Question about Canon i950 InkJet Photo Printer
Printer prints majenta
My test pattern shows column B to be blank, so it must be stopped up. How can I repair it?
  • blazena Aug 28, 2008
    My printer is a Canon, not HP, and it has separate color cartridges. All of the cartridges work except the cyan. I replaced it with a new cartridge, but it is not coming through, and on the test pattern, it does not show up at all. That's why I think the printer itself is gummed up somehow, and need to know what I can do to repair it.
    thanks.
  • JohnSBrown52 Sep 29, 2008
    I had the same problem with Bank E. All of my prints tend to have a blue cast to them. I replaced the print head with a new one and I still have the same problem. This problem began after a few months of inactivity, however, I did have a computer crash and got a new computer (Dell XPS 630i) to provide the extra horsepower of processing photos. I can't imagine the computer being the problem. Has there been any history of a bank of color not printing such as a logic issue? Any ideas?
  • 73 Answers
Properties, Printing Preferences, Maintenance tab for nozzle check and cleaning. Sometimes HP cartridges that have three colors run out of one or two colors at different times. If you try everything else and are going to get rid of the cartridge anyway, pull open the paper label on top and put a few drops of water in. Let it sit. If that doesn't work, you can alway get a refill kit, but they are messy and lose a lot of ink.
Posted on Aug 28, 2008
  •  Terri Popiel
    Terri Popiel Aug 29, 2008
    Some printers have removable print heads. I had a Canon like that. It was an orange piece that could be pulled out of the printer. The ink cartridge did not have a print head at all, but depended upon the printer's print head to regulate the ink. It may be able to be cleaned or replaced. The Canon I bought a few years ago cost $50 with ink, while a removable print head was $40. This is an excerpt from an article I saw on the internet:
    Often times, just soaking the print heads in distilled water with a little bit of rubbing alcohol or ammonia can do the trick. (You could also use a special cartridge flush solution, but that's going to cost you more money). Go ahead and remove the print heads from your printer and just soak them in any of the above liquids. Depending on the blockage, soak them for 10 minutes up to an overnight time period. This method works well by breaking up the bits of dried ink and it should eventually create a clear ink passage again.
I have not my Epson Stylus Photo for quite some time. Now I want to use it again, I 've put in some new cartridges. The print shows repeating (green) lines. Any idea what could be the problem ?
To help complete the pattern, feed copy papers to the printer and do atleast 40 blank photocopies and afterwards clean the head and check the nozzle.if it has not improved, repeat the same procedure until the pattern completes.mine also had the same problem but after doing that, it was solved for good.
NB: Command copies without putting any printed paper to save ink.
Oct 12, 2012 | Epson Stylus Photo R220 InkJet Printer
Majenta is not printing, all cartridges changed and cleaned still no majenta
Blocked print head nozzles
You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Aug 21, 2012 | Brother MFC-3360C InkJet Printer
Hi, My Canon Multipass F50 is flashing the "Wrong Cartridge" error message. I have read a proposed solution to get into the test mode, clear the eeprom and input (0) for the ink code. It doesn't have any...
One fellow on fixyourownprinter.com fixed his this way:
85.gif Re: MultiPass F50 by Anonymous (11/4/05 5:35 AM) reply + / - I tried this and it worked great. My F50 kept showing "wrong cartrige." I don't take credit for this I foud it on another sight
for another model of canon printers, but it worked on my used F50.
Here it is:
1: Remove Cartridge
2: Unplug the AC Power Cord
3: Hold down the RESUME button
4: Release RESUME after plugging in the AC Power cord.
5: Press the RESUME once within 5 seconds and release the RESUME .
6: Press and HOLD RESUME for two seconds or more and release it.
7: Press and HOLD RESUME for two seconds or more and release it.
8: Unplug AC Power Cord to set data.
I hope this info helps.
~Kevin~ in Las Vegas
Here is the web blog that talks about this problem:
http://www.fixyourownprinter.com/forums/inkjet/24152
Good luck, hope this helps, and thanks for using FixYa.
Aug 26, 2010 | Office Equipment & Supplies
My printer won't print. It says wrong cartridge, but it is the same cartridge that has been in there and printed yesterday. The cartridge is full. What is wrong?
Follow these steps:-
  • Reset the printer:-
  • On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  • Wait approximately ten seconds and then press the <ON/OFF> button again.
  • Wait until the device has completed its cycling process before submitting another job request.
Reseat the Print head
  • Make sure the printer is powered on.
