Question about Bugaboo Cameleon Jogger
Turning the bassanet into a seat
I cant figure out what exactly what you mean because i cant find the metal rings.
  • 4 Answers
I didn't see your original post or the response, but the metal rings are on the seat fabric. I hope this helps.
Posted on Sep 22, 2008
How to clockwise the piston rings in gx 270
By clockwise piston ring do you mean clocking the piston rings?
If this is what you asking, that means the rings have gaps. when istalling them the gaps should not be aligned. If they are you will burn oil severely, the gaps are an open path for the oil to pump right on through to the combustion chamber. These gaps should be set approxamately 90 degrees apart. by the picture start with the wiper rings or bottom one move the 2nd ring approx. 1/4 turn or 90 degrees and repeat one more time with the upper ring. Now you can install the piston.
Please note that higher mileage vehicles have ridge or a raised ring
that you can feel with your finger nail at the top of the cylinder. This ridge will break the hardened steel rings if they are forced in the cylinder. Note: If the bore is not honed smooth or this ridge has not been removed and the cylinder is not honed all this work will not fix your problem. Doing this repair requires all new surfaces to seat and the oil should be changed after approx. 1000 miles be carefull with the oil addatives they may prevent the rings from seating. There are non detergent oils available for the break in period.
The reason for the change is to get the metal particulates out of the oil by replacing the filter and new oil.
Good luck I hope this helps solve your dilema.
Aug 31, 2015 | Vehicle Parts & Accessories
How do I take apart a 1962 corvair bucket seat
check the shaft of the knob for set screws, or just try forcing it off by pulling.
Jun 06, 2014 | Vehicle Parts & Accessories
What does pd mean on he inside of a ring. it does not have any other markings. it looks newer and has a cross with diamod like stones
A marking of "pd" on the inside of the ring indicates that the ring is made of the metal palladium. Palladium is in the same group in the periodic table as platinum, another metal used for jewelry. Palladium is a silvery color, extremely hard (difficult to scratch), and does not contain nickel (a common allergen).
Mar 05, 2011 | Watches
Cant stop seat moving on green machine 20x and the bolt wont go any tighter
I added a 2x4 between the seat bars and the cross brace, then used a long screw, fender washer, lock nut to secure the lower plastic and seat together. It was a terrible design to clamp two plastic items between a smooth metal bar in the first place, then on top of this to use a nut that is molded into the plastic and stretches out of the plastic with each stroke of the pedal.
Dec 29, 2010 | Toys
I can not figure out how to get the fuel pump out of the gas tank i have already dropped the tank and i just cant seem to figure it out . its a 1993 mazda navajo
On top of the fuel pump, there will be a metal ring around the edge, the ring will have some tabs, with a screw driver and a hammer, hit the tabs as to unscrew it, you will see the ring start to turn, keep hitting it till it comes off.
Sep 24, 2010 | Mazda Navajo Cars & Trucks
Cant remove the fan from the ceiling and the top ring wont turn
The top skinny ring that is made of plastic is the one that needs to turn. The metal bell shaped piece does not turn. My plastic ring would not turn either. I took a flat blade screwdriver and stuck it between the plastic ring and metal bell shaped piece. I gently pryed the plastic ring away from the bell shaped piece. The plastic ring has 4 screws that hold it in place, they are at the 8 oclock, 10 oclock, 2 and 4 oclock positions. The ring has to be turned counter-clockwise when looking up at the fan from underneath. Once the ring is off take the 4 screws out and the fan will come down.
Nov 15, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Removing seat covers on 2000 Jeep Wrangler Sahara
The seat covers are held on by "hog rings" They are steel rings that are clamped around the metal wires. You will need to use cutters to take them off. When you get ready to reinstall new covers, you will have to get a set of hog ring pliers, and some hog rings.
Mar 26, 2009 | 2000 Jeep Wrangler
Britax boulevard harness installation
Scroll down this page, someone was kind enough to take pictures.
http://www.car-seat.org/showthread.php?t=21629
Dec 08, 2008 | Baby Gear
HOW TO TIGHTEN MOWER BLADE NUT
check out www.toolpartsdirect.com for parts diagram for proper installation. the 2 last step is the square metal washer then the nut. to install the metal washer the match the shaft guide. if still can't tighten the nut then the problem is the armature ring may drop down.
Jul 04, 2008 | Black & Decker 19" Electric Lawnhog...
Bugaboo Cameleon Jogger Logo
35 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
