Question about Gateway Media Center 510S PC Desktop
BIOS My computer was working fine today until it just restarted on its own and wouldnt go back into windows i had the speakers on and they said "CPU,system test failed" and in text on the screen it said bios not installed how can i fix this?
    Sergeant:
  • 241 Answers
Did you resently update your bios??
Posted on Aug 28, 2008
Several codes and no start/stall
Cam shaft position sensor failing. Recommend do both cam and crank and clear codes and recheck.
Dec 22, 2013 | 2005 Kia Sedona
Sound
Maybe this is a foolish question, but are you positive the speakers work? Can you test them on another machine?
Aug 25, 2008 | Microsoft Windows XP Home Edition
What is the possible problem when your computer is automatic shutdown while using?
A number of things - all bad.
If I were betting on problems I've experienced, I'd be betting on reasons #5, #6 (memory), or
reason #8 (overheating due to failing fan), unless its reason #3 (virus).
(1) you laptop (if you have a laptop) battery is dying, and the system is hibernating in response to the low power indication.
(2) your computer's "Standby" button is being accidentally pressed (or the button has failed), and the computer is going into "Standby mode" since it thinks that the "Standby" button has just been pressed.
(3) a virus/worm/Trojan horse/spyware or other malware infecting your system can cause a system restart. While your computer is actually up, run an anti-virus scan and let it run until the system
shuts itself down, and keep running these anti-virus scans until it finds something, or the scan
finally runs to completion. Only when malware is eliminated as the cause of your system shutdowns can you proceed to address any other cause(s) of random system restarts/shutdowns.
(4) You're accidentally pressing the system "Reset" or "Power off" button (if you system is a tower).
(5) Your computer has developed a memory error in the area of RAM where the kernel is resident.
(6) Your computer has developed a memory error in the area of RAM where the ROM BIOS is loaded.
In the case of #5, or #6 perform an in-depth system memory diagnostic using your system's
ROM BIOS resident diagnostics. Access these diagnostic programs by entering SETUP while
your system is booting - usually by holding down F2 (or other system-specific function key) while the system is booting.
(7) Other software problem(s)
In this case, boot your system (and use it for awhile) in SAFE MODE. Safe mode is selected by holding down F8 (or other system specific function key). If you system does not randomly restart while in safe mode, then you have a software problem causing the restarts when in "nonSafe mode"
For Windows XP users
Windows XP is designed to automatically reboot each time an error occurs such as a BSoD (Blue Screen of Death). Although this may be nice for errors that do not occur often, users who have a re-occurring error may wish to identify the error to troubleshoot it. Below are the steps on how this feature can be disabled and enabled in Windows XP.
1. From the desktop right-click on My Computer.
2. Click the Properties option.
3. In the System Properties window click the Advanced tab.
4. In Advanced click the Settings button under Startup and Recovery.
5. In the Startup and Recovery window uncheck the Automatically restart check box.
6. Click Ok.
Now if the computer generates an error it should not automatically restart and enable you to display any errors your computer may be experiencing.
(8) Possible Heat related issue
Many computers today are designed to turn off or automatically reboot if the computer, processor, or other device in your computer gets too hot. If you have heard any abnormal noises coming from your computer recently such as a high squealing this could indicate a fan may be failing in your computer. If the CPU fan is starting to fail, the motherboard will shutdown the PC when the CPU
temperature exceeds a CMOS-set threshold, which protects the CPU from a thermal meltdown.
First, verify the fan on the power supply is working by examining the back of the computer and see if the fan is moving and moving smoothly. For all other fans in the computer (e.g. CPU fan and/or
a tower case fan (if you system has one)) you will need to either open the computer and visually verify that all fans are working.
If your BIOS monitors the RPM of the fans enter CMOS Setup and verify it does not report any errors.
(9) Issue with the operating system (operating system bug)
If after following each of the above recommendations your computer still continues to reboot it is likely that you are experiencing a Microsoft Windows operating system related issue (an operating system bug). To help make sure this is the case try the below steps.
