Question about Acer Computers & Internet
I accidentally hit something while I was typing on msn to make the green characters on the keys appear and dont know how to change it back. it only seems to be doing on msn and not on here though. can you help me?
    Sergeant:
  • 241 Answers
Your font is green only on msn. Go into msn log on and you have to go in to options and change the font color. It was probably a short cut key stroke you hit. If not you browsers is the problem
Posted on Aug 28, 2008
How to remove code KYBD099
Take a look at the "L" key, if it has the word "lang" in green print at the bottom of the key, try holding down the "code" key while pressing the "L" key. This will take it out of language mode. This mode is only used if you have a foreign language keyboard.
Mar 08, 2016 | Lexmark Wheelwriter 30 Series II...
Occasionally a user reports that characters being typed do not appear on screen. Smarterm v12.1 configured as Digital VT session. Reboot of workstation fixes problem. Is there some sequence of keys user...
If "echo" is running, the terminal echoes what is being sent to the server. However, if "backslash" mode is enabled ("echo -e"), then the command "\c" tells echo "produce no further output." Try "\c" to see if that will toggle the command. If not, try "\C" or "\e" (escape). "echo -E" turns off the backslash mode entirely.
Nov 14, 2017 | Esker SmarTerm Essential VT
Apostropy and quotation mark keys change
The only time that I have this problem is when I've accidentally hit SHIFT and CTRL at the same time. Do it again and you should go back to your old way of typing characters.
Jul 14, 2010 | Acer NSK8458AN Keyboard
I am typing and I get numbers instead of letters. Is there something I can change
You have accidentally turned the Num Lock on.
Now depending on the model there are a couple of ways to turn it back off.
1, just hit the Num Lock key and see if its off (type something)
2, Hold down Fn and hit the Num Lock key, again type something.
Regards.
Dec 04, 2009 | Dell Inspiron 1501 Notebook
Symbols
You hit a keystroke combination. You'll have to press the Fn key in the lower left side of your keyboard and one of the special function keys (in a HP, I think it's something like F11 or F12--look at the symbols on the keyboard. Anyway, that combo locks the special characters on. Just hit it again to get back to normal typing.
Sep 22, 2009 | HP Pavilion dv6000z Notebook
Changing the Cursor Appearance
I had this same problem on my TI 89... You must have accidentally set your calculator to insert mode. To switch it back to the thin cursor, input the following keystrokes... Go to the "2nd" key to enter second function mode. Then press the button with an arrow on it pointing to the left(The key that you use to backspace). Do you see the "INS" lettering above the backspace key? There's your solution :-)
Apr 07, 2009 | Texas Instruments TI-89 Calculator
The keyboard characters does not correspond to what appears on sc
Does it type " by any chance when you press the @ key? if so this is usually because keyboard input is set to the wrong language in the regional & language settings are wrong in the control panel. try pressing the left alt key & shift at same time first this is a quick key to change between input languages.
Feb 27, 2009 | Dell Inspiron 500m Notebook
Typing characters to the right instead of the regular left one
look for a switch that says "Kybrd 1" and "Kybrd 2" and put it on Kybrd 1.
Oct 09, 2008 | Brother ML-100 Typewriter
Keyboard
Okay, if I am reading this right, you type but get numbers where there should be some letters? There should be a NUM LK key or such on your laptop keyboard. It may be sharing a key. Check around, its there (or something very very similar). Once you find it, you will have to hold down your "fn" key and then tap the NUM LK key. Now type a sentence that includes the letters that show up as numbers and see if there is a change. It could be that your Number Lock key is on. Let me know if this does not work so we can try something else.
May 24, 2008 | Compaq Presario 2100U Notebook
Computers & Internet Logo
41 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
