Question about Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker
Fridge problem G.E. side by side door FRIDGE wont cool and has occumulated frost in the cooler side they told as it was a control board but we but it they sent a replace ment and its smaller then the original one? mod# GSS22WGMACC
  • 93 Answers
Help me understand better. Frost build up in the freezer section on side by side? If so than you have a defrost heater problem or and, defrost themostat.
Posted on Aug 28, 2008
Fridge s/s cool on freezer but no air cooling fridge side
First, inspect the back wall of the freezer for frost build-up. Defrost failures are a common cause for incorrect fridge temps, and the frost will block air-flow even if your damper is wide open. if there is no frost, verify that the evaporator fan in the freezer is spinning, THEN check the damper door to see if it is open during cooling. Call a tech, guessing will likely lead to a broken machine and/or tons of wasted money!
Apr 26, 2016 | Refrigerators
I have a GE Refride. It is not cooling as it should. It has frost on the freezer side and it is cooler than than the fridge side but neither is cold enough to freeze anything you put in it, yet it is cool...
Sounds like it has a defrost problem. You should call a serviceman. Could be the heaters, defrost timer (or control board and related components), or terminator.
Jan 04, 2010 | GE Refrigerators
Not only will the fridge side not cool properly, now the door won't stay shut. Temp in fridge side stays 20 degrees warmewr than what panel says.what a pos.
Fridge problem- How to check everything
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Door problem-The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Aug 22, 2009 | Refrigerators
GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
May 30, 2009 | Refrigerators
Maytag Fridge (Model # MZD2766GEW) not cooling
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side.
Apr 06, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Fan runs constantly and does not keep temp cool enough
forst on the back wall means you have a defrost problem or a air leak aroudh the door gasket-mike
Mar 16, 2009 | Hotpoint 21.7 cu. ft. Side-by-Side...
Freezer is cool but not freezing or making ice - fridge not cold
If there is frost on the back wall of the freezer, then the compressor is running. Another (maybe) good thing is the fan is running.
The problem could be -
1) Bad defrost heater
2) Failed defrost sensor
3) Failed defrost timer or refrigerator controller board.
There are diagnostic tests to determine the problem, but require skill at using a multimeter and possibly reading a schematic/wiring diagram.
You can temporarily make the refrigerator run again for awhile by unplugging, opening the doors, and defrosting for 6-8 hours (store food in coolers.). Then plug it back in. Note, water may come out of the freezer as a result of defrosted ice.
Jan 15, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Maytag side by side not cooling
Hello Hellohiester,
Defrost circuit failure:
The FROST I the back means you are suffering
There are only 3 basic elements:
- Defrost thermostat (prevents overheating)
- Defrost Heat element (raises temperature (mildly))
- Defrost PC board (starts DF cycles) 61005988
Very simple & easy to fix ($72)... (see video)
With YOUR model number... check out (6 minute)
online VIDEO instructional directions...
My favorite website at appliance parts
Thermostat & HEATER assembly ($50... see VIDEO)
Whirlpool WP61006198 Defrost Assy AppliancePartsPros com
Sometime BEST prices (SEARS: I don't personally care for)
sears Water Filters Lawn Garden Appliance Parts
Hope this helps
Carnac the Magnificent
Nov 24, 2017 | Maytag MSD2656G Side by Side Refrigerator
Fridge has problems
sounds like the defrost clock may be going bad and or a door switch. Look for a hole that has whatr looks like a big screw that you can turn.
Oct 21, 2008 | Frigidaire FRS26R4A Side by Side...
GE Profile- Freezer/ Fridge at 56 wont go cooler!
check freezer for frost build up and if fan is blowing, check condenser, make sure its clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting, check make sure compressor is running
Aug 25, 2007 | GE Profile PSW26P Stainless Steel Side by...
Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker Logo
80 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