1. Reboot the computer and enter CMOS setup as the computer is booting.
2. After you have loaded the computer in CMOS setup let the computer sit for a long time.
If the computer does not reboot while letting the computer sit in CMOS it is likely that you are in fact experiencing an issue with Microsoft Windows and it is recommend that if you have followed all of the above recommendations that you reinstall Microsoft Windows - or, since you're running
WinXP Service Pack 2, you may want to simply install (free) Service pack 3 and/or Service Pack 4,
and see if that resolves the operating system bug issue. Note that Windows XP SP2 is a particularly stable version of Windows, and it is unlikely that your "random restart" issue is going to be an operating system bug.
Sep 19, 2011 | Microsoft Windows XP Professional SP2
My computer which is a Compaq 7550 using windows xp and is about 8 years old ,claims that the progamm is installed but it never asked for the soundsaver serial number from the disc jacket. I dont...
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Apr 07, 2011 | Computers & Internet
One of my speakers stopped working today , the one with the yellow prong . when I plug in the black prong it works in both ports playing the speaker that is not broken . I purchased these new 2 weeks ago ....
try swapping the speakers around if the problem still persists either the speaker is faulty or
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
don
Feb 22, 2011 | Logitech Z-2300 2.1 Computer Speaker...
My cpu is on just i power off the monitor.,series is samsung SyncMasterB1930 is the model., now when i am trying to on the monitor the monitor is not responding it is still power off mode.
First check if the monitor is functional by removing the monitor cable connected to the CPU, once disconnected you should see a onscreen display on the monitor (Keep the power cable intact).
Second check if the CPU is working (not stuck / hung) if you hear the windows logging on sound, then your CPU is fine. If you do not have sound enabled during startup or no speakers then once the system is on give it some time to load windows and then keep tapping the Caps lock or the num lock key, if the lights respond / glow on and off when you press the keys then the CPU is working.
Third check if the CPU has two display ports (in case if you have a onboard VGA and a seperate video card) disconnect it from one port and insert it in another port and restart the computer and see it it works. If you do not have two video ports then skip this step.
Fourth - Restart the computer and keep tapping F8 Key while restarting, in the windows advanced menu choose enable VGA mode or Low resolution video mode (based on XP or Vista/Win 7 the menu changes), if you can see that menu then the issue is with the display settings only. Once in VGA mode or low resolution mode reduce the video resolution settings and restart the computer.
Please revert if you need further assistance, or clarification.
Thank you for contacting Fixya
Jan 03, 2011 | Samsung Computers & Internet
No sound in Windows 7
Uninstall all the audio drivers and restart the computer. Make sure the audio jack is in the Green audio port.
Let the operating system re-detect the audio and install the drivers for it itself. When its done see if you have any sound.
Post back if this does not work.
Good luck.
Nov 17, 2009 | Microsoft Computers & Internet
Same prob. My acer worked y.day and now no sound.
I completely unplugged my speakers. And uninstalled all the hardware for my speakers. Then restarted my computer. Then inserted my format disc for my speakers. Reinstalled it. Using all automatic speaker settings. And they work fine now.
Jun 29, 2009 | Acer (90.18612.36B) Computer Speakers
Upgrade from Pentium 3 to Pentium 4
what socket is the Pentium 3? Socket A. The sockets have to be compatible for example you can't upgrade a Dual Core for a Core 2 Duo because although the chipsets look the same the motherboard may not support the new instruction set. I had this problem recently as i wanted to upgrade my Intel Celeron D 3.02ghz to the Pentium Dual Core 1.8ghz and although the chips were identical and fitted perfectly in my mobo, the actual mobo i was using (foxconn) wouldnt work with it forcing me to buy an ASRock mobo and replace the entire system.
May 27, 2008 | Dell 2.8 GHz Second Processor for...
Gateway Media Center 510S PC Desktop Logo
57 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
