Wireless G "repeaters
Think I entered my 2nd question in the wrong place (comments). Please see original string. Thanks, Joeneedshelp
    Sergeant:
  • 264 Answers
I did check the same. Thank you
Posted on Sep 04, 2008
12/24/2012: XBOX 360/RB3-WIRELESS FENDER MUSTANG PRO-GUITAR: WON'T PLAY "FRET NOTES"
If your guitar was not purchased new (since it was hard to find these guitars late in the life cycle) then perhaps it was already faulty before you received it.
Dec 25, 2012 | Mad Catz Rock Band 3 Wireless Fender...
I placed the motherboard into a new case. I think the new case had a defective power switch. it would not start. I put back in the original case and the computer attempts to start and stops and keeps...
> attempts to start and keeps repeating
Please be more specific.
Do you get the initial "splash" screen, and then some white-text-over-black-background,
giving RAM size, processor ID, and such?
Do you see the "press DEL to enter BIOS SETUP" message?
What else do you see?
Is a disk-drive attached to the motherboard?
Does the motherboard try to boot from that disk-drive?
Nov 15, 2010 | Computers & Internet
HOW DO I CALCULATE STANDARD DEVIATION FOR CALCULATOR T1-30XA
Hi dear friend,
I am providing it with an example.
- I am sorry that the instructions from the maker of the calculator on how to calculate a standard deviation fell short of your expectations. All you have to do is follow them key stroke for key stoke, but enter your own data. If a number is repeated 3 times like the number 55, you can enter it 3 times or use the shortcut in the exemple
55 [2nd][FREQ]3 [Sigma+].
If you make a mistake and enter the wrong number, use the [Sigma-] key to remove it. That is similar to what a cashier does when an item is entered twice: it is entered a third time but with minus sign.
Every time an item is entered, the display shows the total number of items so far. When it is finished the cashier press the key that sums up the prices to get the total. This is the role of the [2nd][Sigma X] key combination.
The average number of the data is obtained by the [2nd][x bar] combination. The last two key combinations display the two type of deviations.
I hope this will help you. Please vote for me.
Thanks in advance.
Jan 30, 2010 | Texas Instruments TI-30XA Calculator
How do I find the standard deviation?
Here is a detailed exemple. Hope it helps.
Some comments on the various variables (should the information be needed. If not need, please skip it.)
1.All you have to do is follow the instructions key stroke for key stoke, but enter your own data.
2. If a number is repeated 3 times like the number 55, you can enter it 3 times or use the shortcut in the exemple
3.If you make a mistake and enter the wrong number, use the [Sigma-] key to remove it. That is similar to what a cashier does when an item is entered twice: it is entered a third time but with minus sign.
4. Every time an item is entered, the display shows the total number of items so far. When it is finished the cashier press the key that sums up the prices to get the total. This is the role of the [2nd][Sigma X] key combination.
5. The average number of the data is obtained by the [2nd][x bar] combination. The last two key combinations display the two type of deviations.
Check the theory you have been taught and try again. If that is not the type of statistics you were supposed to do, then give more information.
Oct 28, 2009 | Texas Instruments TI-30XA Calculator
I could see my SSID, full signal but could not connect
I think the best thing to do is to get in touch with your VOIP provider, as they will likely provide you with free customer service on this issue, AND they are able to remote into the product, and show you the correct configuration and method for setting it.
Hope this helps!!
Jim
Aug 06, 2009 | NetGear WGR614 Wireless Router
Going from wireless to USB install
Turn the wireless radio off on the printer so that it is not connected to the router. 1. go to menu-wifi settings and turn it off.
Kindly Go to kodak all in one home center software and click on connect your Kodak printer. select through usb cable and click on next. printer drivers will be installed. go to control panel-printers and faxes and set the printer to default you are ready to go my friend.
Apr 06, 2009 | Kodak ESP 5 Printer
I have 2 3COM 3CRWE454G75 -> AP, it does work in AP repeater mode
find the ip address problem or the firewall of there or proxy servr is there and re-configure it then you get the it and check the region if not same that also creating problem sir,
Mar 04, 2009 | 3Com OfficeConnect (3CRWE454G75)...
Sansui TVS3245A
Use the audio select button on the original remote. Press it repeatedly until "mono" appears on the screen.
Oct 06, 2008 | Televison & Video
Linksys WUSB300N Wireless Adapter >>> Response to Response
please rate this so it is closed unless you want to try further troubleshooting
Jul 08, 2008 | Linksys WUSB300N Wireless Adapter
Executive business analyst constant memory
Clear calc and mode registers & select two decimal places- ON/C, 2nd, CMR,FIX,2
Select FIN Mode - 2nd, FIN repeat until FIN shows up in display
Enter months in mortgage - N
Divide annual interest rate by 12 - Enter result as %i
Subtract down payment from cost of home - Enter result as PV
Compute monthly payment - 2nd, PMT
for Payments at beginning of month , press DUE, PMT
I have a question for you, what battery does the TI BA-II Constant Memory calculaor use?
Much thanks.
hgeiss@comcast.net
Oct 28, 2007 | Texas Instruments BA-II Plus Calculator
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
