Question about Karcher 2500 PSI Pressure Washer
Karsher 2500 psi
No water pressure
  • aubreydarn Sep 25, 2008
    Works when first started, with first trigger pull, then not. If I take the spray tip out and purge it a few times, replace the tip, then it works on first trigger pull again.
3 Suggested Answers
  • 174 Answers
SOURCE: when I squeez the handle the pressure surges.
Hi:
The first thing i would do is be sure there is not a partial blockage in the nozzle.
Posted on Sep 24, 2009
cool78259
  • 228 Answers
SOURCE: I don't get a constant
Make sure that while you are running your pressure washer, other machines that pull
large volumes of water like a dishwasher or washing machine are not running. check and make sure
the hose you have tied to the pressure washer is not collapsing or has any kinks in it.
check the filter where your water hose ties in to your pressure washer, make sure it
is clean and does not have any debris or hardwater buildup, clean the tip at the tip of
the wand. if it is reduced in size by hardwater buildup, will not work properly, good luck!
Posted on Jul 12, 2011
I don't get a constant stream of water from my Karcher 2500 psi pressure washer. instead is shoots in spurtss.
Jul 12, 2011 | Karcher 2500 PSI Pressure Washer
Karcher 2400 psi washer- no pressure
if the water is flowing
the valves need to change
if no water pistons in pump need to change.
Jul 22, 2009 | Karcher 2500 PSI Pressure Washer
Cleaning solution isn't siphoning to washer wand
you need to use i believe the black tip where there in least pressure it does not work with pressure
Jun 23, 2009 | Karcher 2500 PSI Pressure Washer
Poor pressure
i had this same problem on my pressure washer.the pump had some broken parts in it .i found my replacement pump on EBay.
May 29, 2009 | Karcher 2500 PSI Pressure Washer
No water pressure
There is a injector valve in the water pump that is sticking. Remove this valve, grease the top o-ring and reinstall. Problem solved. Use pump guard in the future to prevent this problem from reoccuring.
Mar 22, 2009 | Karcher 2500 PSI Pressure Washer
No pressure to handle
sounds as if pressure relief valve is stuck open. you will have to disassemble relief valve and clean or replace.
Jun 22, 2008 | Karcher 2500 PSI Pressure Washer
Honda 2500 pressure washer,
The oil in the front of the washer turned a cream color...like it has water in it. Any comments?
Apr 26, 2008 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
65 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