  • Press the <Open> button (1), and then lift up the scanning unit (2).
The print head holder automatically moves to the center of the machine. 9cee8ec.gif
  • Lift up the locking lever, and then remove the print head. The print head can be removed with the ink tank still inside.
  • Replace the print head, and then press down on the locking lever.
  • Close the scanner unit.
  • When the LCD displays the following, press the <Set> button.
The machine will print a vertical line pattern.
  • In column A on the printout, note which box has the most solid image. Note the value next to this box and use the [<] or [>] button on the operation panel to enter it. Then press the <Set> button.
Note: If you have difficulty on Column A when choosing between two patterns, use the larger value number.
  • Repeat step 7 for columns B to F. If you have difficuly choosing between patterns for Columns D, E or F, use the smaller value number.
  • When values for all vertical columns on the printout have been entered, the LCD will display [LAT LINE PATTERN] and a lateral (horizontal) pattern will print.
  • Review the lateral pattern printout, noting which solid box in Column G on the printout has the most solid image.
  • For the G column printed pattern, use the [<] or [>] button to scroll to the value with the most solid box in the column.
Note: If you have difficulty on Column G when choosing between two patterns, use the smaller value number.
  • Press <Set> to select.
  • Repeat steps 11 and 12 for Column H on the printout.
  • When print head alignment is complete, the machine will return to standby mode.
If the problem persists then you will need to take your device for repair, for possible Print head faulty
Thanks for using Fixya.
Good Luck and have a nice day.
Jun 10, 2010 | Canon MultiPASS F50 All-In-One InkJet...
It will not print. It has new ink cartridges..There are no error messages. Print heads have been cleand several times. It will not print a test pattern. It will not make a copy. Only blank paper comes out.
Head cleaning is mechanical process, printing is electrical process. Nothing print out at all? Printer mainboard problem. Lost electrical to head. Usually caused by short circuit at head. Track on aicaxz solution for reference to repair board. Note: if you have experience in electrical circuit, test mounted fuse at board.
Dec 31, 2009 | Epson Stylus CX4600 All-In-One InkJet...
I replaced the shuttle and need to do the phasing adjustment. Can you tell me how?
IMPORTANT The printer must be printing the Phase pattern of “H’s” when the Phasing Value is changed, or the New Phasing Value will not be written into NVRAM. If the value is changed when not printing, the printer will return to its default phasing
value when powered off then back on.
1. Install the ribbon.
2. Load full width (136 column) paper.
3. Power on the printer and set top of form.
4. Press Stop to put the printer into NOT READY mode.
5. Press Scroll + Scroll to unlock the Enter key.
6. Press Scroll + Scroll + Return + Enter to enter the CE Tests menu. (Press all four keys at the same time.)
7. The display will show “SERVICE / PRINTER MECHANISM TESTS”, the first menu item. Press Enter to enter the
mechanism tests menu.
8. Press Scrollor Scrolluntil
“PRINTER MECHANISM TESTS / HAMMER PHASING” is on the display.
9. Press Enter. The printer begins printing all H’s, each line preceded by the phasing index number.
10. Press Return. The display will show
“SERVICE / PRINTER MECHANISM TESTS”.
11. Press Scroll or Scroll until “SERVICE / HAMMER PHASE VALUE” is on the display.
12. Press Enter. The top line of the display will show
“HAMMER PHASE VALUE” and the bottom line will show the current phasing index number.
13. Press Enter. The phasing index (followed by an asterisk) will move up to the top line of the display.
14. Press Scroll or Scroll to increase or decrease the phasing index, then press Enter to activate the value as it prints.
Continue to increase or decrease the phasing index until the pattern of H’s appears.
15. When the print pattern is acceptable, press Stop. Printing stops, and the printer automatically enters the current phase
index value into NVRAM. The display shows “NOT READY”.
16. Press Scroll + Scroll to lock the Enter key.
17. Close the printer cover. Press Start to put the printer into READY mode.
NOTE: If you changed the phasing value, power down the printer, remove the shuttle cover, and write the new phase value on
the aluminum shuttle casting.
Oct 06, 2009 | IBM 6400 Matrix Printer
My printronix printer making shadow while printing
Hammer Phasing Adjustment:
Important: The printer must be printing the Phase pattern of “H’s” when the
return to its default phasing value when powered off then back on.
1. Raise the printer cover.
2. Install the ribbon.
3. Load full width (136 column) paper and set the top of form.
4. Power on the printer.
5. If the printer is on-line, press the ON LINE key to place the printer off-line.
“OFFLINE / CONFIG. CONTROL.” displays.
