Question about HP iPAQ hw6515 Pocket PC
Ipaq 6515 & WLAN?
How is it possible to connect to WLAN with 6515, as I understand from specs, no WLAN connectivity is integrated. I like to buy this model, because of all the specs but I mis the WLAN option. What do you suggest to overcome this problem?
The sd wifi cards are not s good because mini sd memory cards are overpriced. get a mini sd wifi card (wich is supported on the hw6515 i'm nbot sure about other models) this will free up the sd slot for cheep sd memory
Posted on Jan 21, 2008
Buy a WLAN sdcard to get WiFi connectivity. You will still have the second minisd slot available for a memory card.
Posted on May 24, 2007
On a new iPAQ 111, I can't connect to a network wirelessly
Have you tried resetting your iPAQ? You do that by pushing the little button on the side with the stylus. The screen will go blank for a bit, and then windows will restart. I had bought mine used, and when I got it, I had the same problem in that I never got the screen that let me select the wireless network. It fixed mine. Once it is working again, try selecting "View WLAN Networks" again, and you will see a list of networks that it can hear. If the SSID Brodcast is enabled on your wireless access point, you will see your network there. If SSID is not enabled on your WAP, you will need to type in the name of your network before it will find it.
Hope this helps. Sorry it was so late in being posted.
Jun 30, 2010 | HP iPAQ 111 Classic Pocket PC
Hp ipaq wont charge from usb cable. turns on for a few seconds nd loads but then turns off. it wont fully charge.
On the the IPAQ 6515 and others, there is a USB Power option that you must enable to 'slow' or 'fast' charge from USB connection.
Jan 13, 2010 | HP iPAQ HX4700 Pocket PC
My hp ipaq hw6515 does not read my Afghanistan's sim card
The IPAQ 6515 will only work with GSM Simm and network. It is also NOT 3G compatible.
You can verify that the 6515 is working with another network SIMM, then it is likely that your Simm card is not compatible and may in fact be design on Afghanistan's 'Analog' network.
Incidentally, the 6515 will also not work in Japan even with a working 'roaming' SIMM as the Japanese Mobile Network is also not compatible!
Hope it helps!
Dec 15, 2009 | HP iPAQ hw6515 Pocket PC
How do I set-up my WLAN card to my HP iPAQ Hw6515
The HP IPAQ 6515 will support WLAN access via a SDIO WIFI card (which looks like a 'long' standard SD card): it is just a bit tricky to get this add-onl SDIO WIFI card to work properly!
For more deatils and confirmation, please google:
ipaq+6515+sdio+card
Sep 29, 2009 | HP iPAQ hw6515 Pocket PC
IPAQ 6515 doesn't recognize new HP 8Gig SD card
Your 8 Gig card is a SDHC (HC=High Capacity) Card. All HC cards use a different format, which the 6515 can't use...
The biggest capacity the 6515 can use is 4 gig on the SD and 2 gig on the mini SD.
My 4g Transcend card and 2g Sandisk cards have been faultless for about 2 years now.
Sorry, but the 8 gig card is a wonderfull card, but is useless in a 6515
Dec 13, 2008 | HP iPAQ hw6515 Pocket PC
Lost '25 character code' for install of cd to hp 6515.
The code you are referring to is probably the license key for Microsoft Outlook. If you have lost the key you can buy Microsoft Outlook from any good computer stores. The other application you will need for Outlook to sync with the ipaq is Microsoft Activesync which is free and does not need a license key. You can download activesync from Microsoft website or from the cd.
Sep 21, 2008 | HP iPAQ hw6515 Pocket PC
My hp ipaq hw 6515
Try soft resetting your ipaq. If that didnt work then try hard resetting it, note that you will lose all the data in your ipaq
Oct 23, 2007 | HP iPAQ hw6515 Pocket PC
Is IPAQ rz1710 bluetooth technology compatible or not ?
The 1710 does not have bluetooth. You would have to buy a SD bluetooth card and then you could connect to the internet via a bluetooth phone if the phone had internet access.
Sep 08, 2005 | HP iPAQ RZ1710 Pocket PC
Hard Reset HP 6515
Hold down the POWER button and press the reset hole for approx 5 seconds, then remove stylus from reset hole first, follow by release of POWER button.
Sep 07, 2005 | HP iPAQ hw6515 Pocket PC
HP iPAQ hw6515 Pocket PC Logo
212 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
