Question about Bosch Classixx WFC 2465 Front Load Washer
Cold/Hot water I cannot figure out how to put the water on cold...it is always on hot and i believe i am following what the washer says is hot and cold water
  • smartblond10 Aug 29, 2008
    thank you..i will try this
    President:
  • 1,462 Answers
If this is a machine with two fill hoses, then you have them the wrong way round. to check, put on rinse and cold water should come in. if not, swap the hoses round. don't rely on what you house plumbing says is hot or cold - this is often wrong
Posted on Aug 28, 2008
I believe the water temp switch is bad. It will start filling on warm then stop if I put it on hot it will fill with cold water. I have cut the hot water off to achieve this but when it reaches rinse it...
it sounds to me that the hoses are connected to the machine incorrectly. Typically if the plumber ran the water lines behind washer correctly the hot pipe is on the left and the cold pipe is on the right sometimes thats backward and be determined by touching hoses while filling on warm setting and see which hose feels hot. On the back of washer they where they connect hot goes on the bottom and cold on top
Aug 08, 2011 | Estate ETW4400VQ Top Load Washer
I bought this front loader no more than 2 years ago-I dont like using hot water to wash my clothes so I always put in on the cold-now no water wants to come through the washer-it only works if my hot water...
Sounds like the water inlet valve is faulty. It the part that attaches to the hot and cold water hoses. It really easy to fix, just disconnect the hoses, pull the washer out and remove the back of the washer to get access to the valve. You can find a replacement by going to your local appliance supply house, or online such as www.repairclinic.com.
Jun 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
It will not fill from cold water for either wash or rinse. Timer advances and hot water works.
Remove the cold water hose and make sure the screen in the washer inlet is not plugged. Put the hose in the tub and turn on cold water if it flows freely and your screen is clean unplug washer and remove the hot/cold water inlet and replace. You should be able to get parts locally. Of course you can always get them on the net.
Aug 08, 2010 | Washing Machines
Maytag performa washer hot/cold cycles reverse, hooked up correct
This sounds like a cold water supply problem that's usually caused by a problem at the water inlet valve. First, remove the water supply hoses and check the small screens inside the water inlet valve. Make sure they are not clogged with rust or debris. Next, check the solenoids using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty solenoid and the water inlet valve assy will need to be replaced. I will attach a photo for reference. Hope this helps and best wishes.
Aug 10, 2009 | Maytag Performa PAV2200
Washer Fills HOT WATER ONLY
If you checked the screens at the water inlet valve and they were not clogged, then you probably have a defective water inlet valve and will have to replace it. Hope this helped.
Jul 19, 2009 | GE WJSR2070B Top Load Washer
Bosh error code E02
Hi. I had the same problem with my Bosch washing machine and called Bosch...was told the same thing...$99.00 for service call. I managed to fix my problem by doing the following:
  • Removed hot & cold water supply hoses.
  • Took filter screens out of both hoses.
  • Removed filter from cold inlet on back of washing machine. I noticed some oily buildup on both of the cold screens so opted to not put any of them back in.
  • Then I put hot & cold water supplies back on the wall hookup, but crossed the lines where they came into the back of the machine intentionally so that the hot water line fed into the cold side of the washing machine and vice versa.
  • Then I ran a couple loads on "cold" which was actually hot water coming in to the machine.
The reason I did this was that I figured there must be some more waxy buildup inside the machine in the cold lines and hoped the hot water would melt it like when you rinse a greasy pan under hot water. IT WORKED!!! I hope this helps you.
Sep 29, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Maytag mav6000 hot/cold problem
hi try to just regulate the temp by turning down the water flow from your taps if more cold is coming in than hot turn cold water down a bit to your satisfaction thanks THE APPLIANCE DOC
Sep 05, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Frigidaire Front Load Washer Shrinking clothes
check to make sure you water line arnt hooked up backwards. if hot is to cold and cold to hot your washing in hot water when your trying to use cold
Nov 20, 2007 | Frigidaire 14 Cycle Tumble Action Washer
Bosch Classixx WFC 2465 Front Load Washer Logo
59 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
