Question about Toshiba e750 Pocket PC
E750 use with Garmin 76 GPS
I want to use my E750 with my Garmin GPS 76S and have a Prolific serial bridge connector to the USB on my PDA. THe serial bridge works on my home PC OK but when connected to the PDA , the PDA recognises it is connected but will not work with it. I have been unable to load the supplied driver into my PDA. Does anybody know how to convert a driver file to work with a PDA or does anybody know of a driver that will work with the cable that I can download to my PDA or is there another cable such as the PA3323E-1ETC from Toshiba that I can make the connection between my PDA and GPS with.
    Master:
  • 903 Answers
If no one has any solution for your issue in my opinion you should check the manufacturer’s site. Maybe there you can find out if this unit is compatible with your PDA. Usually you can find it under support or FAQs.
Posted on Sep 08, 2005
Where can I locate and download a windows PC driver for NS-PU99501
The Insignia NS-PU99501 USB to serial (RS-232) converter cable should be a plug and play item with Windows 7 and 8. This assumes an active internet connection and Windows Update is set to search for drivers for new devices. See https://www.insigniaproducts.com/pdp/NS-PU99501/5883029 and go to the Support & Downloads tab to find the manual and the driver for a Macintosh OS.
The Prolific chipset in this Insignia device is the PL2303. For other Windows versions, try http://www.prolific.com.tw/US/ShowProduct.aspx?p_id=225&pcid=41 for the driver.
I hope this helps. You may need to check the chipset suffix with the tool on the above Prolific support site.
May 15, 2018 | Computers & Internet
Device cannot be found when connected to P.C
Assuming the USB cable / connector and PC port are working properly - it could be a loose internal USB jack. Wiggle it carefully when USB connected to see if it will connect.
Jul 04, 2011 | Garmin GPSMAP 76 GPS Receiver
Garmin 76S handheld; power shuts off with a black vertical line on the screen.
When I have seen this problem in the past it generally means it is time for a new unit or a repair. It is a hardware issue that a user can not fix. For your local repair depot please contact Garmin @ 1-800-800-1020
Jul 13, 2010 | Garmin GPSMAP-76S Handheld GPS Receiver
Garmin GPS 76S USB interface data cable
The convertor has a microchip in it to do two way signals. Not a DIY project.
Others are available online for less than $5-10.00. Try Ebay.
Good Luck
Mar 05, 2010 | GPS
5yr old Garmin 76s shuts off
KUDOS! Others with the same problem informed me that it is a softwear problem and to download the 4.0 version free on the Garmin web site....l'll do it ASAP and write again if it doesn't work...RG
Jul 19, 2009 | Garmin GPSMAP 76 GPS Receiver
Screen goes blank except for a black line
I had the same problem with my 76S. Called Garmin to send it back for service. They said it was a problem with new WAAS signals that causes the freeze/black line. Disabling WAAS using menu/system solved it for now. They are working on a software update Real Soon Now.
Oct 29, 2008 | Garmin GPS 76 GPS Receiver
Copy maps from c330 to 76s
No, it is not possible to copy the maps from the C330.
Jul 15, 2008 | Garmin StreetPilot C330 GPS Receiver
Gps repair service
You find details to get a service in your area on last pages of your user manual.
Jul 12, 2008 | Garmin GPSMAP 76CSx Handheld GPS GPS...
SD GPS
I have read some Information about Toshiba PDAs. There is a technique called SD™ IO card. In the technical specifications I found this Info: 1 x SD™ card slot (supports SD™ memory card, SD™ IO card, MultiMedia card) So when SD™ IO card is the same as Bsquare SDIO Now! tecnique...
Sep 08, 2005 | Toshiba e750 Pocket PC
Toshiba e750 Pocket PC Logo
136 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
