Question about Simplicity Fashion Pro SW2145 Mechanical Sewing Machine
My stop motion knob is stuck.
I released the stop motion knob counter clockwise and threaded a new bobbin. The know is stuck and won't turn clockwise. My machine is only a year old.
  • 23 Answers
SOURCE: Simplicity SE3 Threading simplicity lets you download manuals for free. I am not certain this is your machine but try the link above
Posted on Jul 11, 2007
  • 323 Answers
SOURCE: stop motion knob won't tighten
Remove the stop motion wheel and you will see another part that is loose(looks kind of like a washer with ears on it). Reposition this on the shaft and put the stop motion wheel back on. The stop motion wheel was too loose and it allowed the washer to fall off the shaft. The screw is nice to have and it keeps the washer from falling off the shaft but it's not absolutely necessary to use the machine. Just be caredul when winding the bobbin.
Posted on Dec 05, 2008
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
  • 108 Answers
SOURCE: When I try to manually bring up the bobbin thread
i was able to find one at
Posted on Feb 15, 2010
  • 23 Answers
SOURCE: Bobbin thread comes out in a mass of threads
ENSURE you have threaded the bobbin properly and at the right tension. Also, ensure that you have routed the bobbin thread properly in the bobbin case.
Posted on Apr 13, 2010
To load the bobbin with thread do you turn the knob towards you or away my is jammed tight
If you are talking about the "inner" wheel on the handwheel that disables the needle action, you need to turn it counter-clockwise to wind the bobbin. When finished, turn it clockwise to enable stitching.
Nov 06, 2017 | Sewing Machines
My machine is not picking up the bobbin thread. What do I need to do?
You may have a) your needle in backwards; b) the bobbin thread not put in properly, i.e., counter clockwise/clockwise, whatever your manual says, or c) you are turning the knob the wrong way. Check your manual and look at the pictures closely. Sometimes they are a bit confusing. Good luck!
Jul 12, 2015 | Consew Sewing Machines
Release stop motion knob won't move
What are you calling a stop motion knob? Are you trying to stop the needle from moving while winding a bobbin?
Jan 31, 2014 | White Sewing White 3032
How to wind bobbin on white 1418
1 Release the stop-motion knob on the right side of the sewing machine by turning it oward you.2 Place a spool of thread of your choice on the spool pin located toward the back of the sewing machine.3 Pull thread from the spool through the threading knob on the top of the machine.4 Pull 2 to 3 inches of thread through one of the holes on the bobbin. Hand-wrap thread around the bobbin in an anti-clockwise direction five or six times.5 Place the wrapped bobbin on the bobbin spindle.6 Push the winder spindle to the right, against the stopper, and depress the foot pedal to begin winding.7 Wind bobbin until completed, then return winder spindle to its original position.8 Tighten the stop-motion knob.
Oct 14, 2011 | White Sewing 1418 Mechanical Sewing...
My Shark 7133 slowed down while sewing and stopped. The handwheel won't turn at all. I cleaned the bobbin area but it still won't work. The light switches on and the machine motor reves up but...
Slacken the stop motion as if to wind a bobbin and press on the foot control, if the motor runs really fast then you have either thread stuck in the bobbin case area or you may need to oil the machine
Sep 01, 2011 | Euro-Pro Shark 80 - 7133
I cannot loosen stop motion knob so that I can wind a bobbin.
Sometimes the knob locks so tight it requires a good strong beefy man to loosen it. Turn it counter clockwise!! You can also wind without loosening the knob, just MAKE SURE to unthread the machine and to sew for winding only. It works for all industrial machines, without loosening the knob.
Jan 15, 2011 | Brother Sewing Machines
I can only get a small amount of thread wound on the bobbin.It stops and wont take any more. The bobbin case keeps moving & I cant get it back in correct place
I assume you are placing the bobbin at the TOP of the machine, then wrapping the end of the thread several times around the bobbin in a counter-clockwise motion?
Have you made sure to "scoot" the empty bobbin next to the bobbin bar to the right? Is the thread going from your spool, directly TO the bobbin? Because it is supposed to wrap around the tension "nut" (where you start to thread your machine) before going to the bobbin.
Apr 24, 2010 | Brother XL-2230 Mechanical Sewing Machine
The thread and bobbin are nesting up in the bobbin case
Two things I have found that make my singer ce-200 nest. 1st. When I change threads, sometimes I thread it wrong - always nests when I do that. 2nd. When the bobbin runs out of thread it always nests for me, so I have to check the bobbin often. And I remembered a 3rd thing. 3rd. The area for the bobbin & bobbin casing has to be clean, no pieces of threads, and the bobbin casing itself can move, so make sure it's seated correctly.Whenever I get nesting, I take the metal cover off, under the needle, to get in and clean the bobbin area and under the needle good, before I go back to embroidering.
Oct 28, 2009 | Singer CE-200 Quantum Futura Computerized...
Threading bobbin on singer stylist 522
To wind a bobbin put the cotton reel on the top pin, take the thread to the left and round the little wheel and back to the bobbin that should be on the winder, wind the thread round a few times to take a grip, release the stop motion in the balance wheel, turn the winder button so the winder moves to the balance wheel and press on the foot control slowly.
When you put the bobbin in the bobbin case make sure it turns anti clockwise.
Jun 27, 2009 | Brother CS-8072 Computerized Sewing...
Simplicity Fashion Pro SW2145 Mechanical Sewing Machine Logo
75 people viewed this question
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Level 1 Expert
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
