Question about Maytag Washing Machines
Maytag MAH5500BWW washer when set on cold cold sometime the washer washes on hot water intermittent problem I have always washed with cold water settings.
  • 639 Answers
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
This was a common problem with the Neptune!
This is one of many reasons they were discontinued!
you need service to diagnose which of many defects these Neptunes may have!
For this problem you will need to use factory service!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
No hot water
The replacement valves could be defective or installed incorrectly.
Nov 15, 2013 | Maytag Neptune MAH5500B Front Load Washer
I have a maytag neptune MAH5500BWW. Everytime the water company shuts off the water to repair a leak, the tub fills with water, sometimes overflows onto the floor. Works just fine when there is pressure...
This is symptomatic of a malfunctioning water control valve- depending on whether it is hot or cold water with which the tub fills.
Sorry but it needs replacing and a service call ;-0(
Good luck,
John C
Mar 27, 2011 | Maytag Neptune MAH5500B Front Load Washer
Cold/cold wash uses hot water wash and warm rinse. I have t set to hot/cold wash to get cold water wash.
probably the water inlet hoses are hooked up cold water line to the hot water inlet and vice versa
Aug 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Oct 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
WARM WATER INTERMITTENTLY ON A HOT WASH?
ok steph does this happen when you use the electronic temperature control for the water? If yes then here is the explanation. Yours and my version of a hot wash is HOT there settings are of a much cooler hot by the standards of the wash machine world.So if you want a HOT wash use the manual setting for hot/cold. When I discovered this about the electronic setting I was disapppointed. Or it could be your electronic water temperature control board. go to www.repairclinic.com/Appliance-Parts?s=t-LSR5132PQ-%3d%3d&z=100 this will show the only other pssibility. If you'd like call me at 417-926-0106 Jim.
Mar 15, 2009 | Whirlpool LSR5132PQ Top Load Washer
Maytag washer/hot and cold water
Some whirlpool washers have had A similar problem. They had a intermittent water temperature switch issue. Sometimes they put hot water in when cold was selected. This is probably the same problem as yours. I would replace the water temp switch.
Mar 02, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag mav6000 hot/cold problem
hi try to just regulate the temp by turning down the water flow from your taps if more cold is coming in than hot turn cold water down a bit to your satisfaction thanks THE APPLIANCE DOC
Sep 05, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
57 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