6. On the control panel, press the = + > keys to unlock the ENTER key.
“ENTER SWITCH UNLOCKED” briefly displays. (If “LOCKED” displays,
simply press = and > again. This is the default key combination. The lock/
unlock key combination can be programmed by the user. If = + > does
not unlock ENTER, get the combination from the user.)
7. Press the ; key. “OFFLINE / DIAGNOSTICS” displays.
8. Press >. “DIAGNOSTICS / Printer Tests” displays.
9. Press >. “Printer Tests / Shift Recycle” displays.
10. Press ; until “Printer Tests / Phase Printer” displays.
11. Press ENTER. The display shows “Printer Tests / Phase Printer” and the
test begins. The current phasing value is printed on the left of the printed
pattern of all H’s. As the pattern prints, compare the H’s to the figure
below. If the phasing needs adjustment, go to step 12. If the phasing is
OK, go to step 15.
12. Press >: The current phase index displays. Press > again: An asterisk (*)
appears next to the phase value.
13. Press < to increase or ; to decrease the phasing index value, then press
ENTER to activate the value as it prints. Continue to increase or decrease
the phasing index until the pattern of H’s is acceptable.
14. Press = twice: “Printer Tests / Phase Printer” displays.
15. Press ENTER to stop the test.
16. Press CLEAR. “OFFLINE / CONFIG. CONTROL” displays.
17. Press = + > (or the key combination set by the user). “ENTER SWITCH
18. Close the printer cover.
19. Press the ON LINE key to place the printer on-line.
the shuttle cover, and write the new phase value on the aluminum
shuttle casting.
Jun 04, 2009 | Printronix Line Matrix P5005B Printer
Colr prints showing plenty of lines
Here's a solution from Canon USA:
Issue: Banded or streaked prints
Solution: Print Head Alignment MP530
Perform Print Head Alignment Instructions to perform a Print Head Alignment directly from the machine. If diagrams or ruled lines are misaligned, print head alignment is required. The print head alignment can be performed automatically or manually. If the automatic print head alignment does not work, adjust the print head manually. Automatic Print Head Alignment
  1. Press <ON/OFF> to turn on the machine.
  2. Load a few sheets of letter-sized plain paper in the auto sheet feeder.
  3. Press the Open button to open the Paper Output Tray. Then open up and set the extension by pressing down the hollow on the front side.
  4. Execute automatic print head alignment.
    1. Press <COPY> button.
    2. Press <Menu> repeatedly to select [MAINTENACE].
    3. Press the left or right cursor to select [AUTO HEAD ALIGN], then press the <OK>. (A pattern is printed and the print head is automatically aligned. It takes about five minutes to finish printing the pattern.)
Manual print head alignment
  2. Load two sheets of Letter-sized plain paper in the auto sheet feeder or cassette.
  3. Ensure that the proper paper source is selected.
  4. Execute manual print head alignment.
    1. Press <Menu> repeatedly to select [MAINTENACE].
    2. Press the left or right cursor to select [ALIGN PRINT HEAD], then press the <OK>. (The nozzle check pattern is printed.)
  5. Check the printed patterns and use the left or right arrow to input the number of the pattern in column A that has the least noticeable streaks.
  6. Press <OK> to move the cursor to column B, and then use the left or right arrow to input the number of the pattern that has the least noticeable streaks.
  7. Repeat the procedure until you finish inputting the pattern number for column P.
  8. When you have finished inputting all pattern numbers, press <OK>.
    Note: For columns A through N select the patterns with the least visible vertical streaks. For columns O and P select the patterns with the fewest visible horizontal streaks.
    <1> Example of the pattern with the fewest visible vertical streak
    <2> Example of the pattern with the most visible vertical streak
    <1> Example of the pattern with the fewest visible horizontal streak
    <2> Example of the pattern with the most visible horizontal streak
Hope this helps - fotobean.
Feb 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
CANON S400 PRINTING PROBLEM
What printer do you have? Clean heads, clean heads, clean heads, etc. Then do the test print to see if the heads are open. I had similar problem with an Epson, had to clean the heads often, finally got to where the heads wouldn't clean so threw it away and bought another one (HP this time, the heads are included in the ink carts, haven't had to clean the heads at all.)
Nov 02, 2008 | Canon S400 InkJet Printer
Canon i950 InkJet Photo Printer Logo
74 people viewed this question
old marine
old marine
