2003 Mitsubishi Lancer Logo
Posted on Aug 28, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replacing front wheel bearing
Just wanting to know how difficult it is and if any special tools are required to change the front wheel berings on my 2003 mitsubishi lancer
  • 1 more comment
  • Anonymous Aug 29, 2008
    how do you get the bearings out?
  • Anonymous Nov 21, 2008
    I have the same problem and can anyone tell us how to replace it and is there any special tools needed for the work?
  • Anonymous Oct 21, 2012
    have a set of mm wrenches and sockets
Anonymous
Level 3:
President:
  • Master 1,263 Answers
  • Posted on Aug 28, 2008
Anonymous
Master
Level 3:
President:
Answers
1263
Questions
Helped
682689
Points
4577
Those are sealed units and are intergrated with the wheel rotor if the bearings are bad they must be replaced and those are dealer only items. labor for each side is about 1 hour for remove and install per side. unfortunately there are no aftermarket parts available just yet. hope this helps
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 15, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2592
Points
When removing the old hub do i have to relese the struts ? what is the proper procedure when removing front wheel hub on 2004 mitsubishi Lancer
Anonymous
Level 1:
  • Posted on Sep 30, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2592
Points
I have Datsun 100A car.I need to change front wheel bearing,where I get it and what is the number of the bearing for replacement
2answers
WHAT IF ANY SPECIAL TOOLS ARE NEEDED TO REPLACE A REAR WHEEL BEARING ?
No.
The most you'll need is a big hammer or a air hammer to loosen the bearing from the spindle but just like changing a front bearing
Hyundia matrix 1.6 is it hard to change a drivers side ball joint ?
It is very difficult and requires special tools and skills, you will also need to have the front end aligned after the part change.
FRONT WHEEL BEARING ON 2005 MAZDA 3 ARE THEY PRESSED IN?
2005 mazda 3 front wheel bering left side are they pressed in and tools needed 2 replace bering
1helpful
Repair front wheel bearing assembly
no special tools in particular just the usual or necessary tools required.. 1stly u remove the Tyre and the caliper then u'll see something like a long rod dats the bearing
2helpful
2answers
Noisy front wheel bearing I would like to rerplace
a hydraulic press ,or go to a recon shop ,i was knocking one out and a splinter hit my mates eye ,nearly lost his eye ,HAVE THEM PRESSED IN AND OUT
12helpful
Front brake rotor removal
Your rotors have an integrated hub with serviceable bearing.
Remove the six bolts around the center of the hub and pry off the grease cover.
behind it you will find a locking wheel with two philips screws holding it in position. Remove the screws and unscrew the locking wheel.
Behind is a large axle locknut that requires a special tool to remove. It has two small holes to grip with. Unscrew it and you will be able to remove the outer bearing, then slide the rotor off the spindle/axle.
From there you can unbolt the rotor disc from the hub backside, or replace the whole unit. Replacing the whole unit will require installing new bearings/races, however.
Either method will require repacking the bearings and loading the bearings with the special locknut tool.
Front wheel bearng replacement
hi i am rather family with this type of jag and the wheel bearings can be a bit tricky and you was right special tools to do the job are reqiered my advice is let a proffesional mechanic do the job it will save you a lot of hastle
dean
Inner wheel bearing
The inner wheel bering is held in with a plate that is screwed in. no special tool is needed. You must remove the bearing housing from the brake disk. It took me 1.5 hours to do both sides.
Top Mitsubishi Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Mitsubishi Expert? Answer questions, earn points and help others
