Question about Intertherm Heating & Cooling
My central air conditioner which is 901282 Intertherm is rusted out and leaking. It looks like that the base can be replaced. Can you help me?
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Yes, the base is called a pan and it can be replace with a plastic pan, or they have a liquid whic can be poured thru standing water and seal rusted pan leaks.. >Check out Palmer Supply in OKlahoma on the web-page but if you need the plastic pan check out the company of the unit web-page! Thank-you-very-much!
Posted on Aug 28, 2008
I have an intertherm furnace model number 901282 and it will not heat my house when i turn on the thermostat it starts but just blows out cold air pleases help
The blower should come on after ignition occurs. When the blower comes on first ignition will not be activated as the thermostat signal shows the heat is on. This happens when the blower relay is stuck in the on condition
Nov 21, 2014 | Intertherm Heating & Cooling
Intertherm/nordyne furnace (24 years old)
Shut off power, get a small wrench, remove orifice spuds and clean them with toothpick. Take burners out and clean rust from them. Check and see if you are getting 24 volts to gas valve. If not replace it.
Feb 15, 2014 | Intertherm P3RA-048K Air Conditioner
I have an intertherm electric furnace Mod#901282. it keeps cutting out and does not come on all the time. any suggestions? also is it possible to convert the electric furnace over to gas
Sounds **** a sequencer problem. As far as converting to gas. I would go with outside package gas unit. Works great and you do not have the noise. James
Mar 27, 2010 | Heating & Cooling
A/c on house evacuate need to find referigerant leak
if you are saying that your home ac unit is leaking refrisgerant and it is your central air system they have a dye that can be introduced into the system throught its refridgerant intake , if it is a small window unit the odds of fixing it inexpensively are minimal
Aug 31, 2009 | Intertherm P3RA-048K Air Conditioner
Leaking water
Sounds like ether you have a plugged condensate drain,or the drain pan is rusted out.If it it clogged you can squire a bit of water through to unclogg.If it is rusted youll have to wait it out.Good luck.
Jul 13, 2009 | Heating & Cooling
Finding model number of older intertherm central a/c
If it is not on the out side probably very weathered usually on the schematic in the unit if your wanting the age their is a model and serial number on the compressor hope this helps . Tom
Jun 25, 2009 | Intertherm P3RC-042K Air Conditioner
Blower speed
Yes usually the black is high speed, the blue is low and red medium speed. plug the black wire from the fan motor to where the blue wire is, then put the blue where the black wire was
Jan 10, 2009 | Intertherm P3RA-048K Air Conditioner
Intertherm to Honeywell thermostat
Typically if you have a yellow wire in the "y" terminal blue is used as common or "c". As far as your jumper from rc to rh, that will depend upon what type of heat you have. If all of your heat and cooling come from your packaged unit outside, yes you will need the jumper. If this does not work maybe you have a bad breaker or transfomer.
Oct 12, 2007 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
71 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
