builder may have put a light switch above your counter ,the one you didn't think went to anything, check for that! good luck with it!
Oct 16, 2008 | Dishwashers
Drying light keeps flashing
You said,
Drying light keeps flashing and beeping. dishwasher will not start. turned off circuit breaker and turned back on same thing happened again.
It seems you have an electrical fault in the dishwasher and it will not permit the start of the motor,
as a safety guard.
You must have the electrical system checked for shorts .
Otherwise the motor is dead!
huuum,happy to assist you!
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy.
Therefore they pay for them selves in only a few years.
You can buy New and save today.
Find the small privately owned and operated appliance store and you will get better service and good treatment! They also will be the best informed!
Bless You, let me know how it goes.
huuum
Please give me a good rating for my fine advice before you sign off.
Thank You
Sep 18, 2008 | GE 24 in. GLD5560LSS Stainless Steel...
Dishwashers Logo
109 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
