Question about Weber Gas Go-Anywhere Grill
Inside of the lid of the Weber Grill peels - Weber Gas Go-Anywhere Grill
It's not peeling. That is carbonized grease build up from cooking. Best solution is to was it real good with some degreaser. check out their website for more information.
Posted on Sep 08, 2008
Paint chipping inside hood
There is no paint. The cover is black anodized aluminum. What you are seeing is carbonized grease, although it can look like peeling paint. Just brush it off.
Jan 12, 2010 | Weber Genesis Silver A Grill
The inside coating of my Silver C is also peeling.
it looks like paint but it is food and smoke enamel on hood is baked on at 1600 degrees no way to get grill that hot spray oven cleaner on top not the sides and wash off
Aug 01, 2009 | Weber Genesis Silver B Grill
My weber grill leaks grease from lid when it gets hot
This is common as grease condenses on the inside of the lid, especially on cooler days or when cooking very greasy foods like skin-on chicken. The only solution is to wipe down the inside of the lid after every use, especially along the bottom edges.
Jul 05, 2009 | Weber GENESIS E-310
How to Clean Weber Gas Grill Lid
you can only use oven cleaner on enameled hood not on the cast painted parts like the body and sides of the hood those you can scrape and vaccum or brush
Jun 28, 2009 | Weber Genesis Silver C Grill
Paint inside lid peeling off when I cook
From Weber.com Don’t worry, it’s not paint. The inside surfaces of our grill lids are not painted, they are coated with baked-on porcelain enamel which cannot peel. What you are noticing is a deposit of grease and smoke that collects during normal use. During use, the grease and smoke vapors slowly oxidize into carbon and collect on the inside of your lid. This deposit will eventually peel, and looks very similar to paint. The peeling normally starts in the center of the lid and spreads outward. It may come off in sheets or flakes, and is shiny on one side and dull on the other. These carbon deposits are non-toxic. But you might want to regularly remove the build-up. Fortunately, the peeling is easy to remove. Simply brush off all loose particles with a brass brush before you start grilling. To prevent future build-up, after every grilling session, while the grill lid is warm—not hot—wipe it with paper towels or a mild soap-and-water solution.
Apr 25, 2009 | Weber Genesis Silver C Grill
On the inside of the lid the paint or enamel coating is pealing off on to the food. Weber rep. said they don't paint the inside of the lid, and is probaly residue from cooking. But I used the word (paint)...
Most of the time what appears to be paint pealing, on the inside of your grill lid, is actually soot from your LP gas and bad combustion. May need someone to provide a thorough clean of your burners and check that your orifice sizes are correct and clean(holes on back of valves).   If you can, convert your grill to NG.. that will almost always solve a sooting issue(it burns much cleaner than LP)!  Hope this gives you some answers?
Mar 28, 2009 | Weber Genesis Silver B Grill
Paint on top inside of lid is peeling off.
Remove the paint. The heat will dry the metal and grease from cooking will keep it from rusting, if it's iron. If it's aluminum it's not a problem.
Mar 14, 2009 | Weber Genesis Silver B Grill
Weber Gas Go-Anywhere Grill Logo
235 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
