Question about Pioneer SD-533HD5 53" Rear Projection HDTV
Greenish color when using component to RGB connection
Currently own a SD-533HD5 HDTV Projection. I tried to hook up a 6ft HDTV SVGA (HD15) to (3) RCA Male Component/RGB Video Cable, Gold Plated Connectors from my Toshiba HD-A3 DVD Component out to the SD-533HD5 HDTV using the RGB input connector. The end result was, every single movie I try to view is coming up GREENISH. The pictures are there but all in GREENISH color.
What am I doing wrong? Please advise.
    Scholar:
  • 136 Answers
Either the problem of convergence ICS or the problem of convergence settings.
for replacement of ics click this link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
for the settings click this link
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
thanks.
Posted on Oct 12, 2008
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
How do i switch my sd-533hd5 to hdtv
the only way to do this is u most upgrade ur cable box to hd box then connected to a component with the color green blue and red on the back of ur tv
Nov 03, 2010 | Pioneer SD-533HD5 53" Rear Projection HDTV
Cannot use convergence on remote for Pioneer SD-532HD5Pioneer SD-532HD5Pioneer SD-532HD5Pioneer SD-533HD5 53 in. Rear...
Ur convergence it dead.Must know how to solders.Tries these Websites.Tv Repair World.com,Tvrepairkits.com to buy a convergence kit.
Dec 29, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
My sd-533hd5 53in.the colors will divide into the blue green and red. then blow a fuse ?
from what i have had in the past was with this problem was convergence problems but it seems to be something originating from your main board.
Nov 06, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
When componet is hook up for hd
My first guess would be that the component connections are not matched. Check the component method and make sure that both the source and the TV are set the same. There are two methods:
1) RGB
2)Y,Pr,Pb
If the set is set for RGB and you are sending Y,Pr,Pb the picture will look a bit purple.
Dan
Jan 28, 2009 | RCA HD61W66 61" Projection HDTV
Connect Macbook Pro to Component input
you should be able to use an SVGA to component rca connector on any component input - i have a wd-65513, and thats how I have my pc hooked up to it. I could also never get a clear picture using the SVGA plug on the back of the set.
Jan 12, 2009 | Mitsubishi WS-65513 65" Rear Projection...
My television has a green tint to the picture...help
go into the tv picture settings and there should be an option for colors and try turning the green down, sorry its not an exact solution but i dont own one so just trying to help
Dec 30, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
15 pin RGB Input
You are wasting your time if the component you're hooking it up to is not High Definition... Tv can't produce any better quality from connector to connector you have to up the type of signal being input.
Bill
Mar 09, 2008 | Pioneer SD-582HD5 58" Rear Projection...
B & W only..no color
plug out the tv and let it stand for a while the you plug it in back again, if that does not work then call a tech to reset it for you.good luck.
Apr 06, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Flashing Green
I would guess that your problem is similiar to mine but mine is with the color red. The CRT went out which is a 400 dollar part and who knows how hard to fix.
Nov 21, 2006 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer SD-533HD5 53" Rear Projection HDTV Logo
123 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
