Question about HP Pavilion s7310n (EN996AA) PC Desktop
Cd rom the computer is stating that the cd rom /burner is not connected
    Sergeant:
  • 241 Answers
In windows go to the Control Panel+ Performance Maintance+System(system properties) + Hardware+ Device Manager from the list select disk drive and select the one that you are trying to access and on the general tab make sure that the drive is enabled.
NEXT In my computer right click on the drive and properties make sure auto play is selected for music. And then also if you have more than one CD/DVD drive you it can possible that the drive is set not to play video and music. The too you will find in the properties menu.
Posted on Aug 28, 2008
How do i install this drive?
Unplug the power cable from your power supply and open up your computer Don't forget to wear your antistatic wrist band. Determine which drive bay you are going to install a CD-ROM into. You should pick on of the uppermost drive bays. Before you install a CD-ROM, make sure you have the proper jumper settings. Since we are only installing a single CD-ROM, set the jumpers as MASTER. The jumper settings are different for each CD-ROM drive, so consult your owner's manual so you know which pins to cover up. Once you have the jumpers set, install your CD-ROM in the computer's case. How you secure the CD-ROM in one of the uppermost drive bays depends on your case. Some CD-ROM drives have to be screwed into the drive bay, while other cases come with brackets (like mine) to attach to the CD-ROM drive so that it slides into the drive bay and locks in place.
Connect the power to the back of the CD-ROM drive, then connect the ribbon cable to the back of the CD-ROM drive. Your ribbon cable has three connectors, one in the middle and one on each end. The middle connector is a "SLAVE" connector that is used if you would install an additional CD-ROM or DVD-ROM drive.
Connect one of the end connectors to the CD-ROM drive, and connect the other end connector to the appropriate spot on your motherboard. Note, hard drives and CD-ROM drives have the same style of connector on the motherboard. You want to connect your CD-ROM drive to the motherboard slot that isn't red or is the highest numbered of all the IDE slots.
Power on your computer after you plug it in. Your computer should recognize the new CD-ROM. If it doesn't, Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver
Hope this helps
Jul 04, 2011 | LG GH22NS50 22X DVDRW SATA Drive OEM...
I have an ATAPI DVD A DH16ABSH Dvd CD rom in my Gateway computer. It keeps on disappearing and reappearing in the computer. This computer was bought back in January. What makes it do this?
Sound like the Connectivity cable is either loose or there is a problem with your dvd rom burner check the cable that it connects to if it looks fine then contact or return the dvd rom burner for a different one
Jun 27, 2011 | Computers & Internet
I have a hp dv9700 and my cd player will not read Missing from My Computer DVD Rom (E)
Check the cables, either DC supply to CD Drive or Data cable from CD Drive to Mainboard (Sata or Pata connection)
Aug 11, 2010 | HP (350208-001) CD-RW/DVD-ROM (Combo)...
Cd dvd / driver issues
I would suggest downloading Driver Magician. There is a small fee to register the product but once this is done it searches for and updates all drivers on your machine. Worked like a dream for me.
May 02, 2009 | HP DVD1040i 20x Super Multiformat Dvd...
Cd burner not being recongnized
XP provides buring software for CD-ROMs
First check device manager to make sure CD-ROM is listed. If it is listed, try to use XP to write files to the CD.
Norton should not have affected the CD writing capabilities.
If you cannot write to the CD, use device manager to remove the CD-ROM, and then restart your computer. New Hardware utility will reinstall the required software
Apr 15, 2009 | Computers & Internet
Laptop DVD-CD-ROM wONT WORK
the connection wire of your laptop with DVD ROM has been got tampered . nothing to worry it is just alittle problem go to any repair shop & get it repaired.
pls rate my solution
thankyou
Feb 12, 2009 | LG GWA-4082N DVD RW Dual Layer Burner
DVD/CD DRIVE NOT WORKING
Check the cables if they are connected properly and see if the cd/dvd rom is first detected in bios..
Jan 28, 2009 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
ACER 9410CD/DVD-ROM driver not found.
I am assuming you are using XP,
update the drivers via device manager and select the device with the yellow question mark,right click update,reboot and restart
if nothing then remove the device via add/remove programs
select device and remove,reboot and restart
should auto recognise and install the drivers for you,
dont forget to do SP2 updates
Good luck with that,
Let me know how it goes thanks
Aug 14, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
HP Pavilion s7310n (EN996AA) PC Desktop Logo
53 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
