Question about Sony RDR-VX555
REMOTE WILL NOT WORK
REMOTE IS NOT WORKING AND GETTING DVD-3 ALERT
  • timtrudeau Sep 05, 2008
    The remote will not work. all that come up is dvd 3
  • Anonymous Feb 14, 2009
    I accidently pushed for the DVD1 instead of DVD3 and now my remote will not work even when I press ENTER and 3.
It works!!!!!!!!!!
Posted on Apr 06, 2009
Hold down enter then hold number 3 both at same time for 3 seconds then release and it should work.
Posted on Oct 28, 2008
Sony remote RM-DX500 not working with Disc Explorer 400 DVP-CX985V, but does work with tv. How can I program it to work the dvd player?
There are 2 set's of command switch's for the dvd player, a 3 position command switch on the back side of the dvd player and another 3 position command switch on the inside of the remote right next to the batteries, easiest option is to remove batteries from remote and test each one of the 3 position switch's labeled 1,2 & 3 and test remote control.
Oct 11, 2010 | Sony DVP-CX985V Multi-disc DVD Player
I cant get my remote reverted back 2 factory settings because it wont work at all because its the player is set in dvd 3 and the remote is not ....so how do i reset it if it wont work at all
If your unit is displaying DVD2 on the front panel, you will need to set the command on the remote to match the display on the unit.
Point the remote to the unit and press 2 on the remote. Them press system menu on the remote, you should be ok.
Apr 23, 2009 | Sony RDR-GX355
Remote Control Code problem
I read through other problems on the web page and tried them
Finally I got one of them to work
Thanks
Feb 28, 2009 | JVC DR-DX5 DVD/HDD Recorder
My remote control to RDR GX3 Sony DVD recorder does not function. When put on TV it works but does not work on DVD setting
Please change command mode on dvd recorder remote as it has 3 modes, dvd-1, dvd-2 and dvd-3. command mode switch is located at bottom part of remote.
DVD Recorder default command mode is DVD-3
Jan 30, 2009 | Sony RDR-GX3 DVD Recorder
My remote doesnt work my dvd recorder it saying 3 check remote
THE aswer is in the manual that can be had on line. You have 3 different remote typse, 1,2,3, All you have to do is hold down the ENTER button and the number 1 or 2 or 3 for a few seconds and it will change the setting. When getting the error "3 check remote" that said you have it currently on setting 3. Try 1 or 2.
Dec 11, 2008 | Panasonic DMR-E50 DVD Recorder
Can not get my sony dvd to get off of dvd1 and it is now locked u
Go to your DVR and manually turn the DVR off. Press the STOP button for
two or three seconds. The DVR COMMAND MODE setting will display in the
DVR window. (DVD1, DVD2 or DVD3)
Set the remote to the COMMAND MODE setting that was diaplayed by depressing
both the remote ENTER key and the desired number key (1, 2 or 3) and holding
them both at the same time for 3 seconds.
You can now use the remote to set the DVR to the desired COMMAND MODE.
To do this depress SYSTEM MENU on the remote and go to SETTINGS and then
COMMAND MODE. Select either DVD1, DVD2 or DVD3. Once you delect a setting
that is different from what was set, your remote will stop working again.
Reset your remote to the desired COMMAND MODE by depressing the remote ENTER
key and the desired number key (1, 2 or 3) and holding them both at the same
time for 3 seconds. The remote should now control the DVR.
Nov 14, 2008 | Televison & Video
Command mode
I did the same thing and lost all remote control to the recorder. Try holding ENTER & 3 in unison for as long as it takes (30 secs or more ) to view change on TV screen. This should get u back to system menu where u can change back to dvd 3 (default ) If doesn't work get a one for all remote and enter code 0533 which will get u in to the recorder command lines. PS enter & 3 worked 4 me.
Oct 22, 2008 | Sony RDR-GX300 DVD Recorder
Remote is stuck in dvd 3 mode
  1. On your remote, push and hold "Enter"
  2. At the same time, push and hold "2"
  3. Keep them down for about 5 seconds
  4. Your remote should now work with the unit
  5. You can go to the set up menu and change the unit back to DVD3 if you wish, but you'll then need to repeat these steps using the "Enter" and "3" buttons
Oct 08, 2008 | Sony RDR-VX525 DVD Recorder/VCR
Cant get jumbo remote to work for my tv
If it's an Innovage brand jumbo remote, try this...
There are 2 different versions of the Innovage Jumbo remote, an old and a new.
For the old version:
1. You have to have the TV or DVD turned OFF.
2. Then, you have to push CODE SEARCH button once for 3 seconds till it lights solid
3. Then press TV (or DVD) button once till it lights once and turns solid and press the ON/OFF button very slowly and repeatedly as many as 300+ times to wait for the TV (or DVD) to go on.
4. Once it goes on...STOP and IMMEDIATELY press ENTER before you pass up the code or you'll have to start over!
This is very frustrating but my advice is to take it slow and methodical. Think the tortoise and the hare...if you go too fast, you'll redo it several times because you'll keep passing it up and accidentally turn the TV on and off suddenly and miss the code.
For the newer version:
1. Turn the TV (or DVD) ON.
2. Press CODE SEARCH once and it blinks.
3. Press TV (or DVD) once and it blinks.
4. Press ON/OFF button only ONCE.
5. Wait as it automatically searches for the code by itself. It will have a slow long blink between each code it searches.
6. Stay alert because when the TV (or DVD) goes off, you IMMEDIATELY have to push ENTER to lock in that code before it goes onto the next one. (which it will even if the TV is off)
Apr 25, 2008 | Big Button TV Universal Remote
Open Questions:
See all Sony RDR-VX555 Questions
Sony RDR-VX555 Logo
324 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
