Question about Dishwashers
My dishwasher does not sound correct (lack of spraying action sound) and this last time when I opened the door the soap had not disolved and the dishes where still dirty. I have taken apart the bottom arm before for a cleaning but it was only a couple of weeks ago. Could it clog up again so fast even when the type of dishes remain the same? Did I put it back together wrong? Maytag EQ Plus
  • 639 Answers
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
You put it back together wrong!!!
Call service now before it cost you real money!!!!!!!!!!!!
For this problem you will need to use factory service!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
Our dishwasher is not dispensing the soap. I have tried using the cubes (stays in wells), tried powder (it turns to a cake of soap) and I have tried liquid but you could see it ran down the door. Some...
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Dishes are not clean if water is hard or when more detergent is used than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results. You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine. Hope this helps...
Please post back if more information is required.
Daniel
Jan 10, 2011 | Maytag Dishwashers
My 13 year old Frigidair dishwasher (model FDB221RFR2) is not disolving the soap tab that drops in during the later cycles. We sometimes find the soap sitting on dishes or on the bottom. It appears that...
could be a couple of things. water valve semi clogged. circulation pump not working to it full capacity.also the water line not completely opened.a line
Feb 25, 2010 | Dishwashers
Detergent does not dissolve.
Make sure that the water supply going to the dishwasher is HOT. Detergent will not disolve in cold water.
Sep 15, 2009 | Kenmore 18 in. 14432 / 14439 Built-in...
Dishwasher only a couple of months old. Ran it
The water may not be hot enough. Increase the temperature of the incoming hot water or try this: put the tab in the open soap cup so it will start to dissolve during the pre-wash. Then it will finish dissolving during the main wash. If the dishes get clean using this method you may not have to increase the water temp.
Aug 25, 2009 | Dishwashers
Hi, we have an LG dishwasher, model # LD-1403W1 and for a while now [intermitent] once we put on an Eco cycle using Finish balls soap block, sometimes the door flips open and other times it doesn't. But...
trust me. use cascade powder.and if you have the option select a strong spray.the answer ,hopefully is bad soap .ps dont use the eco cycle.eco means crappy cycle.thank you.
Aug 08, 2009 | Dishwashers
Tablet falls to the bottom of tub but wont disolve
The newer Whirlpool dishwashers have little slots in the top of the soap dispenser to allow water to seep in during the first water fill. This design allows the tablet to begin to dissolve during the first fill then be usefull when the soap door opens. In your case, I would check to see if the soap dish is opening at all. Perhaps one of the racks are not allowing clearance or the soap door itself is sticking closed.
Let the dishwasher fill, drain, and then fill again. Open the door of the dishwasher and see if the soap door is still closed and if so, there is your problem. Also, at this time, check the water temperature. It should be at least 120 degrees F for the soap to be effective.
Hope this helps, Ken
Jul 17, 2009 | Frigidaire Dishwashers
Soap packets don't melt/disolve
sounds as if you amy have a problem with the dispensor door not opening correctly perhaps opening at end of cycle when all water is already released.Ive seen that sometimes the "tabs" or "packets of detegent are too tall and interfere with normal opening of the latch mechanism. manufacture would reccommend using powder instead.
Nov 04, 2008 | Dishwashers
Saop not disolving
Low water pressure. Caused by not enough water in machine (water valve or house water supply). Also could be pump screen is clogged up (bad chopper assembly) Also could be caused by spray arms themselves being clogged. (goes hand in hand with pump screen being clogged) These are the 3 most common problems i have seen and all could cause low water pressure in the machine. This is assuming the dispenser door is opening!
Apr 28, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dish soap not disolving
Is the water heating up? This may be the problem.
Apr 14, 2008 | Dishwashers
Soap not dispensed and dishes not washed
water is getting past the gasket during the start up cycle. by the time the door opens, the water has caked up the soap. also, its not clear when in the cycle the door is opening.
try using liquid soap.
also, take a peek just after the machine has finished filling and starts washing to see if the door is opened on the soap disp.
good luck
mark
Dec 19, 2007 | LG 24 in. LDS 5811 Built-in Dishwasher
Dishwashers Logo
62 people viewed this question
Top Dishwashers Experts
